#31
mobile phones
Tony Verhulst wrote in
: Tuno wrote: snip Is this a technical fact or just a wishfull speculation? / snip It is a technical fact. Both user equipment (your handheld mobile) and radio base stations (what they talk to) have signal thresholds for "quality of service" that must be met for normal calls (what you're paying for) to go through. These thresholds are MUCH lower for text and emergency calls for obvious reasons: text messages have no real-time requirements (and much lower bandwidth requirements), and emergency calls are, well, emergency calls; who cares about quality of service if it's an emergency. This is quite similar to the ham radio operator voice vs morse code situation. While the signal strengths of both types of signals from a single transmitter will be identical, the *usable* signal strength for code is much less. This is because if a signal is weak or if there is a lot of background noise, it is is much easier to detect dots and dashes than voice. In addition, - all other things being equal, at low SNR AM gives a better quality than FM - morse code can operate with a narrower RF bandwidth, thus reducing noise and increasing SNR |
#32
mobile phones
Tom Gardner wrote: is that the reason why when from time to time my Motorola GSM phone pulses (not necessarily for a call) I can hear the pulse through my computer, car radio etc? If so, that could be an issue for instruments and radio in the aircraft if I understand this correctly. I expect so. The GSM interference during call-setup is "di-di-di, di-di-di, di-di-di, brrr..." duration ~2s. I've been told that BlackBerry's are notorious for this interference. Can one "phone"(/device) interfere with another in this manner? During the frequent telecons I must attend (since travel budget was cut), we frequently hear the pesky "di-di-di--brrrr" you've described. One might extend this conversation to the thousands of PDA's that are semi-permanent (and unapproved?) additions to glider instrument panels (yes, I plead guilty as charged). But perhaps only if they have wireless (e.g. BlueTooth) capability? For personal/work reasons, I have gravitated to PDA's without wireless -- and similarly had to hunt for a cell phone withOUT a camera...trying to stay non-converged (diverged?) in this convergent world is a pain. Remember that old saying? "Aircraft fly because of Bernoulli, not Marconi..." -Pete #309 |
#33
mobile phones
On Mar 7, 3:45 pm, "309" wrote:
I've been told that BlackBerry's are notorious for this interference. Can one "phone"(/device) interfere with another in this manner? I don't know enough about BlackBerries to comment. One might extend this conversation to the thousands of PDA's that are semi-permanent (and unapproved?) additions to glider instrument panels (yes, I plead guilty as charged). But perhaps only if they have wireless (e.g. BlueTooth) capability? Bluetooth's tx power is suitable for a few yards only, and so can be much lower power. This would reduce the probability of interference causing problems. Personally I'd ensure any non-essential radio is completely off before I'm airborne. Practical testing is always useful, provided one realises that testing can only demonstrate problems, not prove the absence of problems. |
#34
mobile phones
309 wrote:
Michael Ash wrote: My understanding is that the major problem with cell phones on GA craft was simply that the old-style cell networks couldn't handle them. An active cell phone in the air would be within range of a bunch of different towers which caused confusion in the network, since it was built on the assumption that the ground would limit your line of sight so that you would only be in range of two or three towers at a time. There are also interference issues with AIRCRAFT SYSTEMS. Certainly. But there is a big difference between airliners and GA craft when it comes to this, namely the fact that in GA craft the use of cell phones will be obvious to the pilot and he can politely ask the passenger to put it away, or he can get off the phone himself. The range of instrumentation will also be much more varied. When I'm flying there should be no interference issues since the only electronic stuff in the glider is the aircraft radio. If I were to use the phone and it were to start messing with the radio, I can always hang up. Airliners have a lot more instrumentation and the use of forbidden objects is harder to detect, so the rules are more strict. -- Michael Ash Rogue Amoeba Software |
#35
mobile phones interference with glider GPS
309 wrote:
