#11
ELT's
Todd,
I looked at the APRS system several years ago. It would provide coverage when flying in the Boise region. However, the coverage is minimal to none existent over the mountains of Central Idaho (Mackay, King Mountain Glider Park, etc.) and bordering region of Montana. H Wayne Paul W7ADK (I've had my amateur radio license for a LONG time.) "Todd" wrote in message ... And if you have an Amateur Radio License there is the APRS tracking option. Here is a flight in Colorado (where you might think the coverage may not be good) for this summer: http://aprs.fi/?call=N8RNW-6&dt=1311...timerange=3600 A device like this: http://www.byonics.com/mt-rtg is easy to stick in the glider More information available at: http://www.aprs.org And if you do not have an Amateur Radio License, get one. It is not that hard. There are networks of linked repeaters that will give you radio contact to your crew over distances that your aircraft radio wont. |
ELT's
Please look at my website page:
http://www.wingsandwheels.com/elt_em...plb_person.htm there is a new unit from Kannad that has not only internal GPS but also includes and internal 406 Mhz antenna. You will note that they originally had suggested this could be mounted without any external antenna but the FAA frowned on this and they now include a note regarding this "an external antenna must be mounted when "mandated".essentially though, an ELT is not "mandated" for gliders and in fact there is an exception to the ELT requirement for gliders. With that being said, this ELT can legally be installed in a glider without the external antenna.....I have spoken directly with our technical contact at Kannad and he stated that the ELT performs as well with the internal antenna as with the external antenna as long as the ELT has an unblocked view (meaning not covered by metal, carbon fiber or materials that would otherwise block the antenna signal. The other exception to this is that the Integra ELT does not transmit the 121.5 Mhz signal without the external antenna. It will Tx on 121.5 however with the "portable" antenna used like most handheld devices so this could also be easily implemented. I have in the past installed the previous model 121.4/243 ELT's in my own gliders with simple rubber duck handheld antennas since they too were 1/4 wave and typical for the airband (118-136 Mhz) and mounted these on smaller ground planes..Understandably even the short rubber duck antenna is in actuality a 22-23" antenna but coiled so it in all perfection should have a ground plane that would be undoable in nearly any glider (being nearly 22" radius) but even a small ground plane is more effective and though a compromise of the "ideal" works....I have tested my own and found then working and sending a signal that I believe could be received by S&R. The big advantage to the aircraft ELT over Spot's and PLB's is that they are activated on impact and have internal batteries capable of sending the signal for several hours even days and I know we've all heard the arguments that ELT's don't work....but the fact of the matter is that they do and even in soaring we have had ELT's that have helpd to find downed gliders.. should ELT's be mandatory in gliders, in contest? or? ? I'll let the rest of you argue and debate this and leave requiring ELTs, PLB's Spot's, Flarm, TCAS and the rest up the individual pilots to decide. regards Tim Mara "Dick" wrote in message ... A couple of years ago there was talk of denying entry in to contests all gliders that were not equipped with ELT's. I immediatly ordered a 121.5 / 406 Mhz model. It came the other day, a year and a half later. It includes a clunky antenna that would have to be mounted outside of a carbon hull. I have two questions. One, what happened to the urgency??? and two has anyone come up with a workable solution to the antenna issue? __________ Information from ESET NOD32 Antivirus, version of virus signature database 6407 (20110824) __________ The message was checked by ESET NOD32 Antivirus. http://www.eset.com __________ Information from ESET NOD32 Antivirus, version of virus signature database 6407 (20110824) __________ The message was checked by ESET NOD32 Antivirus. http://www.eset.com |
ELT's
I would not want to recommend any of these installations as shown as
