Marvel carb on C-75--data needed
Old March 24th 06, 06:13 PM posted to rec.aviation.owning
Default Marvel carb on C-75--data needed
I would like to replace my Stromberg with a Marvel carb on my C-75 so I
can have a mixture control that actually works and can maybe get away
from a needle valve that has an unstopable leak.
Have called Precision and Continental and neither can give me a
reference showing where this carb is approved for the C-75-8, even
though Precision shows a carb number for it.
Does anyone out there have a Marvel on a C-75-8? Do you have the 337
paperwork approving it? Can you give me a copy?
Lastly, would such a change be aircraft type specific, requiring me to
find someone with the same carb on my type of aircraft (Interstate
Cadet) or is it just an engine mod?
Thanks
Old March 24th 06, 07:01 PM posted to rec.aviation.owning
Thanks
The TCDS shows the Marvel part numbers that can be used on the C-75-8 so you
are good to go IF you can find the particular Marvel part listed in the
TCDS. Not all Marvel MA3-SPAs are the same. The TCDS is available on the
FAA web site. It would be a good idea to check the TCDS for the Cadet also.
Old March 25th 06, 03:05 AM posted to rec.aviation.owning
They are very prized pocessions, highly desired, rare and difficult to
find.
Old March 26th 06, 03:17 AM posted to rec.aviation.owning
Only the Stromberg is listed on the type cert for the C-75-8.
Old March 26th 06, 06:27 AM posted to rec.aviation.owning
Look again. A Marvel is listed.
Old March 26th 06, 06:37 AM posted to rec.aviation.owning
Ignore my other posts.............
You are right the -8 is only approved for a Stromberg.
Old March 27th 06, 04:33 AM posted to rec.aviation.owning
On Sun, 26 Mar 2006 05:37:54 GMT, "Dave Stadt"
On the copy I'm looking at E-213 Rev. 9, it sure looks like either
carb is approved.
http://www.airweb.faa.gov/Regulatory_and_Guidance_Library/rgMakeModel.nsf/0/546b3ba8256c6dd58525670e004419ba/$FILE/E-213.pdf
TC
Old March 27th 06, 12:42 PM posted to rec.aviation.owning
On Mon, 27 Mar 2006 04:46:07 GMT, "Dave Stadt"
He said it was a C75-8 not an A75-8. Need to look at E-233.
DOH
GAO: Electronic Warfa Comprehensive Strategy Needed for Suppressing Enemy Mike Naval Aviation 0 December 27th 05 06:23 PM
Garmin data card needed Marty from Florida Owning 0 December 14th 05 03:51 PM
GEM-610 data download info needed [email protected] Owning 9 October 22nd 05 10:55 PM
Ice meteors, climate, sceptics Brian Sandle General Aviation 43 February 24th 04 12:27 AM
