Dave S wrote:
And hence we have ANOTHER person who cannot tell the difference between MASS and VOLUME. I feel your frustration. And.. whats sad is.. the person who said 100 pounds probably thought they were being helpful by pointing out something "obvious" Dave Those that point out the mistakes of others would do well to mind their own. Pounds (lbs.) are a measure of weight, not mass (which in the English system would be slugs). Van's own web page shows the baggage area to be "12+ cu. ft." If you need a more precise number, I would suggest contacting Van's Aircraft directly. http://www.vansaircraft.com/public/rv-7spe.htm Russell Kent |
On Mon, 08 Dec 2003 09:59:10 -0600, Russell Kent
wrote: Dave S wrote: And hence we have ANOTHER person who cannot tell the difference between MASS and VOLUME. I feel your frustration. And.. whats sad is.. the person who said 100 pounds probably thought they were being helpful by pointing out something "obvious" Dave Those that point out the mistakes of others would do well to mind their own. Heed your own advice, fool. Pounds (lbs.) are a measure of weight, not mass (which in the English system would be slugs). Where'd you get that idea? Gene Nygaard http://ourworld.compuserve.com/homepages/Gene_Nygaard/ Gentlemen of the jury, Chicolini here may look like an idiot, and sound like an idiot, but don't let that fool you: He really is an idiot. Groucho Marx |
Russell Kent wrote:
Those that point out the mistakes of others would do well to mind their own. Gene Nygaard responded: Heed your own advice, fool. On entirely too many occasions I am indeed a fool, but I don't see where devolving to name calling improves the conversation. Besides gently (IMHO) chastising the intervening poster's rant, I still provided a useful answer to the original poster's question (12+ cu. ft.) and a reference to the source. Russell Kent continued: Pounds (lbs.) are a measure of weight, not mass (which in the English system would be slugs). Gene Nygaard responded: Where'd you get that idea? Uh, 2 years of high school physics (a jillion years ago). Perhaps a few web references will help clear the cobwebs: http://scienceworld.wolfram.com/physics/Slug.html http://www.physics.ucla.edu/k-6connection/Mass,w,d.htm Russell Kent |
OK, I know it's bad form to follow-up one's own posting. So sue me. :-)
Gene, I see from your signature that this "weight vs. mass" thing is a personal windmill for you. Fine. And I see that slug isn't used anymore (pound-force is the term now). And for non-technical conversations, pound is a unit of mass. Here's a question though: is this forum a technical or non-technical conversation? And look at the sequence of postings: EUTNET wrote that the baggage area dimension was 100 lbs, obviously meaning *weight*, and Dave S. complained that EUTNET "cannot tell the difference between MASS and VOLUME." [emphasis Dave's] So I believe Dave should have instead written "WEIGHT and VOLUME." Now I suspect that Dave S. was merely careless and really does understand the difference between mass and weight, and I was trying to gently pass along the advice that newsgroup corrections are invariably inspected for even the slightest error (see this thread!). I welcome you (Gene) jumping in at that point to correct the whole weight vs. mass, slugs, pound-force hullabalu, but I wish you'd do it with a bit less hostility. Someone may well have ****ed in your cornflakes, but I assure you it wasn't me. :-) Russell Kent Russell Kent wrote: Russell Kent wrote: Those that point out the mistakes of others would do well to mind their own. Gene Nygaard responded: Heed your own advice, fool. On entirely too many occasions I am indeed a fool, but I don't see where devolving to name calling improves the conversation. Besides gently (IMHO) chastising the intervening poster's rant, I still provided a useful answer to the original poster's question (12+ cu. ft.) and a reference to the source. Russell Kent continued: Pounds (lbs.) are a measure of weight, not mass (which in the English system would be slugs). Gene Nygaard responded: Where'd you get that idea? Uh, 2 years of high school physics (a jillion years ago). Perhaps a few web references will help clear the cobwebs: http://scienceworld.wolfram.com/physics/Slug.html http://www.physics.ucla.edu/k-6connection/Mass,w,d.htm Russell Kent |
On Mon, 08 Dec 2003 15:02:03 -0600, Russell Kent
wrote: Russell Kent wrote: Those that point out the mistakes of others would do well to mind their own. Gene Nygaard responded: Heed your own advice, fool. On entirely too many occasions I am indeed a fool, but I don't see where devolving to name calling improves the conversation. I see that even that wasn't enough to get your attention, Chicolini. How big a bat do I need to hit you over the head with to get your attention? Besides gently (IMHO) chastising the intervening poster's rant, I still provided a useful answer to the original poster's question (12+ cu. ft.) and a reference to the source. Yes, you got that right. Too bad nobody will pat you on the back for it, because you obscured it with irrelevant nonsense, and even worse, an incorrect claim of error on someone else's part. Russell Kent continued: Pounds (lbs.) are a measure of weight, not mass (which in the English system would be slugs). Gene Nygaard responded: Where'd you get that idea? Uh, 2 years of high school physics (a jillion years ago). Perhaps a few web references will help clear the cobwebs: If you found those references, you also found many that got it right. http://scienceworld.wolfram.com/physics/Slug.html Slugs are units of mass. That's not what I'm calling you on. But that little-used 20th century invention, which didn't even appear in physics textbooks before 1940, are by no stretch of the imagination _the_ units of mass in "the English system." Pounds force also exist, but that's also beside the point. Back up your claim that pounds are not units of mass. That's where you falsely claimed that Dave S. was making an error. -- Gene Nygaard http://ourworld.compuserve.com/homepages/Gene_Nygaard/ "It's not the things you don't know what gets you into trouble. "It's the things you do know that just ain't so." Will Rogers |
