Fuel Flow instrument
has anyone considered trying a marine fuel flow instrument in home built.
http://www.navman.com/marine/product...100/index.html I was considering the EI-fp-5 but at $750 it a bit pricy for my budget.. The marine unit does the same thing for $150 Any thoughts? Bill |
"Billc851" wrote in message ... has anyone considered trying a marine fuel flow instrument in home built. http://www.navman.com/marine/product...100/index.html I was considering the EI-fp-5 but at $750 it a bit pricy for my budget.. The marine unit does the same thing for $150 Any thoughts? Bill I'm currently using that unit on my 19 foot Glasply. It functions well for me. It has barbed fittings and I would have preferred flared. MikeR |
("Billc851" wrote)
snip has anyone considered trying a marine fuel flow instrument in home built. http://www.navman.com/marine/product...100/index.html 32F/0C for the low end operating temp? Maybe it isn't intended for the icebreaker segment of the marine market. Montblack |
"Billc851" wrote in message ... has anyone considered trying a marine fuel flow instrument in home built. http://www.navman.com/marine/product...100/index.html I was considering the EI-fp-5 but at $750 it a bit pricy for my budget.. The marine unit does the same thing for $150 I'd check put the design of the transmitter, aircraft certified FF transmitters will allow full fuel flow even if the transmitter malfunctions; some commercial units reportedly will restrict fuel flow if the internal wheel seizes up. |
John Kunkel wrote:
I'd check put the design of the transmitter, aircraft certified FF transmitters will allow full fuel flow even if the transmitter malfunctions; some commercial units reportedly will restrict fuel flow if the internal wheel seizes up. Such things have been reported - but not by reliable witnesses. Seriously, a turbine is not a positive-displacement meter. Even if the bearings freeze, liquid can still get past it. The main difference between electronics designed for airplanes and boats is cost, not quality. Michael |
"John Kunkel" wrote in message ... "Billc851" wrote in message ... has anyone considered trying a marine fuel flow instrument in home built. http://www.navman.com/marine/product...100/index.html I was considering the EI-fp-5 but at $750 it a bit pricy for my budget.. The marine unit does the same thing for $150 I'd check put the design of the transmitter, aircraft certified FF transmitters will allow full fuel flow even if the transmitter malfunctions; some commercial units reportedly will restrict fuel flow if the internal wheel seizes up. No wheel in this one (electrical impulses). |
"MikeR" wrote in message ... No wheel in this one (electrical impulses). Impulses from what? |
Bill,
You may want to take a look at the Aveo MaxiSingles model FF-3. It is $172 plus $125 for the sender. I have 2 of their instruments and like them alot. http://www.aveousa.com/avionics/inst...gles/index.htm Greg Piney Billc851 wrote: has anyone considered trying a marine fuel flow instrument in home built. http://www.navman.com/marine/product...100/index.html I was considering the EI-fp-5 but at $750 it a bit pricy for my budget.. The marine unit does the same thing for $150 Any thoughts? Bill |
"Blueskies" wrote in message . com... "MikeR" wrote in message ... No wheel in this one (electrical impulses). Impulses from what? Ref: http://203.167.230.122/qiss/scripts/FAQFrame.htm Title: How does the flow transducer work? Question/Symptom: How does the flow transducer work? -------------------------------------------------------------------------- Answer/Solution: NAVMAN flow transducers are of an optical type. Within the transducer are a transmitter and receiver that output an infrared beam through the body of the transducer. Inside the transducer is a very precisely dimensioned turbine running on jewelled bearings. As the fuel flows it spins the turbine and the blades cut the infrared beam, which transmits a pulsed signal to the fuel computer. |
"MikeR" wrote in message ... "Blueskies" wrote in message . com... "MikeR" wrote in message ... No wheel in this one (electrical impulses). Impulses from what? Ref: http://203.167.230.122/qiss/scripts/FAQFrame.htm Title: How does the flow transducer work? Question/Symptom: How does the flow transducer work? -------------------------------------------------------------------------- Answer/Solution: NAVMAN flow transducers are of an optical type. Within the transducer are a transmitter and receiver that output an infrared beam through the body of the transducer. Inside the transducer is a very precisely dimensioned turbine running on jewelled bearings. As the fuel flows it spins the turbine and the blades cut the infrared beam, which transmits a pulsed signal to the fuel computer. OK, normal stuff. Thanks for the link. The concern from the other folks is what happens to pressure drop if the (turbine in this case) wheel seizes up. Usually it will add some pressure drop with a corresponding restriction to the flow, but the turbine types pass fluid pretty well even if seized... |
Similar Threads | ||||
Instrument Checkride passed (Long) | Paul Folbrecht | Instrument Flight Rules | 10 | February 11th 05 02:41 AM |
Shadin's Fuel Flow Management System | Tom Alton | Products | 0 | September 1st 04 06:07 PM |
Is Your Airplane Susceptible To Mis Fu eling? A Simple Test For Fuel Contamination. | Nathan Young | Piloting | 4 | June 14th 04 06:13 PM |
Logging approaches | Ron Garrison | Instrument Flight Rules | 109 | March 2nd 04 05:54 PM |
PC flight simulators | Bjørnar Bolsøy | Military Aviation | 178 | December 14th 03 12:14 PM |
