Weght of wings calculated from max T/O weight and max non lifting parts
Old December 29th 16, 02:56 AM posted to rec.aviation.soaring
Default Weght of wings calculated from max T/O weight and max non lifting parts
Can you assume wings weight is max T/O weight - max non lifting parts ?
I am trying to find the wing weight for my ventus C
Dan
Old December 29th 16, 04:15 AM posted to rec.aviation.soaring
JS
Default Weght of wings calculated from max T/O weight and max nonlifting parts
Dan
There may be too many variables for that formula.
Try a set of scales?
Old December 29th 16, 04:23 AM posted to rec.aviation.soaring
Scott Williams
Dan
When I weighed my std Cirrus, I also weighed just the fuselage and stabilator, being Very Careful not to let it fall over. I could do some math and get just the wing weight from that. 'nonlifting' Parts weight was more helpful to me.
Scott
Old December 29th 16, 02:29 PM posted to rec.aviation.soaring
Tango Eight
Dan
No. Try the math and see. You'll be off by 2x (water ballast).
You can measure wing weight with two bathroom scales and get close.
Evan
Old December 29th 16, 04:28 PM posted to rec.aviation.soaring
Paul Rice
To find weight of wings - subtract weigh of Non lifting parts (NLP) from
empty weight of glider, both of which you should have from the last
weighing schedule.
Paul
Dan
Fiberglass cloth weight vs 'finished' weight Fred the Red Shirt Home Built 12 April 5th 08 04:24 PM
Glider Weight/Wing Loading and determing speed for best L/D for a given weight 65E Soaring 3 January 26th 06 09:26 PM
lifting off... Richard Lamb Home Built 0 May 17th 04 05:57 AM
Empty/Gross weight Vs. Max. Pilot weight Flyhighdave Soaring 13 January 14th 04 04:20 AM
Weight of snow on wings Michael Horowitz Home Built 10 January 4th 04 10:58 PM
