Cambridge 302 question
Old January 23rd 20, 11:00 AM posted to rec.aviation.soaring
Default Cambridge 302 question
Hello Guys. I am restoring another 1-26 and have a spare older 302 I would like to use. Have any of you used that vario without the external TE probe, setting it to the internal compensation mode? The manual for it does’nt recommend it but I would like to save the bother and drag associated with installing an external probe.
I use a 302 with external TE in my other machine and it works great but have never experimented with the internal compensation setting. Any shared experience comments sure welcomed.
Old January 23rd 20, 11:50 AM posted to rec.aviation.soaring
JS[_5_]
I remember it working fine on electronic TE.
Refer to the manual for pneumatic connections and TE compensation setup.
Old January 23rd 20, 12:20 PM posted to rec.aviation.soaring
Tango Eight
Works fine if you have high quality, unshared, co located pitot and static (e.g. triple probe) sources. With typical 1-26 sources, not so much.
I suggest using TE probe.
T8
Old January 23rd 20, 02:57 PM posted to rec.aviation.soaring
I have a 302 in my Libelle that is set at 100% electronic compensation. Right beside it I have a Borgelt B40 that is connected to my TE probe. There is little if any difference between the two. I absolutely believe you'll be happy with the 302 and pure electronic compensation.
Robert
Old January 23rd 20, 02:58 PM posted to rec.aviation.soaring
Dan Daly[_2_]
There was a Johnson report, "DEVELOPMENT OF A TOTAL ENERGY SYSTEM FOR THE PW-5 SAILPLANE By Richard H. Johnson, Published in Soaring Magazine, April 1998" which describes a simple fuselage-mounted short TE probe that worked well. It includes instructions for building your own probe. It should be in the SOARING archive.
Old January 23rd 20, 03:34 PM posted to rec.aviation.soaring
MNLou
I use a 302 with electronic compensation as a back up vario and find it works just fine.
This is especially true when I have the sustainer engine running. The engine seems to affect the T/E probe for my other vario and causes it to be a little wild.
Lou
Old January 23rd 20, 06:38 PM posted to rec.aviation.soaring
Tim Taylor
I have used the 302 as my back-up logger and vario on electric compensation only. I run my other vario on TE and see very little difference. If I have a TE failure it is nice to know the 302 will work well.
Old January 23rd 20, 06:51 PM posted to rec.aviation.soaring
Thanks for all the comments guys, sure appreciate it. Not having to deal with mounting the TE probe for the 302 lightens my load of restoration chores lol.
Dan
Cambridge 302 question Mark Olinger Soaring 4 February 28th 19 05:52 PM
Question on Cambridge 302/Glide Nav 2 combo JimF Soaring 2 November 29th 13 12:16 AM
Cambridge 302 Question [email protected] Soaring 15 April 20th 09 07:46 PM
Cambridge 303 Display Question Tim Hanke Soaring 1 April 20th 09 04:13 PM
Cambridge Fuse Question Brian Iten Soaring 9 January 4th 05 02:43 PM
