IO 470 Fouled Plug
Old January 28th 06, 02:10 AM posted to rec.aviation.owning
Default IO 470 Fouled Plug
My engine analyzed is telling me that the spark plug on the #6
cylinder, left mag is fouled. I have a new plug, but can't tell which
cylinder #6 is and whether it's the plug on the top or the bottom....
Can anyone tell me which plug it is...?
Thanks much,
Anthony
Old January 28th 06, 03:30 AM posted to rec.aviation.owning
Number 6 is the rearmost cylinder. Trace the wires to work out which plug is
connected to the left mag.
George Patterson
Coffee is only a way of stealing time that should by rights belong to
your slightly older self.
Old January 28th 06, 04:29 AM posted to rec.aviation.owning
In article YyBCf.1306$Ix.796@trnddc07,
George Patterson
I have an old Continental Operators's handbook (for the E-225 series),
which shows #1 as rifgt rear, #6 is left front. I doubt that Continental
has changed their numbering system on the O-470 series.
On a Lycoming, #1 is right front; #6 is left rear.
Remve "_" from email to reply to me personally.
Old January 28th 06, 04:56 AM posted to rec.aviation.owning
According to my A&P at the time, right front was #1 on my Continental O-200.
George Patterson
Old January 28th 06, 05:01 AM posted to rec.aviation.owning
"George Patterson" wrote in message
news:mQCCf.13187$K17.13085@trnddc03...
O-200.
George Patterson
Right rear is #1 on an O-200. Left front is #4.
Old January 28th 06, 05:17 AM posted to rec.aviation.owning
"Prooving" that on different engines there are different numbering
schemes.
Old January 28th 06, 01:40 PM posted to rec.aviation.owning
O-200.
Lycomings have the numbers stamped right in the engine case. Don't
Continentals?
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old January 28th 06, 01:44 PM posted to rec.aviation.owning
"Jay Honeck" wrote in message
news:hvKCf.517589$084.337062@attbi_s22...
O-200.
Continentals?
Jay Honeck
Iowa City, IA
Pathfinder N56993
Yes, they are cast into the case.
Old January 28th 06, 07:17 PM posted to rec.aviation.owning
Page A-3-1 of the Continental O-470 Maintenance Manual: #6 cylinder is the
front port side cylinder. As Michelle said, it is the most forward of the
six cylinders and is directly on the OPPOSITE side of the engine from the
oil cooler.
Looking at the O-470 engine from the top:
Prop Flange
Oil Cooler
6
5
4
3
2
1
Magnetos
What's this "left" and "right" stuff from you old geezers? You no speaka da
port and starboard likea you teacher done taught you? Left and right swap
sides depending on which end of the engine you are looking at.
Me? I'd pull the bottom plug for inspection first. 99/100 of the time
that's the fouled one.
news:YyBCf.1306$Ix.796@trnddc07...
is connected to the left mag.
George Patterson
Old January 28th 06, 04:24 AM posted to rec.aviation.owning
I think that the cylinders are numbered on the intake manifold. THe
number is cast right into the manifold. Also, I believe that the bottom
plugs are the ones that tend to foul. Did you try to do a lean runup to
try and "un-foul" the plug? I have had good luck doing that.
Jon Kraus
'79 Mooney 201
4443H @ TYQ
Thanks much,
Anthony
Fouled plug IO 470 [email protected] General Aviation 7 January 29th 06 06:03 PM
Plug fouled Denny Owning 9 September 2nd 05 05:58 AM
Plug replacements for O-360-A3A [email protected] Owning 3 August 20th 05 10:39 PM
ICOM Headset Adaptor Plug Ron Wanttaja Home Built 3 June 2nd 05 07:54 AM
Clearing a fouled plug Roger Long Piloting 3 July 6th 04 05:53 AM
