Skyking wrote: The trick is to thin it with AvGas when you shut it down. Won't the gas all evaporate out the breather tube if you pour it into the filler neck of a hot engine? How much gas are we talking about here, anyway? -- Ben Jackson http://www.ben.com/ |
****How much gas are we talking about here, anyway?*****
My Cessna 185 has a factory option for an "Oil Dilution" system. There is a table, seconds of OD push per temperature. This was very common in the bush, and before reliable engine preheating. Once the oil warms up, the gasoline evaporates. Best, Karl |
karl wrote: Once the oil warms up, the gasoline evaporates. So it should be added to a cold engine just before start, then? George Patterson Great discoveries are not announced with "Eureka!". What's usually said is "Hummmmm... That's interesting...." |
"G.R. Patterson III" wrote in message ... karl wrote: Once the oil warms up, the gasoline evaporates. So it should be added to a cold engine just before start, then? Nope. Gas is added to the warm engine oil, just before shutdown. That way the oil is diluted and thin for the next cold start. Pretty common on radial engined aircraft. John Severyn |
Similar Threads | ||||
JSF/F-22 weights | John Cook | Military Aviation | 2 | September 11th 04 06:32 AM |
more radial fans like fw190? | jt | Military Aviation | 51 | August 28th 04 04:22 AM |
Auto conversions & gear boxes | Dave Covert | Home Built | 56 | April 1st 04 06:19 PM |
More long-range Spitfires and daylight Bomber Command raids, with added nationalistic abuse (was: #1 Jet of World War II) | The Revolution Will Not Be Televised | Military Aviation | 161 | September 25th 03 07:35 AM |
Engine weights | Salem Farm & Garden | Home Built | 5 | July 22nd 03 04:27 AM |
