Polikarpov Po-2
https://en.wikipedia.org/wiki/Polikarpov_Po-2
The Polikarpov Po-2 (also U-2, for its initial uchebnyy ("training") role as a flight instruction aircraft) served as a general-purpose Soviet biplane, nicknamed Kukuruznik (Russian: ??????????, from Russian "kukuruza" (????????) for maize; thus, "maize duster" or "crop duster"), NATO reporting name "Mule". The reliable, uncomplicated concept of the Po-2's design made it an ideal trainer aircraft, as well as doubling as a low-cost ground attack, aerial reconnaissance, psychological warfare and liaison aircraft during war, proving to be one of the most versatile light combat types to be built in the Soviet Union. As of 1978 it remained in production for a longer period of time than any other Soviet-era aircraft. It is one of the most produced aircraft, and may be the most produced biplane in history, with as many as 30,000 Po-2s built between 1928 and 1959. However, production figures for Polikarpov U-2 and Po-2 bombers and trainers combined are between 20,000 and 30,000. with production ending as early as 1952. Correct figures are hard to obtain since low-rate production by small repair shops and air clubs likely continued until 1959. The aircraft was designed by Nikolai Polikarpov to replace the U-1 trainer (a copy of the British Avro 504), which was known as Avrushka to the Soviets. The prototype of the U-2, powered by a 74 kW (99 hp) Shvetsov M-11 air-cooled five-cylinder radial engine, first flew on 7 January 1928 piloted by M.M. Gromov. Aircraft from the preproduction series were tested at the end of 1928 and serial production started in 1929 in Factory number 23 in Leningrad. Its name was changed to Po-2 in 1944, after Polikarpov's death, according to the then-new Soviet naming system, usually using the first two letters of the designer's family name, or the Soviet government-established design bureau that created it. Production in the Soviet Union ended in 1953, but license-built CSS-13s were still produced in Poland until 1959. Role Utility biplane Manufacturer Polikarpov First flight 24 June 1927 Introduction 1929 Primary users Soviet Air Force Aeroflot DOSAAF Produced 1928-1952 Number built 20,000–30,000 From the beginning, the U-2 became the basic Soviet civil and military trainer aircraft, mass-produced in a "Red Flyer" factory near Moscow. It was also used for transport, and as a military liaison aircraft, due to its STOL capabilities. Also from the beginning it was produced as an agricultural aircraft variant, which earned it its nickname Kukuruznik. Although entirely outclassed by contemporary aircraft, the Kukuruznik served extensively on the Eastern Front in World War II, primarily as a liaison, medevac and general-supply aircraft. It was especially useful for supplying Soviet partisans behind the German front line. Manufacturing of the Po-2 in the USSR ceased in 1949, but until 1959 a number were assembled in Aeroflot repair workshops. On 17 June 1951, at 01:30 hours, Suwon Air Base was bombed by two Po-2s. Each biplane dropped a pair of fragmentation bombs. One scored a hit on the 802nd Engineer Aviation Battalion's motor pool, damaging some equipment. Two bombs burst on the flightline of the 335th Fighter Interceptor Squadron. One F-86A Sabre (FU-334 / 49-1334) was struck on the wing and began burning. The fire took hold, gutting the aircraft. Prompt action by personnel who moved aircraft away from the burning Sabre prevented further loss. Eight other Sabres were damaged in the brief attack, four seriously. One F-86 pilot was among the wounded. The North Koreans subsequently credited Lt. La Woon Yung with this damaging attack. UN forces named the Po-2's nighttime appearance Bedcheck Charlie and had great difficulty in shooting it down – even though night fighters had radar as standard equipment in the 1950s. The wood-and-fabric material of the Po-2 had only a small radar cross-section, making it hard for an opposing fighter pilot to acquire his target. As Korean war U.S. veteran Leo Fournier remarked about "Bedcheck Charlie" in his memoirs: "... no one could get at him. He just flew too low and too slow." On 16 June 1953, a USMC AD-4 from VMC-1 piloted by Major George H. Linnemeier and CWO Vernon S. Kramer shot down a Soviet-built Polikarpov Po-2 biplane, the only documented Skyraider air victory of the war. The Po-2 is also the only biplane credited with a documented jet-kill, as one Lockheed F-94 Starfire was lost while slowing down to 161 km/h (100 mph) – below its stall speed – during an intercept in order to engage the low flying Po-2. Specifications (U-2) General characteristics Crew: 2 Length: 8.17 m (26 ft 10 in) Wingspan: 11.4 m (37 ft 5 in) Height: 3.1 m (10 ft 2 in) Wing area: 33.2 m2 (357 sq ft) Empty weight: 770 kg (1,698 lb) Gross weight: 1,030 kg (2,271 lb) Max takeoff weight: 1,350 kg (2,976 lb) Powerplant: 1 × Shvetsov M-11D 5-cylinder air-cooled radial piston engine, 93 kW (125 hp) Propellers: 2-bladed fixed-pitch propeller Performance Maximum speed: 152 km/h (94 mph, 82 kn) Cruise speed: 110 km/h (68 mph, 59 kn) Range: 630 km (390 mi, 340 nmi) Service ceiling: 3,000 m (9,800 ft) Rate of climb: 2.78 m/s (547 ft/min) Wing loading: 41 kg/m2 (8.4 lb/sq ft) Power/mass: 0.060 kW/kg (0.036 hp/lb) Armament (U-2VS / LNB only) Guns: One 7.62×54mmR (0.30 in) ShKAS machine gun Bombs: Six 50 kg (110 lb) bombs * |
Similar Threads | ||||
Polikarpov I-16 ZK-JIN | Glenn | Aviation Photos | 0 | December 25th 06 07:26 AM |
Polikarpov I-153 ZK-JJB | Glenn | Aviation Photos | 0 | December 25th 06 07:22 AM |
Polikarpov and Dak | Glenn | Aviation Photos | 0 | December 25th 06 07:20 AM |
Even more polikarpov's | Glenn | Aviation Photos | 6 | December 25th 06 05:42 AM |
Polikarpov I-153-1 | Glenn | Aviation Photos | 0 | December 23rd 06 05:46 AM |
