Relieving in flight
Old December 25th 17, 02:22 AM posted to rec.aviation.soaring
Default Relieving in flight
I don't remember who told me this story, or if it is even true (soaring pilots, don't you know), but be sure to retract the pee tube prior to landing. The tale I was told involved a tube so long that the main wheel ran over it on touchdown and gave the pilot an uncomfortable sensation as it forcibly removed the external catheter. And probably several years of life expectancy due to the surprise.
  #52
Old December 25th 17, 11:28 AM posted to rec.aviation.soaring
Jim Kellett
snip
It's true. It happened to a good friend of mine (now deceased, but not from this experience!) It was a 1-26 and the tube exited the cockpit right in front of the wheel.
  #53
Old December 25th 17, 02:00 PM posted to rec.aviation.soaring
Followed upon landing with yelling "push it back-push it back!"
LOL
UH
  #55
Old December 25th 17, 08:06 PM posted to rec.aviation.soaring
Le mercredi 20 décembre 2017 21:56:46 UTC-5, a écritÂ*:
Ok guys, this has probably been covered in older posts but what are you all using regarding urinary relief on long flights? Ive used gallon ziplock bags in the past but whats your experience with cathaters. What brand and how are they.
A different solution.
Because of cold weather and heavy clothing in club glider with no urinal possibilty I have used with success and no mess a maximum absorbency pad inside a overnight underwear. The pad will gel. If the amount of fluid is to large it will over flow in the under wear and will not leak. No discomfort no odor no mess.
Gilles
  #56
Old December 25th 17, 08:17 PM posted to rec.aviation.soaring
Paul Agnew
We'll look up "curb feeler" while you older guys look up "manscaping".
Paul A.
  #57
Old December 25th 17, 09:28 PM posted to rec.aviation.soaring
Dan Marotta
I understand that, but real men don't mind a little pain. :-D
Paul A.
Dan, 5J
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
  #58
Old December 26th 17, 12:48 AM posted to rec.aviation.soaring
On Monday, December 25, 2017 at 10:21:52 AM UTC-8, Dan Marotta wrote:
I always thought it made a great "curb feeler" (you youngsters look that
up), and was a last chance gear warning.
Except when it sticks dow farther than the gear and the unfortunate pilot pulls up, retracts the wheel and slams down on the belly. It's been done...
5Z
  #59
Old December 26th 17, 03:05 PM posted to rec.aviation.soaring
Waveguru
I had an Open Jantar with a relief port built into the fuselage under the seat. After using it for a season there was an article in Soaring about how the pee would run down the fuselage, into the gear well, and corrode things.. I ended up removing the gear and refinishing it. The article said to run the tube back to the gear doors to get the pee away from the fuselage by dropping the gear. It also said to put a T in the line so you could blow it out so it wouldn't freeze. I ran a new line back and put the T in, tested it on the ground and went soaring. After a couple of hours in the wave, I really had to pee, so I dropped the gear and cut loose. The pee started coming out of the blow out tube and into my lap! I immediately pinched off the tube, but it's hard to stop peeing that quick. The condom started filling up like a water balloon! Great, now what? I stuck the tube out the vent window and finished the job, spraying **** all over the fuselage and wing. So I'm left with a tube full of **** that I didn't want inside. I thought there must be some small plug in the line, it had worked on the ground... My solution was to wipe off the end of the tube and blow on it, which just re-inflated the condom! Frustrated and not thinking, I pulled the tube out of my mouth, blasting the remaining **** back into my mouth and all over my face! My first response was disgust, but then I thought "That didn't taste all that bad... Maybe with a little ice and a sprig of mint..." Back on the ground I discovered the problem. I had ran tube under the seat pan and my weight crushed the tube. After re-routing, it worked well for many years. Happy soaring.
Boggs
  #60
Old December 26th 17, 03:40 PM posted to rec.aviation.soaring
Roy B.
Boggs:
You should sell the movie rights to that story. :-)
ROY
IGC Flight Recorders using Flarm firmware - New DLL file forvalidating IGC flight data files Ian Strachan Soaring 0 July 20th 14 07:28 PM
New 18m Class ship - First Flight - The JS1 starts proving flight phase [email protected] Soaring 2 December 14th 06 02:06 AM
NEW FLIGHT SCHOOL - Best in Flight Aviation Academy - Morristown,New Jersey Dave Vioreanu Piloting 0 April 22nd 05 02:55 AM
NEW FLIGHT SCHOOL - Best in Flight Aviation Academy - Morristown, New Jersey Guy Elden Jr Piloting 0 April 21st 05 04:37 PM
Does anybody know a link to a real picture of the X-43 in flight sans Pegasus or better yet a video clip of the flight? Scott Ferrin Military Aviation 0 April 3rd 04 08:47 PM
