Is there a drag rake guru out there?
Old April 1st 05, 03:14 AM
Bob Salvo
Have you seen:
http://www.glidingmagazine.com/Featu...cle.asp?id=199
Bob
"Bob Salvo" wrote in message
An analog meter does a nice job of smoothing the information in mild
turbulence. Additional smoothing may be needed with a digital system. If
a
pitot that is used to sample the airspeed at the other port of the
pressure
gauge has the same hose size and length as the hose coming from the rake,
the pressure gauge output should be smoother. You might consider using a
Kiel tube for the pitot and mounting it on you drag probe. I hope to hear
more about your tests.
Bob
"nimbusgb" wrote in message
I have a differential pressure gauge built around a Honeywell DUXL01D.
Measuring 0 - 1" H20 which is the same range that I've seen used on the
old 80's repogle systems and in Dick Johnsons tests.
At the moment, during testing I'll be using an analog meter, my
amplifier outputs a signal between .6 and 4 volts. Ultimately it'll go
into an A/D converter on a digital system I have.
Ian
Old April 1st 05, 05:56 AM
nimbusgb
Yup, been doing a LOT of reading lately!
Ian
Old April 1st 05, 06:01 AM
nimbusgb
Pretty much.
2 * 10 pitots each over a 33mm span with a 'missing' tube a the
midpoint. Gives the rake a 75mm span. The plenum chambers are seperate
on each side of the wing and averaged by a tube running down the rear
edge of the chamber.
Ian
Old April 1st 05, 03:17 PM
Bob Salvo
Do you intend to use it to find the optimum flap position?
Bob
Pretty much.
Ian
Old April 1st 05, 06:36 PM
nimbusgb
Yes, thats the general idea.
Ian
max altitude and Mach 1 Boomer Military Aviation 22 June 1st 04 08:04 PM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 06:42 PM
Source of Induced Drag Ken Kochanski Soaring 2 January 10th 04 12:18 AM
Angle of climb at Vx and glide angle when "overweight": five questions Koopas Ly Piloting 16 November 29th 03 10:01 PM
Did we decide if ballasted pullups are higher???????? Lars Peder Hansen Soaring 22 October 8th 03 12:45 AM
