Dg400 rigging tips
Guys, I'm a new DG400 owner, and was wondering if there are any tips or suggestions that others have learned to help rigging. My ship came with an electric self rigger with remote, and the first time I used it I got the wings on with little problem. Today was a different story, not only did it take considerable time to get the wings in, but than I fought the spar pins for a while before throwing in the towel, figuring it just wasn't my day! Any suggestions?
Thanks, Steve Cameron |
Dg400 rigging tips
1) Pay attention to how high the main tire is above the ground (while on the cradle) before you start. I noticed that if the tire is less than or equal to 1.5 inches from the ground, wing install goes better. If the fuselage is higher than that (2+ inches), it goes badly. I'm not sure why. I think the extra pitch up attitude of the nose causes a tortional misalignment that requires more force to overcome. I would have thought that once the wings were flush with the fuselage seated in the lift pins then the tortional orientation couldn't be an issue. Anyway, by simply lowering the cradle to get the tire closer to the ground almost always fixed my problem - even though there was no apparent change in the wing gaps and hole alignments.
2) Use your "eyes" to align the spar holes first. If you can 'see' a misalignment, there is no amount of force you can apply to the pin to fix it. 3) If you see a misalignment of the spar holes in the vertical direction (so the assumption here is that the wings are tight against the fuselage and the fore/aft alignment is good), I have found that raising or lowering the CRADLE did a better job of aligning the holes than to raise or lower one of the wings. When you go out to the wing tip and "fix" wing height, you almost always cause the wing to pull out slightly or cause a misalignment fore/aft at the root (so you fixed one problem, but created one or two others). (This will be less of an issue for you with the electric rigger). However, using the cradle doesn't cause that problem at all, it is the ultimate fine adjustment knob. I like to assemble my wings so that the fuselage is a smidge too high when the wings are in, such that I have to lower the cradle to fix the gap. Because both wing roots are being lowered, gravity is helping keep the wings nice an tight against the fuselage as the cradle lowers. Hope that made sense. |
Dg400 rigging tips
On Tuesday, February 27, 2018 at 2:56:26 PM UTC-8, Steve Cameron wrote:
Guys, I'm a new DG400 owner, and was wondering if there are any tips or suggestions that others have learned to help rigging. My ship came with an electric self rigger with remote, and the first time I used it I got the wings on with little problem. Today was a different story, not only did it take considerable time to get the wings in, but than I fought the spar pins for a while before throwing in the towel, figuring it just wasn't my day! Any suggestions? Thanks, Steve Cameron I have a a DG-200 with short lift pins. Putting the first wing in I have to put the rear pins in first. I made a cam tool to hold the wing in place so putting in the left wing doesn't knock the right wing out. I don't think this is an issue with later models. With the first (right) wing in the spar stub is not centered but low in the opposite side opening. After putting the second wing in place, rear lift pins first again, if the mains pin holes don't line up I push or pull on the fin to twist the fuselage to change the misalignment of the holes. (my trailer has a fixed height on the cradle.) I also have a cam tool to pull the main pin holes into alignment. In the past I made and sold these tools. They are now should be available from MM Fabrication https://www.mmfabrication.com/ Hope this helps, Steve 450+ DG-200 assemblies |
Dg400 rigging tips
Steve, Congrats on your new DG-400 -- wonderful glider, and to me, the real "sweet spot" in the price/performance continuum for self-launchers. I have DG-400 No. 150 from 1985 and assemble alone with a home-built rigger. Dirk's points above, especially numbers 2 and 3 are spot on. The other thing that is critical when putting the wings on is that the gap between wing root and fuselage is parallel -- I use a couple of fingers inserted into this gap as a visual gauge, then adjust the wing fore or aft to get the gap even. If this is even slightly off, it displaces the lift pins relative to their sockets and the wing won't join up. I put the right wing on first, then tape the gap on the top surface, leaving the roll hanging so I can finish taping the underside of the wing later. This keeps the wing from sliding out while I'm installing the left wing. Like Dirk, I then use the manual crank on my ramp to adjust the height of the fuselage, until the spar holes on one side are visually aligned. When I have this right, the pin slides in smoothly without any significant force. Then I go back to the crank and change the fuse height until the other pair of spar holes are aligned, and insert the other pin. You will learn to recognize when it all looks just right, and I prefer to take a few more moments to get it right visually than to try to force things. While you are securing the pins, check the soundness of the small spring-loaded pins that lock the handles into place: there's been an instance of one of these failing, resulting in a spar pin working it's way out during flight.
