Pitot Heat Failure in a Piper
Old February 9th 06, 01:35 AM posted to rec.aviation.owning
Default Pitot Heat Failure in a Piper
On Fri, 3 Feb 2006 15:50:32 +0000 (UTC), Aaron Coolidge
The heating elements - there are 2 in the pitot tube - are supposedly
not repairable. I had one bad heating element a few years ago and a
new heated pitot tube from DMFS was "only" about $250. If the pitot tube
is replaced you are supposed to re-do the transponder/IFR cal as you are
"opening the static system".
Aaron C.
They are repairable. The older ones need to be drilled out, the newer
ones are easily removed and replaced. I've done both. Airparts of
Lockhaven is the right place to go......After you check the electrical
like everyone else has stated.
z
Most reliable homebuilt helicopter? tom pettit Home Built 35 September 29th 05 02:24 PM
TSA requirement of Security Awareness Training dancingstar Piloting 3 October 5th 04 02:17 AM
pitot heat question K. Ari Krupnikov Instrument Flight Rules 7 December 11th 03 01:51 AM
Pitot heat Paul Mennen Owning 10 November 6th 03 09:54 AM
Pitot heat Paul Mennen Piloting 10 November 6th 03 09:54 AM
