newest backup for gyro failure in IMC
For photography dorks only.... Nikon D3 SLR camera: http://www.dpreview.com/previews/nikond3/page8.asp (scroll down to see Virtual Horizon) It may be time for you Canon users to go Nikon. After all, can your 1D Mark III save your bacon in hard IMC? Not yet available at Sporty's. -- dave j |
In article
, Dave J wrote: For photography dorks only.... Nikon D3 SLR camera: http://www.dpreview.com/previews/nikond3/page8.asp (scroll down to see Virtual Horizon) It may be time for you Canon users to go Nikon. After all, can your 1D Mark III save your bacon in hard IMC? Not yet available at Sporty's. -- dave j It is most unfortunate that they chose an aviation-style display because this feature is almost certainly implemented with an accelerometer, not a gyro, so it will not work in an airplane. It will be fooled in exactly the same way that the human inner-ear is fooled, which is the reason you need a gyro-based AI (or TC) in the first place. If you try to use this as a backup AI in IMC you will almost certainly die. rg |
Actually, Ron you can derive a very accurate attitude reference from only
accelerometer(s). This is how the AHRS units in a Garmin G1000 work for example. They integrate accelerations and moments using small very accurate mechanical sensors. There is no "spinning" platform which uses rigidity in space to provide a reference on these airplanes, except for the backup AI. The reason your brain is fooled is becuase it uses a fluid pool to sense the vertical. In the case of an acceleration the fluid shifts and you mis-interpret this as a change in attitude. Now, I cannot vouch for using a camera as an inflight reference :^) However, I have wondered if some sort of "solid state" package (or something based on the small RC helicopter gyros) could be built that could provide an attitude reference that you could even velcro to the glare shield. Maybe the camera is proof we would be close. Regards Todd "Ron Garret" wrote in message ... It is most unfortunate that they chose an aviation-style display because this feature is almost certainly implemented with an accelerometer, not a gyro, so it will not work in an airplane. It will be fooled in exactly the same way that the human inner-ear is fooled, which is the reason you need a gyro-based AI (or TC) in the first place. If you try to use this as a backup AI in IMC you will almost certainly die. rg |
"Todd W. Deckard" wrote: Actually, Ron you can derive a very accurate attitude reference from only accelerometer(s). I doubt that very much. You need roll rate information from somewhere. Do you have a reference? In any case, even if you can do it with just accelerometers, you need very good accelerometers and you need an integrator, neither of which this camera is likely to have. It almost certainly has a single accelerometer and no integrator. All it will tell you is the apparent acceleration, not your actual attitude. This is how the AHRS units in a Garmin G1000 work for example. They integrate accelerations and moments using small very accurate mechanical sensors. Yes, but some of those sensors are gyros. They are solid-state gyros, but they are gyros nonetheless. (The gyros may themselves be built out of accelerometers as components, but one way or another you have to sense rotation rate in order to build an AHRS.) Now, I cannot vouch for using a camera as an inflight reference :^) However, I have wondered if some sort of "solid state" package (or something based on the small RC helicopter gyros) could be built that could provide an attitude reference that you could even velcro to the glare shield. Yes, such things exist (e.g. http://www.icarusinstruments.com/microEFIS.html). But they are expensive because they require multiple sensors and sophisticated electronics to do the integration. Maybe the camera is proof we would be close. No, this is exactly my point. What this camera is doing is (almost certainly -- I haven't actually looked at its technical specs) NOT the same as an AHRS despite the fact that their behavior is superficially similar, particularly when you are not in an airplane. That is exactly why I think it's important to warn pilots away from trying to use this device as a backup AI. It will almost certainly kill you. rg |
No, this is exactly my point. What this camera is doing is (almost certainly -- I haven't actually looked at its technical specs) NOT the same as an AHRS despite the fact that their behavior is superficially similar, particularly when you are not in an airplane. That is exactly why I think it's important to warn pilots away from trying to use this device as a backup AI. It will almost certainly kill you. Yes, I don't think we have any idea how this camera works, but it's a fair bet that it won't work very well in an aircraft. We'll have to wait for a pilot to buy one and try it out. My understanding of gyros, be they mechanical or otherwise, was that they can indeed work simply by measuring and integrating acceleration. However, that needs to be angular acceleration, not linear. It was also my understanding that the solid state accelerometers in GA glass cockpits are in reality not very good on their own. The attitude solution displayed is actually computed from the integrated accelerometer values corrected with magnetometer info, air data info, and even gps data. -- dave j |
As I said Ron, it integrates accelerations and moments (probably should say
'or') I believe it gets angular moments from a small mems device that deflects under twist, however, opposing accelerometers separated by a distance accomplish the same. I've never looked at a schematic. The gizmo is a very small mass on some kind of spring or lever (thus you have the force and the mass, so the deflection gives you acceleration). It does *not* use the principle of rigidity in space provided by a spinning gyroscope in which conservation of angular momentum resists a change in its spin axis. No one is suggestion that you use a camera to provide a backup flight instrument. The only purpose of my post was to site the minor physics gaff. Its the old teacher's assistant in me I guess. Someone else can chain onto this and tell me I am misusing the term 'moment' It *is* interesting to me that consumer electronics provide this capability. Between the camera, and the more expensive R/C helicopters which have a stability augmentation system like a yaw damper (which uses an actual spinning gyro) this stuff is coming into reach of a cockpit mountable capability. A bigger crime to be debated is the "psuedo" panel display afforded by some of the handheld GPS units. It derives bearing and attitude information from the apparant change in flight path. I have heard folks speculate that this could be used in instrument flight after failure of the AI/HI? I might open up a thread to see how that debate