The Yahoo Group "DG Owners" is the main online resource for owners of 400's and 800's and there is a real "brain trust' there, eager to help out -- I can't recommend it too highly. Enjoy! Paul Villinski, NYC |
Dg400 rigging tips
Guys, I'm a new DG400 owner, and was wondering if there are any tips or suggestions that others have learned to help rigging. My ship came with an electric self rigger with remote, and the first time I used it I got the wings on with little problem. Today was a different story, not only did it take considerable time to get the wings in, but than I fought the spar pins for a while before throwing in the towel, figuring it just wasn't my day! Any suggestions? Thanks, Steve Cameron The key to easy assembly of the 400 is alignment - if the wings are out of alignment no amount of pushing, hammering or swearing is going to get the spar pins in. As Paul mentioned, the wings need to be parallel to the fuselage, but that is not the only factor. The wing dihedral must also be correct.. You can check this by looking at the gap between the wing root and the fuse: it must be the same on the top and bottom. If it isn't, raise or lower the wing to get it the same (you can also raise or lower the fuselage, but only for the first wing). Just because the wing gap looks on the top side doesn't mean that the vertical (dihedral) is correct: you must also look on the bottom side. Once both wings are in the gaps look good, I check spar bushing alignment be my special feeler gauge tool: my finger. Of course, you will be able to see gross misalignments visually, but this will not get you the whole way. If they have even the slightest misalignment, you will be able to feel it with your finger. Just rub it back and forth over the joint. What needs correction depends upon where you feel a misalignment. If it is on the sides of the bushing, one of the wings (or both) need a fore/aft correction. If it is on the top or bottom, one or both of the wings need a vertical adjustment. The first time you go thru this just pick a direction and see if it makes the gap better or worse; if worse you went the wrong way. I showed this method to another 400 owner who was having a similar experience to yours. He said he had his pins dripping in grease and they still wouldn't go in. I had him go thru this procedure with my dry pins and, once everything was in alignment, the pins slid in with next to no effort. Tom |
Dg400 rigging tips
One thing i always suggest when a glider is difficult to rig is to clean
and regrease the pins and their fittings. I've seen people struggling for ages, they do that and everything just slips together. Chris At 05:15 28 February 2018, 2G wrote: On Tuesday, February 27, 2018 at 2:56:26 PM UTC-8, Steve Cameron wrote: Guys, I'm a new DG400 owner, and was wondering if there are any tips or s= uggestions that others have learned to help rigging. My ship came with an e= lectric self rigger with remote, and the first time I used it I got the win= gs on with little problem. Today was a different story, not only did it tak= e considerable time to get the wings in, but than I fought the spar pins fo= r a while before throwing in the towel, figuring it just wasn't my day! An= y suggestions? Thanks, Steve Cameron The key to easy assembly of the 400 is alignment - if the wings are out of = alignment no amount of pushing, hammering or swearing is going to get the s= par pins in. As Paul mentioned, the wings need to be parallel to the fusela= ge, but that is not the only factor. The wing dihedral must also be correct= .. You can check this by looking at the gap between the wing root and the fu= se: it must be the same on the top and bottom. If it isn't, raise or lower = the wing to get it the same (you can also raise or lower the fuselage, but = only for the first wing). Just because the wing gap looks on the top side d= oesn't mean that the vertical (dihedral) is correct: you must also look on = the bottom side. Once both wings are in the gaps look good, I check spar bushing alignment b= e my special feeler gauge tool: my finger. Of course, you will be able to s= ee gross misalignments visually, but this will not get you the whole way. I= f they have even the slightest misalignment, you will be able to feel it wi= th your finger. Just rub it back and forth over the joint. What needs correction depends upon where you feel a misalignment. If it is = on the sides of the bushing, one of the wings (or both) need a fore/aft cor= rection. If it is on the top or bottom, one or both of the wings need a ver= tical adjustment. The first time you go thru this just pick a direction and= see if it makes the gap better or worse; if worse you went the wrong way.= =20 I showed this method to another 400 owner who was having a similar experien= ce to yours. He said he had his pins dripping in grease and they still woul= dn't go in. I had him go thru this procedure with my dry pins and, once eve= rything was in alignment, the pins slid in with next to no effort. Tom |
Dg400 rigging tips
I have owner a number of DG gliders including a DG400 and never have