Gene Nygaard wrote:
I see that even that wasn't enough to get your attention, Chicolini. OK, you got me there. Haven't a clue who Chicolini is. Should I be insulted? Do you now feel better having insulted me? How big a bat do I need to hit you over the head with to get your attention? Clear, intelligent statements usually work. Besides gently (IMHO) chastising the intervening poster's rant, I still provided a useful answer to the original poster's question (12+ cu. ft.) and a reference to the source. Yes, you got that right. Too bad nobody will pat you on the back for it, (I don't care) because you obscured it with irrelevant nonsense, Irrelevant? Wasn't to me. Nonsense? Um, nope. and even worse, an incorrect claim of error on someone else's part. Perhaps. Uh, 2 years of high school physics (a jillion years ago). Perhaps a few web references will help clear the cobwebs: If you found those references, you also found many that got it right. I just grabbed a few that looked to get to the point quickly. http://scienceworld.wolfram.com/physics/Slug.html Slugs are units of mass. That's not what I'm calling you on. It wasn't clear in your earlier hostile response. But that little-used 20th century invention, which didn't even appear in physics textbooks before 1940, are by no stretch of the imagination _the_ units of mass in "the English system." I'm sorry, you're correct. I didn't mean to imply that they are the only unit of mass. I was taught (perhaps incorrectly) that the unambiguous term for weight (scientific meaning) in the English system was "slugs". Apparently it's also "pounds force" now (it may have been them, too, and I've just forgotten it). Pounds force also exist, but that's also beside the point. sarcasm Whew. Glad we're past that. /sarcasm Back up your claim that pounds are not units of mass. That's where you falsely claimed that Dave S. was making an error. Actually, I intended only to claim that Dave S. incorrectly stated mass when he should have stated weight. From my perspective, the respondent about whom Dave S. was complaining clearly intended "lbs" as a unit of weight. The reference to the slug as the English mass unit was only intended as an offhand remark. Pounds are units of mass in casual (non-technical) conversations, and probably shorthand for "pounds force" in technical conversations. For the record, I don't claim that slugs are the only unit of mass in the English system, and I'm sorry to have inadvertantly made that implication. Russell Kent |
Russell Kent wrote in :
Back up your claim that pounds are not units of mass. That's where you falsely claimed that Dave S. was making an error. Actually, I intended only to claim that Dave S. incorrectly stated mass when he should have stated weight. From my perspective, the respondent about whom Dave S. was complaining clearly intended "lbs" as a unit of weight. Gene is correct, although mass and weight are equal in the same environment (i.e. good ole earth gravity) so really correcting someone on that is akin to correcting spelling mistakes on use-net.... kind of useless. Lbs IS a measure of mass (to us "common" folk) IFF acceleration is either identified or implied. i.e. My mass is 195lbs at earth sea level. Most people would say then mass = weight and weight = mass. BUT I would say most of us have had experience where that is not true. If you've traveled on an airplane... or ... perhaps flown one grin, the acceleration factor has been at least momentarily increased or decreased... with maneuvering... so even though you weigh 200lbs before the you stepped into the plane, when you banked into that 30 degree turn, you probably weighed something like 250+, but your mass never changed.... When I took physics, mass was measured in a.u.'s & I have no idea what the a stands for, and I think the u just meant "unit" Although I beleive the correction was a bit petty... The hostle response was a bit uncalled for, especially since Gene was correct. Here is a good link that explains: http://www.nyu.edu/pages/mathmol/tex...ightvmass.html ET "A common mistake people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools."---- Douglas Adams |
Russell Kent wrote in message ...
I'm sorry, you're correct. I didn't mean to imply that they are the only unit of mass. I was taught (perhaps incorrectly) that the unambiguous term for weight (scientific meaning) in the English system was "slugs". Apparently it's also "pounds force" now (it may have been them, too, and I've just forgotten it). I think you mistyped. 'Slugs' are unambiguously a unit of mass. Pounds are ambiguously a unit of force. Ambiguity exists because it is popular in some disciplines to use a unit of mass defined (loosely) as that mass which weighs one pound. But you knew that. -- FF |
Fred the Red Shirt wrote:
Russell Kent wrote in message ... I'm sorry, you're correct. I didn't mean to imply that they are the only unit of mass. I was taught (perhaps incorrectly) that the unambiguous term for weight (scientific meaning) in the English system was "slugs". Apparently it's also "pounds force" now (it may have been them, too, and I've just forgotten it). I think you mistyped. 'Slugs' are unambiguously a unit of mass. Oy. You are correct, sir. Pounds are ambiguously a unit of force. Ambiguity exists because it is popular in some disciplines to use a unit of mass defined (loosely) as that mass which weighs one pound. But you knew that. Ibid. :-) Russell Kent |
Similar Threads | ||||
Stearman for rent in Bay Area | John Harper | Aerobatics | 7 | April 5th 04 07:20 AM |
Where can one get aerobatic training in the seattle area? | SeattleFlyer | Aerobatics | 1 | January 22nd 04 02:56 AM |