unfolds. It would certainly be more interesting than the essays on tort reform and having your mom sew epaulets on your Sport's pilot shirt that are all the rage on the other forums. Regards Todd "Ron Garret" wrote in message ... In article , "Todd W. Deckard" wrote: Actually, Ron you can derive a very accurate attitude reference from only accelerometer(s). I doubt that very much. You need roll rate information from somewhere. Do you have a reference? In any case, even if you can do it with just accelerometers, you need very good accelerometers and you need an integrator, neither of which this camera is likely to have. It almost certainly has a single accelerometer and no integrator. All it will tell you is the apparent acceleration, not your actual attitude. This is how the AHRS units in a Garmin G1000 work for example. They integrate accelerations and moments using small very accurate mechanical sensors. Yes, but some of those sensors are gyros. They are solid-state gyros, but they are gyros nonetheless. (The gyros may themselves be built out of accelerometers as components, but one way or another you have to sense rotation rate in order to build an AHRS.) Now, I cannot vouch for using a camera as an inflight reference :^) However, I have wondered if some sort of "solid state" package (or something based on the small RC helicopter gyros) could be built that could provide an attitude reference that you could even velcro to the glare shield. Yes, such things exist (e.g. http://www.icarusinstruments.com/microEFIS.html). But they are expensive because they require multiple sensors and sophisticated electronics to do the integration. Maybe the camera is proof we would be close. No, this is exactly my point. What this camera is doing is (almost certainly -- I haven't actually looked at its technical specs) NOT the same as an AHRS despite the fact that their behavior is superficially similar, particularly when you are not in an airplane. That is exactly why I think it's important to warn pilots away from trying to use this device as a backup AI. It will almost certainly kill you. rg |
"Todd W. Deckard" wrote: It *is* interesting to me that consumer electronics provide this capability. I dunno. Single accelerometers with no integration logic are pretty cheap. Macbooks have had them for some time now. They are used to park the hard drive head if you drop the machine. There's also a dashboard widget you can install that displays the accelerometer reading as a bubble level, which is kinda cool, and much more appropriate IMO than an aviation-style display. http://www.apple.com/downloads/dashb...carpentersleve l.html in case you're interested. Between the camera, and the more expensive R/C helicopters which have a stability augmentation system like a yaw damper (which uses an actual spinning gyro) this stuff is coming into reach of a cockpit mountable capability. Yes. I already noted that such devices are already on the market: http://www.icarusinstruments.com/microEFIS.html It costs about $1500 (which, interestingly, is about the same as a middle-of-the-line Macbook). A bigger crime to be debated is the "psuedo" panel display afforded by some of the handheld GPS units. It derives bearing and attitude information from the apparant change in flight path. I have heard folks speculate that this could be used in instrument flight after failure of the AI/HI? I actually tried this a while back in a 182 and a handheld GPS. It works actually much better than a single accelerometer (which is pretty much guaranteed to kill you). If you are very, very careful you can keep the plane kinda sorta level for quite a while. But it's mentally exhausting, and I certainly would not want to rely on it in IMC. rg |
In article
, Dave J wrote: No, this is exactly my point. What this camera is doing is (almost certainly -- I haven't actually looked at its technical specs) NOT the same as an AHRS despite the fact that their behavior is superficially similar, particularly when you are not in an airplane. That is exactly why I think it's important to warn pilots away from trying to use this device as a backup AI. It will almost certainly kill you. Yes, I don't think we have any idea how this camera works, but it's a fair bet that it won't work very well in an aircraft. We'll have to wait for a pilot to buy one and try it out. My understanding of gyros, be they mechanical or otherwise, was that they can indeed work simply by measuring and integrating acceleration. However, that needs to be angular acceleration, not linear. It was also my understanding that the solid state accelerometers in GA glass cockpits are in reality not very good on their own. The attitude solution displayed is actually computed from the integrated accelerometer values corrected with magnetometer info, air data info, and even gps data. -- dave j Yes, I believe that is exactly right. And it is all that complexity that makes them expensive. rg |
A bigger crime to be debated is the "psuedo" panel display afforded by some of the handheld GPS units. It derives bearing and attitude information from the apparant change in flight path. I have heard folks speculate that this could be used in instrument flight after failure of the AI/HI? This, however, is something that is easy enough to try, and indeed, I have done so. (under the hood, with a safety pilot). My unit, a Garmin 196, does not include any attitude information, but it does provide: "airspeed" -- actually, groundspeed "heading" -- actually, track (but hey, once you've gone track, you don't go back) "altitude" -- GPS derived, but with WAAS, not too bad when I tried it turn and bank -- based on rate of turn, see heading above. My experience is partial panel with this was just as easy, if not easier to fly than with the same panel of real instruments. Starting in controlled, stable flight, I was able to perform all maneuvers necessary for instrument flight (climbs, descents, turns) without any trouble. It was no more fatiguing than normal partial panel. Starting from a spin or something, I have my doubts. -- dave j I might open up a thread to see how that debate unfolds. It would certainly be more interesting than the essays on tort reform and having your mom sew epaulets on your Sport's pilot shirt that are all the rage on the other forums. |
Similar Threads | ||||
backup for vacuum pump/attitude indicator failure | Kelly | Owning | 27 | November 29th 06 06:58 AM |
backup for vacuum pump/attitude indicator failure | Kelly | Instrument Flight Rules | 26 | November 29th 06 06:58 AM |
Backup AI (using solid state gyro) for portable | Andrew Gideon | Piloting | 14 | January 27th 05 08:41 AM |
Backup AI (using solid state gyro) for portable | Andrew Gideon | Products | 13 | January 27th 05 08:41 AM |
gradual gyro failure in FS2004? | Gary L. Drescher | Simulators | 3 | July 19th 03 07:07 AM |
