PIX -- Oil pump & new sump drain
Old September 25th 08, 09:04 PM posted to rec.aviation.homebuilt
Default PIX -- Oil pump & new sump drain
To All,
The last couple of days we've talked about VW oil pumps, and about
making a new drain for the sump of a converted VW.
I've just posted some pictures of an assortment of VW oil pumps, and a
little How-To for the sump drain I use. I've posted the pictures to
the chuggers group, in the engine folder.
The drain is not yet drilled & tapped but the laying-out and sawing
should give you an idea of what is to follow, in that the newly
created surface (ie, what you have after lopping off that corner of
the crankcase) is perpendicular to the axis of the new drain, which
will be tapped M8x1.25. An O-ring provides the seal and the 'plug' --
a regular bolt -- is safety-wired.
-R.S.Hoover
Can you dry sump a type1 VW engine? Fonz Home Built 6 January 27th 07 07:28 AM
Spider in Archer Sump Drain Bob Chilcoat Owning 3 June 29th 05 10:29 PM
0-300D cylinder and oil sump torque settings Darrel Toepfer Owning 5 January 13th 05 04:41 PM
Looking for user comment : Oil Sump Heater Javier Gorordo Owning 8 December 2nd 03 01:33 PM
sump drain cleaning Mike Noel Owning 15 August 15th 03 02:41 AM
