Garmin 196 acting up
Old March 16th 04, 04:25 AM
Peter Duniho
Default Garmin 196 acting up
"BTIZ" wrote in message
news:0Pu5c.16807$Nj.10761@fed1read01...
[...] granted with minor errors of cheap handheld GPS
units
The "minor errors" exist in all GPS units, no matter the cost. There aren't
any error-free GPS units available.
Not all GPS receivers perform to the same standards, but they all have
errors. No amount of money will change this.
Pete
Old March 16th 04, 12:06 PM
Dennis O'Connor
It is working perfectly... The erratic motion when standing still is due to
two major items...
One, is the fact that your built in antenna is not recovering the data
stream as consistently as an external antenna will - are you sorrounded by
buildings?... Go out into an open area away from trees and buildings, or get
an external antenna and it will quiet down...
Second, the nature of gps is that there is a circle of confusion around the
fix point... The more satellites your unit sees with consistent data the
smaller the circle of confusion..
When your unit is dithering what is the EPE and DOP showing? I just ran out
to the car to check mine and the EPE is 28 feet, and the DOP is 1.7... The
heading was stable... The altitude was bouncing around about 4 to 5 feet
with variations in the data stream...
Do a google on gps and read up on the technology a bit...
cheers ... denny
"Glenn Westfall" wrote in message
I have a Garmin 196 and just in the past week or so it is acting
strange. I get a signal just fine, but when I am standing still it
constanly changes headings. It never moves in a direction, just turns
in circles sporatically. Once I begin to move, it tracks just fine.
But as soon as I stop, it constantly changes headings again. Anyone
else experience this? I upgraded to the latest software, but that
didn't fix the problem.
Glenn
Old March 16th 04, 01:12 PM
Nathan Young
On Mon, 15 Mar 2004 19:49:16 -0800, "BTIZ"
GPS only computes heading from "last known position" to "current position",
if you are not walking.. the "last known and current" are the same.. there
is no heading to compute.. granted with minor errors of cheap handheld GPS
units.. the "movement" could be minor inches or parts of an inch as the GPS
computes it's position.. and that will cause a heading change..
It is actually quite a bit more than inches. Single carrier civilian
GPS without SA (which has been shut off for several years now) is
accurate to about 10-20 meters. With WAAS corrections, it is about 3
meters.
The delta between any two position estimates is several inches to
several feet. Most GPS software will mask this motion and force the
velocity display to 0.0, and the heading display to be fixed, however,
if the delta between two position estimates is large enough, it can
generate a false movement.
-Nathan
Garmin 430 Reception Jon Kraus Owning 16 November 7th 04 03:17 AM
Garmin 296 worth the money? Terry Owning 15 June 22nd 04 09:03 AM
Garmin DME arc weidnress Dave Touretzky Instrument Flight Rules 5 October 2nd 03 02:04 AM
Garmin 430/530 Questions Steve Coleman Instrument Flight Rules 16 August 28th 03 09:04 PM
Garmin 90 Database Updates Discontinued Val Christian Piloting 14 August 20th 03 09:32 PM