any problems... As Chris said, make sure its well greased, then fit one wing in place and adjust the tip height to make sure the spar tip is relatively central as it emerges from the other height. You can get a tool on some of the DG's to keep that wing in place whilst you fit the other wing... The next bit is key... Ask the person on the wing he is holding to lift or lower so that the opposite hole is about lined up and push that main pin as far in as it will go... it probably won't go in fully, but don't worry... THEN look at the other hole and ask him to again raise or lower his tip until it is lined up and put the second pin in... with brief minor adjustments it will go straight in... As you do so, push in the center of the pin with one hand whilst rotating the handle a bit with the other. Once that pin is in, you will find that the other pin will then push straight in also... It works... I have been doing it this way on DG202, DG400, DG800 and now DG808 for 28 years..!.. Craig At 08:15 28 February 2018, Chris Rowland wrote: One thing i always suggest when a glider is difficult to rig is to clea and regrease the pins and their fittings. I've seen people struggling fo ages, they do that and everything just slips together. Chris At 05:15 28 February 2018, 2G wrote: On Tuesday, February 27, 2018 at 2:56:26 PM UTC-8, Steve Cameron wrote: Guys, I'm a new DG400 owner, and was wondering if there are any tips or s= uggestions that others have learned to help rigging. My ship came with an e= lectric self rigger with remote, and the first time I used it I got the win= gs on with little problem. Today was a different story, not only did it tak= e considerable time to get the wings in, but than I fought the spar pins fo= r a while before throwing in the towel, figuring it just wasn't my day! An= y suggestions? Thanks, Steve Cameron The key to easy assembly of the 400 is alignment - if the wings are ou of = alignment no amount of pushing, hammering or swearing is going to get the s= par pins in. As Paul mentioned, the wings need to be parallel to the fusela= ge, but that is not the only factor. The wing dihedral must also be correct= .. You can check this by looking at the gap between the wing root and the fu= se: it must be the same on the top and bottom. If it isn't, raise o lower = the wing to get it the same (you can also raise or lower the fuselage but = only for the first wing). Just because the wing gap looks on the top side d= oesn't mean that the vertical (dihedral) is correct: you must also loo on = the bottom side. Once both wings are in the gaps look good, I check spar bushing alignment b= e my special feeler gauge tool: my finger. Of course, you will be able to s= ee gross misalignments visually, but this will not get you the whole way. I= f they have even the slightest misalignment, you will be able to feel it wi= th your finger. Just rub it back and forth over the joint. What needs correction depends upon where you feel a misalignment. If i is = on the sides of the bushing, one of the wings (or both) need a fore/aft cor= rection. If it is on the top or bottom, one or both of the wings need a ver= tical adjustment. The first time you go thru this just pick a direction and= see if it makes the gap better or worse; if worse you went the wron way.= =20 I showed this method to another 400 owner who was having a similar experien= ce to yours. He said he had his pins dripping in grease and they still woul= dn't go in. I had him go thru this procedure with my dry pins and, once eve= rything was in alignment, the pins slid in with next to no effort. Tom |
Dg400 rigging tips
On Tuesday, February 27, 2018 at 8:47:49 PM UTC-5, Dirk_PW wrote:
1) Pay attention to how high the main tire is above the ground (while on the cradle) before you start. I noticed that if the tire is less than or equal to 1.5 inches from the ground, wing install goes better. If the fuselage is higher than that (2+ inches), it goes badly. I'm not sure why. I think the extra pitch up attitude of the nose causes a tortional misalignment that requires more force to overcome. I would have thought that once the wings were flush with the fuselage seated in the lift pins then the tortional orientation couldn't be an issue. Anyway, by simply lowering the cradle to get the tire closer to the ground almost always fixed my problem - even though there was no apparent change in the wing gaps and hole alignments. 2) Use your "eyes" to align the spar holes first. If you can 'see' a misalignment, there is no amount of force you can apply to the pin to fix it. 3) If you see a misalignment of the spar holes in the vertical direction (so the assumption here is that the wings are tight against the fuselage and the fore/aft alignment is good), I have found that raising or lowering the CRADLE did a better job of aligning the holes than to raise or lower one of the wings. When you go out to the wing tip and "fix" wing height, you almost always cause the wing to pull out slightly or cause a misalignment fore/aft at the root (so you fixed one problem, but created one or two others).. (This will be less of an issue for you with the electric rigger). However, using the cradle doesn't cause that problem at all, it is the ultimate fine adjustment knob. I like to assemble my wings so that the fuselage is a smidge too high when the wings are in, such that I have to lower the cradle to fix the gap. Because both wing roots are being lowered, gravity is helping keep the wings nice an tight against the fuselage as the cradle lowers. Hope that made sense. Dirk, thank for yours & others comments, I'll see how thing go this weekend.. I had also gotten into the habit of having the main extended, and very close to the ground, but not touching. Several times yesterday while fighting to get the wings in I noticed the main had lowered to the ground, so it seems I've got a hydraulic foot pump that doesn't quite hold pressure. Because of this it makes sense to me to begin rigging with the fuselage and cradle in its lowest position, so at least I'm starting from a consistent position. I have used self riggers in the past, and a good friend suggested it will take some time to learn the right positioning, etc. Steve |
