Military Airfield Procedures..
Old February 26th 06, 02:50 PM posted to rec.aviation.piloting,rec.aviation.ifr
Default Military Airfield Procedures..
"Dan" wrote in message
Last night I took a quick trip to KYUM. On approach, the controller
mentioned that the "arresting gear was up" on the runway I was to land
on. Being unfamiliar with arresting gear and flying an Archer, I asked
the controller specifically what that meant. He indicated that it
consisted of a cable stretched across the runway about 6 inches high.
Since it seemed that this could seriously damage an Archer, I made sure
to land beyond it. (although it's exact position was difficult to
determine at night.)
Does anyone know what would have happened if I had landed on it? This
type of thing seems quite dangerous to GA aircraft.
IT IS!
You could easily find yourself without your landing gear if you land before
the cable.
On another note, as I was inbound on the ILS, the tower handed me over
to someone else for a "monitored" approach. This controller called my
position on the ILS and advised of any deviations. There was no
parallel ILS in progress. Is this just the way things are done at a
military field?
Yes.
Old February 26th 06, 02:55 PM posted to rec.aviation.piloting,rec.aviation.ifr
"David Cartwright" wrote in message
One has to wonder why they didn't put it down for you (the fact that they
said it was up suggests it was retractable). As for what would have
happened - well, it would almost certainly have damaged your landing gear.
I think this is holdover from previous arresting gear terminology. There
are still web type devices that are actually "up" and then retracted when
not needed. Most cables are "strung" across the runway. At most fields,
changing a cable configuration is a manual process that takes a couple of
guys about 20 minutes or so to accomplish. Not something they will do for a
GA arrival.
Old February 26th 06, 07:18 PM posted to rec.aviation.piloting,rec.aviation.ifr
The cable was probably manually operated only. Normal configuration for
manual cables is to have the approach end cable removed, and the
departure end cable strung across the runway. That way, military jets
that have brake failure or abort takeoff can snag it and come to a stop.
If the wind shifts and requires a runway change, then the tower has to
direct a crew out there to change the cable configuration. They may not
have had enough time to do that before you came in, or you may have been
operating "opposite direction" in able to get the ILS approach. There's
a good article about cables at the following link, it even mentions an
incident where an MD-88 snagged a cable during takeoff roll and came to
a stop.
http://www.boeing.com/assocproducts/...ingsystems.pdf
I'm not sure the E-28 cables at Yuma are remotely retractable.
Incidentally, even if the arresting gear was down, you should always try not
to land before it (assuming there's plenty of runway the other side - which
there should be). I did part of my PPL training at RAF Coltishall, which has
arrester gear that sits in a little channel across the runway when it's
down. If you roll over the channel, you get a hell of a bump.
David C
Ahh, RAF Coltishall. I spent 2 tours over in East Anglia. One at
Ben****ers/Woodbridge, the other at Mildenhall. It's amazing how many
airfields they squeezed into such a small area.
John
Old February 27th 06, 04:36 PM posted to rec.aviation.piloting,rec.aviation.ifr
"John Doe" wrote in message
news:2fjMf.42118$Dh.501@dukeread04...
I've done it in a C-150, at NAS Millington, TN, with a flying club
aircraft. I was unfamiliar, simulating a dead stick with an Instructor, when
we touched down before the last wire. We rolled right over it. No damage.
When I saw we were going to hit it, I held the nosegear well clear, and hit
it with the mains. We were probably still doing about 30kts, and had full
flaps, so there was some lift being generated. I am a little amazed the
cable didn't pop up and strike the tiedown ring on the tail cone which must
have been a foot off the ground or so. Of course the cable is pretty heavy,
and I doubt the 150 moved it much.
The system they used to have installed at Klamath Falls,(Kingsley
Field), had the same wire and donut scheme, but it was connected to what
looked like anchor chain on both sides of the runway. One link was
positioned right next to the prior link, so the chain was very "slack". When
you caught the wire, you pulled one link on each side for about a foot, then
picked up the next link for about a foot. Before long you were dragging many
tons of iron down the runway. I have no doubt that it would stop almost
anything.
Al
Old February 28th 06, 12:26 AM posted to rec.aviation.piloting,rec.aviation.ifr
"JPH" wrote in message
news9nMf.173258$WH.118923@dukeread01...
Well, there are fewer now. Benwaters/Woodbridge closed about 6-7 yrs ago.
Coltishall ceases to be operational on April 1st and will close towards the
end of the year when our last General Aviation ac will also depart. It's all
sad ;-(
When landing at RAF Stations the question asked is "Are you familiar with
the field", referring to the RHAG (rotary hydraulic arresting gear). I just
say "negative, but have the RHAG in site".
Gus Cabre
RAF Coltishall
Old February 28th 06, 04:39 AM posted to rec.aviation.piloting,rec.aviation.ifr
just
So, how about a quick description of RHAG?
Old February 28th 06, 02:18 PM posted to rec.aviation.piloting,rec.aviation.ifr
They had, probably still do, at the joint use airport at
Springfield, IL where I learned to fly about 40 years ago.
Runway 4/22 was used by F84F and had a cable that could be
raised by the tower that would catch the nose gear on the
F84F if it ran past a certain point. It used old Navy
anchor chain as weight.
"Morgans" wrote in message
Falls,(Kingsley
connected to what
One link was
was very "slack".
| When
for about a foot,
| then
you were dragging
| many
would stop almost
| anything.
| I have seen the same thing Seymore Johnson AFB, in
Goldsboro NC, and at
| another NC base that I can't remember, at this hour.
| Jim in NC
07 Feb 2006 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 February 7th 06 01:28 AM
30 Jan 2006 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 January 31st 06 03:21 AM
20 Nov 2005 - Today's Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 November 20th 05 09:43 PM
