Dan Thomas wrote: In most airplanes the alternator switch controls only a relay in the regulator, not the field current itself. The relay connects the voltage regulator relay to the "A" line, which runs to the alternator output which in turn is connected to the aircraft's electrical system. The small current required to run the relay might not be enough to keep the master/field switch contacts burned clean, and the relay contacts themselves can get worn. The voltage regulator contacts can burn and start cutting out or sticking shut intermittently, too. Not Piper. Piper's field circuit goes from the master bus, through the field breaker, through the master switch, thru the OV relay, thru the regulator to the alternator field. A relay would have been a better design in that the master switch doesn't wear well with the 12v several amp DC current. Many if not most Pipers have solid state regulators, so there are no regulator contacts to burn. -- --Ray Andraka, P.E. President, the Andraka Consulting Group, Inc. 401/884-7930 Fax 401/884-7950 http://www.andraka.com "They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -Benjamin Franklin, 1759 |
Similar Threads | ||||
FA: 12V to 24V DC voltage converter | Karl Geng, N1DL | Home Built | 2 | April 21st 05 08:48 PM |
Remote Switch for Pointer ELT --- Why Does It Need Voltage? | jls | Home Built | 1 | November 22nd 04 09:13 PM |
Battery storage? | Roger Long | Owning | 10 | January 14th 04 02:35 PM |
Skylane Alternator problems | MLenoch | Owning | 7 | December 11th 03 09:37 PM |
Anyone have experience with InterAv alternator | flyer | Home Built | 6 | October 19th 03 03:24 AM |
