Skip Tower View Possible ?
Old November 20th 03, 03:43 AM
Steve Stethen
Default Skip Tower View Possible ?
Looking for a bit of help as I program my HOTAS for FS9.
S (cycle views forward) and shift s (cycle views backward) include
cockpit, virtual, tower and spot views. I don't find the tower view
very useful. I'd like to program specific views in lieu of cycling to
them. Are there discrete commands for cockpit, virtual, and spot views?
Review of the kneeboard keypad assignments leads me to believe
independent view commands don't exist. Has anyone developed a way to
overcome this?
I have a Thrustmaster Cougar.
Thanks,
Buzz
Old November 22nd 03, 03:57 AM
Tlewis95
MIght check the FS2002.cfg or FS9.cfg depending on what sim you have.
Old November 22nd 03, 01:12 PM
Steve Stethen
Good idea. I checked fs9.cfg. No joy.
Buzz
Old November 29th 03, 10:08 AM
Worrybird
Yes it is possible...
Method 1:
Program a toggle button with SHF s (shift s) as the first click to pop to
the chase view on the first click and back in the cockpit with s on the
second click.
Method 2:
However, I had problems with this toggle getting out of sequence and
discovered an even more reliable and lesser known keystroke combination:
SHF [ (shift left bracket)
*** I don't care what view you are in... if you hit SHF [ (shift left
bracket) you will be in the forward 2-D cockpit. If you hit it again it
will toggle the full view off and on. ***
My preference was to program one button to cycle backwards with SHF s (shift
s) - first click will put you in chase, second click will put you in the
Virtual Cockpit.
The second button is programmed with SHF [ (shift left bracket). First
click will always return me to the cockpit, second click will give me the
full forward view.
I hope this makes sense...
daBird
"Steve Stethen" wrote in message
overcome this?
Thanks,
Buzz
Old November 29th 03, 12:19 PM
Angus Lepper
That key combo is the 'Global View On' combo. It shows the cockpit, then if
you press it again, it will rid the cockpit completely, press it again, the
default panels come back.
"Worrybird" wrote in message
link.net...
Method 1:
second click.
Method 2:
(shift
Virtual Cockpit.
full forward view.
daBird
overcome this?
Thanks,
Buzz
Los Angeles radio tower crash kills 2 Paul Hirose Piloting 178 August 6th 05 03:46 PM
Tower Enroute Control? Sam Jones Instrument Flight Rules 5 June 2nd 04 02:31 AM
Tower with only Class G Airspace Jeff Saylor Piloting 8 May 10th 04 09:53 PM
Baby Bush will be Closing Airports in California to VFR Flight Again Larry Dighera Piloting 119 March 13th 04 02:56 AM
New Oshkosh Tower Jay Honeck Piloting 20 November 25th 03 05:35 PM
