K-1 hose in vertical stabilizator
Old April 24th 21, 12:43 PM posted to rec.aviation.soaring
Zbyszek Walas
Default K-1 hose in vertical stabilizator
Hi . In our Jantar Standard ( 1977) plastic pipe for TEC probe inside vertical stabilizator is LEAKED . Is any solution to seal it ( for sample any liquid glue ) without opening stabilizator . Thanks .
Ziggi
Old April 26th 21, 05:35 AM posted to rec.aviation.soaring
Bob Kuykendall
Unfortunately, with plastic tubing that old, there is no point in heroics to try to plug one leak. The tubing is most likely old and rotten, and if you plug one leak, there will be another in some other spot in a few weeks or months. You are probably better off replacing the tubing. A Jantar service expert can probably do it with a minimum of hole-cutting.
--Bob K.
Old April 26th 21, 11:26 AM posted to rec.aviation.soaring
Tony[_7_]
--Bob K.
Is there no way to pull through replacement tubing using the old one as the initial lead?
Old April 26th 21, 01:02 PM posted to rec.aviation.soaring
Jay Campbell
--Bob K.
Don't know specifically on the Jantar, but I did this on a Standard Cirrus. Used the old tube to pull tough nylon string, then used the string to pull the new tubing. I didn't trust the old tubing to pull the new tubing.
That said, if the old tubing has fastening points along its run, obviously those will have to be dealt with first before anything can be pulled by the old tubing. And if there are tight bends to be negotiated, well, you know how that will go.
The Crazy V-Bat Vertical Takeoff And Landing Drone Could Be A Game Changer [2/6] - Crazy V-Bat Vertical 2.png (1/1) Miloch Aviation Photos 0 July 28th 19 04:20 AM
Sell:brass hose connectors and fittings,brass Insert,Hose Coupling,Barb Fitting Brass valvetom Piloting 0 November 28th 06 02:27 AM
Flexible air intake hose abripl Home Built 10 July 21st 06 04:11 AM
T.E. Static hose [email protected] Soaring 7 March 27th 05 01:58 PM
