pushback in fs2002
Old August 15th 04, 09:33 PM
cruise
Default pushback in fs2002
Could someone tell me how to push back from the terminal in FS2002 prof
please? I can thrust forward and turn hard, but unless I disable "reset
after crash" when I hit the terminal building the sim stops and, yes, resets
itself. I have tried reverse thrust too, but that doesn't seem towork. Is
there a proper way to pushback?
Old August 15th 04, 10:16 PM
shift p to push back then
press 1 or 2 without pressing any other keys to turn left or right shift p
again to stop
or you could use y for slew
"cruise" wrote in message
resets
Old August 15th 04, 10:19 PM
maggot
shift+P, press again to stop pushback.
Old September 4th 04, 09:35 PM
Kurt Weber, VACommunity.Net
p
again to stop
Specifically:
Press 1 to make the TAIL (not nose) turn left, meaning the nose will swing
to the right
Press 2 to make the TAIL (not nose) turn right, meaning the nose will swing
to the left
Kurt Weber
fs2002 problem Roger Maskell Simulators 9 June 17th 04 11:14 AM
FS2002 Compass Anomaly - PLEASE HELP GM EWA Simulators 0 January 13th 04 11:20 PM
Difference Between FS2002 Pro vs. the Standard Versions? Bill Wolff Simulators 4 January 12th 04 03:26 AM
Radio problem in FS2002 Scet Simulators 2 September 12th 03 10:19 AM
Help needed - fs2004 zaps fs2002 props Ian D Simulators 1 September 11th 03 10:20 PM
