High altitude & RPM
Old August 31st 05, 11:48 PM
abripl
Default High altitude & RPM
At higher altitudes (non-turbo piston engine) is it more efficient for
power/economy to use medium or max RPM? There is much less air there
and if the RPM is too high will it be starving more than at lower RPM?
Old September 1st 05, 12:12 AM
Bill Daniels
"abripl" wrote in message
I have flown light airplanes over the Rocky Mountains for a long time. I
always flew as high as possible at full throttle and as lean as possible.
In fixed-pitch airplanes. The cruise RPM stayed about the same at all
altitudes since the power absorbed by the prop declined with altitude at
about the same rate as engine power. Even with full throttle, the power was
usually something like 50 - 60% at altitudes up to FL 180.
With a CS prop, I ran full throttle and as low an RPM as the handbook
settings allowed. I used full throttle to reduce pumping losses and as lean
as the engine would take without undue vibration to conserve fuel. Low RPM
improved prop efficiency. My engines always lasted way beyond TBO.
Bill Daniels
Metric Instruments Roy Bourgeois Soaring 29 May 27th 13 01:53 PM
Does cruise altitude matter? Ben Jackson Piloting 12 September 3rd 04 04:44 PM
Speeds for best range or endurance don't depend on altitude John T Lowry Piloting 5 April 16th 04 02:02 AM
High Altitude operations (Turbo charge???) Andre Home Built 68 July 11th 03 11:59 PM
