Garmin 430/530 WAAS upgrade reminder Nov 15
Doug wrote:
What functionality do you get after the upgrade that you don't have now? The ability to fly glideslope-like approaches with the GPS into airports that never could afford an ILS. -- Peter ----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups ----= East and West-Coast Server Farms - Total Privacy via Encryption =---- |
It's the 'later this year' that I've been hearing for 3 yrs. I also don't
want the box to go in for terrain (which I have on an EFB) and then go back for WAAS. I'll do it once. (and for all) -- Thx, {|;-) Victor J. (Jim) Osborne, Jr. "Andrew Gideon" wrote in message online.com... Victor J. Osborne, Jr. wrote: At AOPA in Tampa, the Garmin rep said "No airways on 430/530 series GPS" I've been told this as well. When I ask "why", I get silly answers like "it's too complex a way to enter flight plans". That always sounded silly to me...until I spoke to a VFR-only pilot about it. So perhaps either (1) Garmin sells mostly to VFR pilots or (2) Garmin tests their software mostly with VFR pilots. Or perhaps (3) it was just a silly excuse. I've heard other silly things that speak to some disconnect with the company. For example, technical support once told me that there'd be no CPU speedup in the WAAS upgrade, and that it would be done later. That same day, someone in engineering told me "of course the CPU will be faster; that's required for certification!" They're all very nice and helpful. Amazing as I find it (I deal mostly with tech firms {8^), Garmin has some friendly and communicative people working for them. I just wish they'd get the story straight laugh. Then again they said WAAS in late 2003, early '04 I'm also waiting on terrain. Hey, isn't that out already (as of late last year, if I recall correctly)? Or was that only for the 530? - Andrew |
Hey, isn't that out already (as of late last year, if I recall correctly)? Or was that only for the 530? Certified terrain (TAWS) is only available on the 530 and it's expensive. Terrain "advisories" are available now for the 430 and 530. It's coming standard on all new units (as of beginning of September). If you bought a unit after June 1 the upgrade is free otherwise it's $500. In either case you'll also need to pay for about an hour of shop time to get it installed (You could send it back to Garmin but it won't be cheaper and it'll take longer). You may need a bit more shop time if your flight manual supplement needs to be updated. --Rick |
Rick Beebe wrote On 11/18/05 13:37,:
I'm also waiting on terrain. Hey, isn't that out already (as of late last year, if I recall correctly)? Or was that only for the 530? Certified terrain (TAWS) is only available on the 530 and it's expensive. Terrain "advisories" are available now for the 430 and 530. It's coming standard on all new units (as of beginning of September). If you bought a unit after June 1 the upgrade is free otherwise it's $500. In either case you'll also need to pay for about an hour of shop time to get it installed (You could send it back to Garmin but it won't be cheaper and it'll take longer). You may need a bit more shop time if your flight manual supplement needs to be updated. --Rick Although certainly integration of TWAS into the 430/530 would be nice, the Garmin upgrade is meant for turboprops that require it under FAA rules. There is no advantage over having it in an add on unit, such as the new Garmin portables. If you get a TWAS alert I doubt you are going to be worried about if it is a TSO'ed, official warning while you pull up... |
Rick Beebe wrote:
You may need a bit more shop time if your flight manual supplement needs to be updated. I don't understand this (although I believe I've seen it mentioned before). Why would the manual need updating in some cases but not others? - Andrew |
Andrew Gideon wrote:
Rick Beebe wrote: You may need a bit more shop time if your flight manual supplement needs to be updated. I don't understand this (although I believe I've seen it mentioned before). Why would the manual need updating in some cases but not others? If we're talking about an upgrade from TSO C129 to TSO C146, I don't see how the SPOH could avoid being updated. It's the SPOH that has the operating limitations, and they will surely change. Dave |
Rick Beebe wrote: You may need a bit more shop time if your flight manual supplement needs to be updated. I don't understand this (although I believe I've seen it mentioned before). Why would the manual need updating in some cases but not others? As Garmin got close to releasing the terrain advisory feature they started adding it into the manual. So if your manual doesn't have it, it needs to be redone. My manual doesn't have it (and my 430 is getting updated) and I haven't seen what the actual changes are yet. Probably a silly paragraph that just says that terrain advisories are not to be used for actual navigation. --Rick |
Rick Beebe wrote On 11/21/05 13:59,:
Andrew Gideon wrote: Rick Beebe wrote: You may need a bit more shop time if your flight manual supplement needs to be updated. I don't understand this (although I believe I've seen it mentioned before). Why would the manual need updating in some cases but not others? As Garmin got close to releasing the terrain advisory feature they started adding it into the manual. So if your manual doesn't have it, it needs to be redone. My manual doesn't have it (and my 430 is getting updated) and I haven't seen what the actual changes are yet. Probably a silly paragraph that just says that terrain advisories are not to be used for actual navigation. --Rick You must not rely on a terrain alert alone for navigation. If the terrian collision alert is heard, this must be verified by one of the following: 1. Sighting of the ground approching at rapid velocity. 2. Tree branches hitting the airplane. 3. Screams of ground based person(s). 4. Wet sensation in undergarmets. 5. White light at end of long corridor. |
Scott Moore wrote:
You must not rely on a terrain alert alone for navigation. If the terrian collision alert is heard, this must be verified by one of the following: 1. Sighting of the ground approching at rapid velocity. 2. Tree branches hitting the airplane. 3. Screams of ground based person(s). 4. Wet sensation in undergarmets. 5. White light at end of long corridor. Any less than three of these indicators could mean the Garmin has malfunctioned and the terrain alert should be disabled until the unit can be verified by authorized service personnel. --Rick |
Similar Threads | ||||
Garmin 430/530 WAAS upgrade reminder Nov 15 | Paul kgyy | Owning | 18 | November 22nd 05 07:22 PM |
Garmin backing away from additional GDL-69 features for 430/530 products? | Andrew Gideon | Owning | 2 | September 9th 05 11:36 PM |
More info on GNS 430/530 WAAS upgrade | PPT33R | Instrument Flight Rules | 33 | June 24th 05 02:21 PM |
Any inside story re 430/530 WAAS cert.? | [email protected] | Instrument Flight Rules | 0 | May 20th 05 06:13 PM |
WAAS and Garmin 430/530 | DoodyButch | Owning | 23 | October 13th 03 04:06 AM |
