Casting Aluminum question
OK, so there has been a lot of talk around here, about casting aluminum for
VW heads. It was here that I first learned that you can not use iron crucibles for melting aluminum. So, what if you need to cast a little job for something that does not to be a pure aluminum part, for a non-aircraft application, where strength is not very important? Would it be good enough? My part is a socket (retainer) to go on top of a tractor shift lever. Think like a donut, with the inside of the hole shaped like would be formed around the outside of a sphere, or half of it. It has a retainer that screws down around the outside of the part, holding the shift lever and ball around it, down onto the transmission. I believe the metal part that needs to be replaced is/was made out of what is usually called "pot metal." What the heck is that, anyway? So, what do you all think? Contamination from a cast iron crucible OK for this part? -- Jim in NC |
Morgans wrote:
OK, so there has been a lot of talk around here, about casting aluminum for VW heads. It was here that I first learned that you can not use iron crucibles for melting aluminum. So, what if you need to cast a little job for something that does not to be a pure aluminum part, for a non-aircraft application, where strength is not very important? Would it be good enough? My part is a socket (retainer) to go on top of a tractor shift lever. Think like a donut, with the inside of the hole shaped like would be formed around the outside of a sphere, or half of it. It has a retainer that screws down around the outside of the part, holding the shift lever and ball around it, down onto the transmission. I believe the metal part that needs to be replaced is/was made out of what is usually called "pot metal." What the heck is that, anyway? So, what do you all think? Contamination from a cast iron crucible OK for this part? Lots of people cast aluminum using steel pots. I don't -- but I spent the money on a selection of graphite crucibles long ago and a big carbide one as well. The steel "crucibles" will eventually fail with a burn through (so will graphite for that matter , but there is a very different event horizon). Pot metal is generally some zinc alloy, like zamac. Decent strength, easy pour, given to corrosion. Atlas used to make a lot of chrome plated die-cast zamac parts for their tools, especially their lathe, which they marketed directly and through Sears & Roebuck. When you buy an old Atlas lathe, you have to make sure the gears, handles and other Zamac doodads don't crumble. Sometimes it almost seems like the chrome is filled with sand. Seems to me I saw plans for a cupola furnace made out of flower pots years ago and fired with BBQ briquettes -- no crucible required. Then again, flower pots can be deadly too. Charles |
"Morgans" wrote in message ... OK, so there has been a lot of talk around here, about casting aluminum for VW heads. It was here that I first learned that you can not use iron crucibles for melting aluminum. So, what if you need to cast a little job for something that does not to be a pure aluminum part, for a non-aircraft application, where strength is not very important? Would it be good enough? My part is a socket (retainer) to go on top of a tractor shift lever. Think like a donut, with the inside of the hole shaped like would be formed around the outside of a sphere, or half of it. It has a retainer that screws down around the outside of the part, holding the shift lever and ball around it, down onto the transmission. I believe the metal part that needs to be replaced is/was made out of what is usually called "pot metal." What the heck is that, anyway? So, what do you all think? Contamination from a cast iron crucible OK for this part? -- Jim in NC Iron pots or crucibles are often used for melting aluminum. Coat it with a clay or graphite slurry before each use for best results. Steel will work, but will not last as long as iron, and coating is a must. Molten aluminum is very corrosive to clean steel. Rust or blasting will help a clay based wash adhere to steel or iron, where cast iron is usually rough enough as cast. I personally prefer to allow new steel ladles to rust outside, then coat regularly with a graphic based wash. I have never personally used cast iron. All my crucibles are silicone carbide. Drying is not terribly important after a wash if you are starting with cold metal. The time and heat required to melt aluminum will dry the pot or crucible long before you see molten metal. But if you are coating a ladle to dip molten aluminum, adequate drying it's an absolute must. Pot metal is usually just slang for die cast aluminum with high zinc content. It makes it very difficult, if not impossible to weld, but I'm told it flows well in high production die casting. |
Similar Threads | ||||
Casting Four Individual VW Heads | [email protected] | Home Built | 23 | January 21st 09 11:07 PM |
CASTING CALL! | [email protected] | Home Built | 11 | January 21st 09 04:51 PM |
casting intricate finned heads | Stealth Pilot[_2_] | Home Built | 13 | January 16th 09 02:35 AM |
misdrilled hole on on tubular aluminum spar question | patrick mitchel | Home Built | 12 | October 2nd 06 08:17 PM |
Tech: Aluminum Forming Question | Scott Rodriguez | Home Built | 5 | March 15th 06 04:42 AM |