Dg400 rigging tips
On Wednesday, February 28, 2018 at 4:41:12 AM UTC-8, Steve Cameron wrote:
On Tuesday, February 27, 2018 at 8:47:49 PM UTC-5, Dirk_PW wrote: 1) Pay attention to how high the main tire is above the ground (while on the cradle) before you start. I noticed that if the tire is less than or equal to 1.5 inches from the ground, wing install goes better. If the fuselage is higher than that (2+ inches), it goes badly. I'm not sure why. I think the extra pitch up attitude of the nose causes a tortional misalignment that requires more force to overcome. I would have thought that once the wings were flush with the fuselage seated in the lift pins then the tortional orientation couldn't be an issue. Anyway, by simply lowering the cradle to get the tire closer to the ground almost always fixed my problem - even though there was no apparent change in the wing gaps and hole alignments. 2) Use your "eyes" to align the spar holes first. If you can 'see' a misalignment, there is no amount of force you can apply to the pin to fix it. 3) If you see a misalignment of the spar holes in the vertical direction (so the assumption here is that the wings are tight against the fuselage and the fore/aft alignment is good), I have found that raising or lowering the CRADLE did a better job of aligning the holes than to raise or lower one of the wings. When you go out to the wing tip and "fix" wing height, you almost always cause the wing to pull out slightly or cause a misalignment fore/aft at the root (so you fixed one problem, but created one or two others). (This will be less of an issue for you with the electric rigger). However, using the cradle doesn't cause that problem at all, it is the ultimate fine adjustment knob. I like to assemble my wings so that the fuselage is a smidge too high when the wings are in, such that I have to lower the cradle to fix the gap. Because both wing roots are being lowered, gravity is helping keep the wings nice an tight against the fuselage as the cradle lowers. Hope that made sense. Dirk, thank for yours & others comments, I'll see how thing go this weekend. I had also gotten into the habit of having the main extended, and very close to the ground, but not touching. Several times yesterday while fighting to get the wings in I noticed the main had lowered to the ground, so it seems I've got a hydraulic foot pump that doesn't quite hold pressure. Because of this it makes sense to me to begin rigging with the fuselage and cradle in its lowest position, so at least I'm starting from a consistent position. I have used self riggers in the past, and a good friend suggested it will take some time to learn the right positioning, etc. Steve I forgot a couple of things: 1. You can use the position of the spar butt to judge the dihedral of the wing by its position on the opposite side of the spar tunnel. Nominally, it will have an equal gap between the top and bottom of the tunnel, but you can mark the actual position immediately after pulling the pins (I use some wing tape & a permanent marker). 2. Often times you will get a single pin in, only to find the second pin needs some vertical adjustment. Do this with the fuselage jack. While it is always a good idea to grease the pins, doing this WILL NOT solve a misalignment problem. When you assemble with helpers, they can just wiggle the wing tips until they randomly find the correct alignment. This method WILL NOT work when you self-assemble, you MUST be methodical and have a procedure where you can detect what is out of alignment and correct it. Tom |
Dg400 rigging tips
All the above suggestions are great.
Having everything you can in the same position each time, wing stand marked at perfect height, and same position on the wing, cradle at the same height, ...... Also the R wing first, as it sits in the back of the spar box, if you start with the left the spar wants to side back. When inserting the left wing, as the spar is going in, you have to pull the spar initially forward a little by opening the canopy. This keeps the bushings from hitting. ( the spars are not smooth, the bushings are sticking out.) If you do not do this then you can push out the second wing quite easily. This in also one area where the fore aft alignment of the wing comes into play, because if it is off the bushings will also rub. I don't have electric, but I have replaced the gas strut in my rigger, so I can go out to the tip and raise and lower the wing myself easily, and it will stay in that position. Your electric rigger should be great for this,. Use this method for getting the wings in, but then as others have noted, make fine adjustments by raising and lowering the cradle. I start with the cradle high, and then lower to get final alignment. Hope this helps. Kevin Anderson 92 DG 400 146 |
Similar Threads | ||||
Thinking about buying a DG400 | [email protected] | Soaring | 29 | June 1st 17 10:34 PM |
ASG-32 Mi rigging aid | [email protected] | Soaring | 3 | June 8th 16 04:22 PM |
Lak 12 rigging | Colin Roney | Soaring | 6 | September 14th 12 02:51 PM |
Pocket PC Tips & Glide Navigator II Tips | Paul Remde | Soaring | 0 | December 14th 04 08:21 PM |
