T-6 accident
Old November 18th 07, 08:12 AM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
Default T-6 accident
This is the one I mean to post Dudley. Was having some trouble with Youtube
due to a plug-in I think.. http://www.youtube.com/watch?v=Y7eYhlm9FJ8
Old November 18th 07, 01:32 PM posted to rec.aviation.piloting
WJRFlyBoy
Can you assess the problem?
Remove numbers for gmail and for God's sake it ain't "gee" either!
Old November 18th 07, 01:51 PM posted to rec.aviation.piloting
WJRFlyBoy wrote in
Youtube due to a plug-in I think..
What, with my browser or the accident?
The T-6 passed 90 deg (and even earlier) with his nose below the horizon.
He could have rolled back and saved it at that point, but he continued
around in the now awkward position of having to prevent further altitude
loss with excessive neg G which slowed him considerably and further skewed
the airplane's. The exit half was a classic dish. Everybody does 'em
sometimes.... Trick is to recognise a roll that's going to produce one
early enough to abandon it. This guy didn't.
The You tube extension add-on, I have no idea, but it's made a mess out of
my youtube fun!
Bertie
Old November 18th 07, 08:22 PM posted to rec.aviation.piloting
Big John
On Sun, 18 Nov 2007 13:51:53 +0000 (UTC), Bertie the Bunyip
WJRFlyBoy wrote in
my youtube fun!
Bertie
Bertie
I made some comments on another post on this accident which was before
the video of the accident was posted.
I have looked at the strip probably 50 times and can't come up with
what I believe is a accurate analysis of what all happened and why.
1. Bird was in a shallow dive and picking up airspeed, above cruise,
when strip starts. This is a good entry technique.
2. Bird bottomed out and nose was raised above the horizon before roll
started. Again good technique.
3. After first 90 degrees of roll nose had dropped to at least level
or very slightly nose down.
4. After 180 degrees of roll nose was definitely below the horizon.
Not in a dive but shallow enough that continuing roll rate should have
allowed completion of roll before bird hitting ground.
5. After 270 degrees of roll bird made almost a square corner port
turn and shortly after hit the ground almost flat 90 degrees off line
of flight.
6. It did not look to me like he dished out but I don't know why the
bird made the rapid 90 degree turn off line of flight. My experience
with dish out of roll, in T-6, bird ended up at max 30 degrees off
line of flight.
7. Assuming video strip was real time, the roll was a pretty rapid
slow roll. My slow rolls were about half the roll rate of this bird.
8.Roll was against torque, which would have slowed roll down without
extra aileron.
9.Either you or Dudley talked about G forces slowing bird down. I
didn't see any large angle of attack which would be required to slow
bird down.
10. Looking at bird in video, I didn't see any reduction in airspeed
until about the time it made the 90 degree turn before impact.
Lots of comments but can't give a hard analysis of what happened from
start to finish.
Big John
Old November 18th 07, 08:37 PM posted to rec.aviation.piloting
Kyle Boatright
"Big John" wrote in message
WJRFlyBoy wrote in
t:
my youtube fun!
Bertie
Bertie
of flight.
Is there any evidence that he fed in pro-roll rudder in addition to some
elevator? That would explain both the nose dropping during the roll and the
rather abrupt course change.
line of flight.
extra aileron.
bird down.
start to finish.
Big John
Old November 18th 07, 08:48 PM posted to rec.aviation.piloting
"Kyle Boatright" wrote in
WJRFlyBoy wrote in
with Youtube due to a plug-in I think..
horizon. He could have rolled back and saved it at that point, but he
continued around in the now awkward position of having to prevent
further altitude loss with excessive neg G which slowed him
considerably and further skewed the airplane's. The exit half was a
classic dish. Everybody does 'em sometimes.... Trick is to recognise
a roll that's going to produce one early enough to abandon it. This
guy didn't.
out of my youtube fun!
Bertie
Bertie
before the video of the accident was posted.
roll started. Again good technique.
have allowed completion of roll before bird hitting ground.
of flight.
some elevator? That would explain both the nose dropping during the
roll and the rather abrupt course change.
doubt it or he would have turned into the ground pretty quickish. just
not enough top rudder would be my guess.
Bertie
Old November 18th 07, 08:47 PM posted to rec.aviation.piloting
Big John wrote in
WJRFlyBoy wrote in
t:
classic dish. Everybody does 'em sometimes.... Trick is to recognise a
roll that's going to produce one early enough to abandon it. This guy
didn't.
Bertie
Bertie
of flight.
line of flight.
extra aileron.
bird down.
start to finish.
OK, it's kind of hard to see it in relation to he horizon for a lot of
the roll. My own feeling is the nose was down too far during the first
quarter and then he was well to nose low during the inverted portion and
knew it, pushed hard and drew some drag, then panicked and tried to get
out with hard top rudder too early and pulled hard as soon as he passed
90 deg roll on the back side. It's been a while, but it;s a classic
student panic recovery from a botched roll.
Bertie
Old November 20th 07, 02:50 AM posted to rec.aviation.piloting
Bela P. Havasreti[_2_]
On Sun, 18 Nov 2007 14:22:58 -0600, Big John
WJRFlyBoy wrote in
t:
my youtube fun!
Bertie
Bertie
of flight.
line of flight.
extra aileron.
bird down.
start to finish.
Big John
If I recall correctly, the pilot of the accident aircraft borrowed
that T-6 for the accident flight (his T-6 was down for maintenance,
something like that...). The story went that his T-6 had the "high
throw" aileron bellcranks, but the borrowed / accident T-6 did not.
Bela P. Havasreti
Old November 20th 07, 03:32 AM posted to rec.aviation.piloting
Dudley Henriques[_2_]
WJRFlyBoy wrote in
my youtube fun!
Bertie
Bertie
of flight.
line of flight.
extra aileron.
bird down.
start to finish.
Big John
Bela P. Havasreti
The 6 had 2 choices of bell cranks on the ailerons. One was a 29up/15
down and the other a straight 15/15 if I recall.
If the accident pilot was used to the roll rate and roll inertia
resulting from a roll set initiated at his usual entry airspeed
(aileron dynamic pressure) and rolled the borrowed aircraft with the
asymmetrical aileron setup this could possibly explain a great deal to
me as a display pilot.
For a given airspeed, the aileron drag produced by the 29/15 setup would
not have been what he was instinctively expecting and that could easily
have spooked him as the roll commenced causing the control
mis-application and confusion that seemed obvious from the crash.
Dudley Henriques
Old November 18th 07, 09:26 PM posted to rec.aviation.piloting
WJRFlyBoy
On Sun, 18 Nov 2007 13:51:53 +0000 (UTC), Bertie the Bunyip wrote:
WJRFlyBoy wrote in
lol
I later saw your post equipment failure.
my youtube fun!
Bertie
Orbit Downloader
A Sad Accident RL Anderson Piloting 29 October 20th 07 08:14 PM
F6F accident Larry Cauble Naval Aviation 4 October 14th 05 06:19 PM
C-130 accident Jay Honeck Piloting 28 January 11th 05 06:52 PM
MU2 accident Big John Piloting 16 April 13th 04 03:58 AM
KC-135 accident Big John Piloting 3 November 19th 03 04:36 PM
