Over to ATIS?
Old November 18th 07, 08:42 PM posted to rec.aviation.ifr
Paul kgyy
Default Over to ATIS?
I fly in the Chicago area and sometimes find it awkward on a busy
frequency to break in to tell the controller that I need to check ATIS
at my destination. I've tried listening to both ATIS and ATC at the
same time but have never been able to make that work very well.
I do have the Garmin 396 and can pull up the METAR on that, but my
concern is that's not always timely.
Any other ideas?
Old November 18th 07, 09:52 PM posted to rec.aviation.ifr
Ray Andraka
Any other ideas?
Pick up ATIS the first time you get handed off within reception range of
ATIS. You've got a little bit of time between signing off with the
previous controller and the next controller expecting you to have signed
in with him. You can even turn down your primary comm radio while you
get the ATIS, since no one will call you until you check in unless you
are really tardy. Just don't forget to turn it back up before transmitting.
Old November 19th 07, 12:35 AM posted to rec.aviation.ifr
Bob Gardner
Just to piggyback on Ray...turn off the squelch on the radio you want to use
for the ATIS ...you might have to listen to several repetitions to get it
all through the static. Keep a finger on the transfer switch so that you can
kill the ATIS audio when ATC calls your number.
Bob Gardner
"Ray Andraka" wrote in message
Any other ideas?
in with him. You can even turn down your primary comm radio while you get
the ATIS, since no one will call you until you check in unless you are
Old November 19th 07, 12:23 PM posted to rec.aviation.ifr
Ron Natalie
A METAR has a timestamp.
A METAR however is NOT a subsitute for the ATIS.
Old November 19th 07, 02:28 PM posted to rec.aviation.ifr
Andrew Sarangan
There is another important distinction. METAR is weather. ATIS
contains NOTAM and other important information.
Old November 20th 07, 12:18 PM posted to rec.aviation.ifr
Ron Natalie
Yep, that was my point.
JFK ATIS: Strange???? RST Engineering Piloting 5 April 19th 07 10:50 PM
KOSU Arrival ATIS john smith[_2_] Owning 15 April 7th 07 10:52 PM
KSFO ATIS: "FG IN GAP W" David Ziemba Instrument Flight Rules 3 July 20th 04 02:13 PM
KSFO ATIS: "FG IN GAP W" David Ziemba General Aviation 3 July 20th 04 02:13 PM
