what is that noise?
Old August 2nd 19, 12:42 AM posted to rec.aviation.soaring
Charlie Quebec
Default what is that noise?
On none removable lift pins, the shins are lightly glued on to the fuse wing fillet with contact cement or similar.
Be warned, too tight shims can make rigging very difficult in hot weather.
  #32
Old August 2nd 19, 12:52 AM posted to rec.aviation.soaring
My Libelle has a floating shim on one of the lift pins and I'm afraid it will slide off and get lost during assembly/disassembly. Sounds like cementing it on may be the trick.
FAA paper Noise Attenuation Properties of Noise-Canceling Headsets Jim Macklin Piloting 26 January 13th 07 12:06 AM
FAA paper Noise Attenuation Properties of Noise-Canceling Headsets Jim Macklin Instrument Flight Rules 15 January 13th 07 12:06 AM
Prop noise vs. engine noise Morgans Piloting 8 December 24th 03 03:24 AM
noise G.A. Seguin Soaring 2 August 27th 03 01:57 AM
Com noise Hankal Piloting 0 July 21st 03 12:54 AM