Caution is advised. It would be a shame if your 1000k log was trashed when you called Mom to tell her you finally did it... I've not seen any interference from my mobile phone (analog or digital mode) with the GPS or radio. Has anyone had a problem? -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
#36
mobile phones
309 wrote:
One might extend this conversation to the thousands of PDA's that are semi-permanent (and unapproved?) additions to glider instrument panels (yes, I plead guilty as charged). My understanding is "approval" isn't required for general aviation use, because PDA's are portable devices (like a handheld radio, GPS, and oxygen), and the only requirement is the pilot determine they do not cause interference. This doesn't mean we can't think of ways to cause ourselves trouble with some of our mounting methods. I was guilty of mounting a GPS antenna on the glare shield, which would've affected the canopy jettison. I've removed the antenna to a better location, and when I mounted my MRX transponder detector on the glare shield, I used a connector that releases easily. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
#37
mobile phones
Michael Ash wrote:
Airliners have a lot more instrumentation and the use of forbidden objects is harder to detect, so the rules are more strict. Not to mention the potential cumulative effect of two hundred energy radiators operating at the same time. Jack |
#38
mode) with the GPS or radio. Has anyone had a problem? Yes, my Motorola Razr trashes my Garmin 96! Best regards, Jer/ "Flight instruction and mountain flying are my vocations!" -- Jer/ (Slash) Eberhard, Mountain Flying Aviation, LTD, Ft Collins, CO CELL 970 231-6325 EMAIL jer'at'frii.com http://users.frii.com/jer/ C-206, CFII Airplane&Glider, FAA-DEN Aviation Safety Counselor CAP-CO Mission&Aircraft CheckPilot BM218 HAM N0FZD 247 Young Eagles! |
#39
mobile phones
Mike the Strike wrote:
Both text messages and some 911 calls will go through with much weaker signals than needed to complete a regular call. There was a good example of this recently in NZ. A girl rolled her car and ended 3.5m down a bank with the car upside down and supported over a river by the bank and some trees, which were evidently fairly thin, because she wasn't about to try getting out in case the car fell into the river while she was getting out. Her phone wouldn't raise anybody, including emergency services, due to poor signal from where she was, but she was able to text a friend, who passed the emergency call on. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
#40
mobile phones
Blackberries definitely cause interference with wired phones in our
conference rooms, but generally only if they're within a foot or two. I frequently have to remind participants to take them off the table away from the phones. Then they put them in their briefcases or purses which are sitting on the phone wire (read: antenna) on the floor... duh! "309" wrote in message ups.com... Tom Gardner wrote: is that the reason why when from time to time my Motorola GSM phone pulses (not necessarily for a call) I can hear the pulse through my computer, car radio etc? If so, that could be an issue for instruments and radio in the aircraft if I understand this correctly. I expect so. The GSM interference during call-setup is "di-di-di, di-di-di, di-di-di, brrr..." duration ~2s. I've been told that BlackBerry's are notorious for this interference. Can one "phone"(/device) interfere with another in this manner? During the frequent telecons I must attend (since travel budget was cut), we frequently hear the pesky "di-di-di--brrrr" you've described. One might extend this conversation to the thousands of PDA's that are semi-permanent (and unapproved?) additions to glider instrument panels (yes, I plead guilty as charged). But perhaps only if they have wireless (e.g. BlueTooth) capability? For personal/work reasons, I have gravitated to PDA's without wireless -- and similarly had to hunt for a cell phone withOUT a camera...trying to stay non-converged (diverged?) in this convergent world is a pain. Remember that old saying? "Aircraft fly because of Bernoulli, not Marconi..." -Pete #309 |
Similar Threads | ||||
Cell phones on GA aircraft | Mxsmanic | Piloting | 18 | October 16th 06 08:12 PM |
GET FREE CELL PHONES and CAMERA PHONES! | ssgg | Home Built | 0 | February 13th 06 02:34 AM |
Fun with Wx on Cell Phones | B4RT | Rotorcraft | 0 | October 9th 05 02:45 PM |
Cell phones in the air | Roger Worden | Soaring | 35 | March 30th 05 11:01 PM |
Cell phones with GPS | Roger Halstead | Piloting | 0 | December 24th 03 03:04 AM |
