KLN94 "Flagged" When Database Out of Date
Old September 14th 04, 01:37 PM
Jack Cunniff
You see, I've got an IIMorrow NMS2001, and it suddenly stopped working
late last month, also with the "NAV FLAGGED" symptom, just like another
newsgroup poster had recently had. I was hoping that whatever was ailing
Mike's system was identical to mine, perhaps a GPS date code change (or
rollover).
My GPS had been working perfectly (albeit with a year-old database and
much older firmware) until last month. (How old's the firmware? I'm warned
about ARSA's!)
Garmin (who took over IIMorrow support when they bought UPSAT) said that
the issue was probably a corrupt almanac, but after setting the date to 1
Jan 2004 at startup, and feeding the GPS its location, it then could give
navigation info to all the waypoints I tried entering. (The GPS took
a long time when first coming up, probably doing an autolocate just
the same.) 45 minutes later, I should have had a complete almanac
downloaded. A power cycle later, and it was again NAV FLAGGED and unable
to locate.
I'm thinking it isn't the antenna, since it does eventually "see"
satellites and sense position and give accurate nav info to other
waypoints.
Before I take it to the shop, I'm wondering if anyone else has ideas about
the root cause of the problem. (And don't say I'm cheap, 'cause I just put
in a new attitude indicator last week. :-)
-Jack
Old September 14th 04, 02:03 PM
Peter Clark
On Tue, 14 Sep 2004 12:37:14 +0000 (UTC), Jack Cunniff
rollover).
about ARSA's!)
to locate.
Do these units have an internal CMOS battery which might be dead?
Old September 14th 04, 05:20 PM
Jack Cunniff
Peter Clark writes:
about ARSA's!)
DING!
Reviewing the fantastic manual, (Yes, F is for Fantastic) I find that
there is indeed a statement saying that the NMC memory is maintained by a
lithium battery with a 5-10 year lifetime. It's not a user-replacable
item.
So - I'm off to the shop, with not just a symptom, but also a pointer to a
solution. That definitely could be the solution.
Thanks for your help, Peter!
-Jack
Learning the KLN94 GPS DH Instrument Flight Rules 7 April 7th 04 06:28 PM
What approaches are in a database? Ross Instrument Flight Rules 11 January 4th 04 07:57 PM
