Ack! My ACK!
Am wondering if there's a design flaw in the ACK E-01 ELT or just an anomaly?
Our unit went off by itself today because the battery in the remote panel mount indicator died, triggering the ELT, and I'd like to know if anyone else has had this happen? If a dying battery in the remote ***always*** sets off the ELT, then this is a design flaw. Everyone's ACK will eventually false alarm if the remote battery isn't replaced on time. (And you know how we are with smoke detectors...) Hmmm... maybe this explains all the false alarms CAP complains about? ----------------------------------------------- I got a call from the airport today. They said the ELT from our plane in the hangar was transmitting as of this morning. That's strange. We last flew a few days ago. No ELT then. (The landings haven't been THAT hard.) What could've happened? In disbelief, I drove to the hangar, expecting this to be a false report. (Not even sure how they could receive a signal, since the hangar makes a pretty good shield. Turns out the CAP hangar is nearby, and they picked it up as they taxied by.) I unlocked the plane, and checked the panel indicator for the ELT. No flashing LED showing activation. I punched the "Reset" button anyway. And then I punched the "On" button. Hmmm... no flashing LED. So I pulled out the handheld, and tuned 121.5. Sure enough, there was an ELT signal, loud and clear. I hit the hard switch on our ACK, and that stopped it. I pulled the remote, and sure enough, the 6v Lithium battery is down to 2v. I'd like to know if anyone else had this same problem, where a dying battery in the panel remote triggers the ELT? It could simply be an anomaly. But if a sizeable number of you have had this happen, then it's a design flaw. But you might not know it happened if someone doesn't alert you that your ELT has triggered. If the CAP wasn't nearby, I suspect our ELT would have drained itself down to zero, and I would have blissfully flown around for the next year (time to annual) thinking the ELT was functional. (It's not like there's a "Checklist" item, to test the ELT before every flight. But in light of this I think I'll make a monthly item on my Palm Pilot.) So if you have an ACK ELT, you may wish to check it from the panel mounted remote to make sure everything is working. FYI, I installed the Lithium battery in August 1999, and expected it to last until 2004. (I don't know if there's any current drain on it when the ELT is in standby.) But it quit almost 4 years to the month, in 2003. My new replacement cycle will be every 3 years now. Hope this helps, Mike Palmer Excellence in Ergonomics |
Our unit went off by itself today because the battery in the remote panel mount indicator died, triggering the ELT, and I'd like to know if anyone else has had this happen? I haven't heard of this before but will check any ACK ELT in any aircraft I inspect. However I thought that regardless of the battery replacement date on an ACK ELT transmitter that the batteries still had to be replaced every two years regardless. Am I wrong. If I am right then replacing the transmitter and remote batteries at the same time would keep that problem from happening. Have you ever had problems with battery leakage in an ACK ELT. I have heard of a number of cases. John Dupre' |
The replacement time for the remote panel is not very explicit compared to
the main unit. The main unit batteries must be replaced "upon reaching the date marked upon each cell" (page 1 of installation and operation manual 08-12-98). For the remote unit, page 7 states "under normal operating conditions the lithium battery must be replaced every eight years. Alkaline type cells....may be used in place of the lithium cell. Under normal operating conditions the alkaline battery must be replaced every four years." (notice no reference to a date marked on the cell regarding the remote panel unit). John Severyn N24495 "Jim Weir" wrote in message ... (JDupre5762) shared these priceless pearls of wisdom: -an ACK ELT transmitter that the batteries still had to be replaced every two -years regardless. Am I wrong. If I am right then replacing the transmitter -and remote batteries at the same time would keep that problem from happening. You are wrong. The Duracell batteries that the TSO requires has an expiration date printed on the side of the battery. The expiration date for the batteries is the printed date. There IS no remote battery replacement requirement. |
My understanding is that the battery due date in the main unit is determined by
the expiration date of the Duracell batteries inside. (Presumably, the 1st day of the month listed.) I stick a sticker with that month/year on the ELT body and make a note in the logbook. As for the remote unit, I'm not sure how to handle that. The replacement battery I bought for it today (an Alkaline - couldn't find a Lithium) has no expiration date that I can find, even though it's a Duracell brand. I'm not sure when it was manufactured either, so I don't know how long it has to live. I plan to make an entry in our Maintenance spread sheet to replace it in two years. (Would have been three if Lithium.) Nor am I sure about requirements for a logbook entry for it and a sticker for it. (IIRC, ACK didn't supply any for the remote when we bought our unit.) It might be that the remote is considered part of the "ELT" as a system, and requires the same documentation as the ELT proper. OTOH, since there's no expiration date (that I can find) for the remote battery, maybe the remote is an area conveniently overlooked by the regulators as being "distinct" from the ELT. (The ELT will still work without a battery in the remote.) I suppose the most prudent way to proceed is to make a sticker and a log book entry and a guess on the replacement date. As for practical replacement of the main batteries - yes, I was alerted by another ACK user that the batteries in his unit leaked, even though well short of the expiration date. I checked ours, and found the same. (Duracells.) I cleaned everything out, and now make it a point to physically remove the batteries at ever annual and also replace them prophylacticly 50% to their expiration date. This isn't the first time I've had Duracells leak - happened in a MAG flashlight too. I live in hot Phoenix, so if not a design flaw, perhaps our heat has something to do with it. (User that had his leak lived in higher (cooler) country in Arizona.) Have you ever had problems with battery leakage in an ACK ELT. I have heard of number of cases. Hope this helps, Mike Palmer Excellence in Ergonomics |
MikeremlaP wrote: If a dying battery in the remote ***always*** sets off the ELT, then this is a design flaw. Everyone's ACK will eventually false alarm if the remote battery isn't replaced on time. (And you know how we are with smoke detectors...) Hmmm... maybe this explains all the false alarms CAP complains about? I've chased dying main batteries in ELTs before, an EPIRB that was ten years out of date, a fax machine and a UPS truck. There are a myriad of ways to produce false alarms on 121.5mhz. Searching for 121.5 signals is so pointless IMO that I don't even go out on 121.5 only searches any more unless there is an ALNOT (ALert NOTice for missing/overdue plane). So in terms of extra work for CAP, this is just a small factor among all the others. Having no signal from the remote switch trigger the ELT is probably done on purpose as a 'fail safe'. Since there is a high propability that in an actual emegancy, the cable between the remote and the ELT will break,it is reasonable to activate the ELT on loss of signal from the remote. I know nothing about the actual design of the ELT in question, so this is just speculation on my part. John -- John Clear - http://www.panix.com/~jac |
"John Clear" wrote in message ... In article , MikeremlaP wrote: If a dying battery in the remote ***always*** sets off the ELT, then this is a design flaw. Everyone's ACK will eventually false alarm if the remote battery isn't replaced on time. (And you know how we are with smoke detectors...) Hmmm... maybe this explains all the false alarms CAP complains about? I've chased dying main batteries in ELTs before, an EPIRB that was ten years out of date, a fax machine and a UPS truck. There are An ELT on a fax machine!!!??? |
"Bill Hale" wrote in message om... ps: Now where do we find the little li cells? Wal-Mart carries them....in the camera department.....or most camera stores. John Severyn N24495 |
I found mine at Fry's Electronics. They used to carry the Lithium version, but all I could find this time at my local store was the Alkaline. HTH, Mike Palmer Excellence in Ergonomics |