examples of "how to do it", all of the installations proposed were highly suspect...in any antenna installation you'd want to keep the antenna's from paralleling other antenna's, metal posts or objects as they will interfere with the radiation pattern and even can bounce signals back and forth creating distortion.you also need to look at the antenna mast and the direction that you are hoping to transmit to, typically the mast would want to be vertical to send the signal in a more horizontal direction, particularly for communications being that we don't know in the case of an ELT what might and might not be vertical .....again looking for ideal....even that said, some signal can get out even with a damaged or missing antenna but greatly reduced..In a conversation with Ameri-King (claimed) they claimed to have tested their ELT for certification with no antenna attached...but I might find this to be suspect. tim Please visit the Wings & Wheels website at www.wingsandwheels.com "Paul Remde" wrote in message ... Hi Dick, ELTs are still great safety devices. Most contests probably won't require them - requiring SPOT units instead. One workable internal antenna mounting solution is shown he http://www.archive.jimphoenix.com/ar...Nfuselage.html Best Regards, Paul Remde Cumulus Soaring, Inc. __________ Information from ESET NOD32 Antivirus, version of virus signature database 6407 (20110824) __________ The message was checked by ESET NOD32 Antivirus. http://www.eset.com |
ELT's
Mmmm thanks Tim, that Kannad antenna systems is quite appealing for somebody who really wants a 406 Mhz ELT. This may be by far the best ELT approach, say mount it under the fiberglass RF area of a turtledeck (an area that likely survives impact well). Just be aware that many SAR organizations may still attempt to do final homing on the 121.5 MHz beacon all these systems also carry and so having a way to connect the 121.5 MHz antenna (if you are able to after landing/crashing) is important. The 406 MHz patch antenna is unlikely to provide a good radial pattern for ground based homing on 405 MHz. I think we'll disagree on how reliable ELTs activations are - at least one benefit of a Kannad system is that mounted like above or in front of the spars under the turledeck and aligned along the gliders axis properly etc. is likely a better install location than other places where these ELTs end up misaligned and have likely lower probability of proper activation. The problem with rubber ducky antennas with 405 MHz ELTs is having a single antenna that handles 406 MHz and 121.5 MHz signals. Darryl On 8/24/11 1:54 PM, Tim Mara wrote: Please look at my website page: http://www.wingsandwheels.com/elt_em...plb_person.htm there is a new unit from Kannad that has not only internal GPS but also includes and internal 406 Mhz antenna. You will note that they originally had suggested this could be mounted without any external antenna but the FAA frowned on this and they now include a note regarding this "an external antenna must be mounted when "mandated".essentially though, an ELT is not "mandated" for gliders and in fact there is an exception to the ELT requirement for gliders. With that being said, this ELT can legally be installed in a glider without the external antenna.....I have spoken directly with our technical contact at Kannad and he stated that the ELT performs as well with the internal antenna as with the external antenna as long as the ELT has an unblocked view (meaning not covered by metal, carbon fiber or materials that would otherwise block the antenna signal. The other exception to this is that the Integra ELT does not transmit the 121.5 Mhz signal without the external antenna. It will Tx on 121.5 however with the "portable" antenna used like most handheld devices so this could also be easily implemented. I have in the past installed the previous model 121.4/243 ELT's in my own gliders with simple rubber duck handheld antennas since they too were 1/4 wave and typical for the airband (118-136 Mhz) and mounted these on smaller ground planes..Understandably even the short rubber duck antenna is in actuality a 22-23" antenna but coiled so it in all perfection should have a ground plane that would be undoable in nearly any glider (being nearly 22" radius) but even a small ground plane is more effective and though a compromise of the "ideal" works....I have tested my own and found then working and sending a signal that I believe could be received by S&R. The big advantage to the aircraft ELT over Spot's and PLB's is that they are activated on impact and have internal batteries capable of sending the signal for several hours even days and I know we've all heard the arguments that ELT's don't work....but the fact of the matter is that they do and even in soaring we have had ELT's that have helpd to find downed gliders.. should ELT's be mandatory in gliders, in contest? or? ? I'll let the rest of you argue and debate this and leave requiring ELTs, PLB's Spot's, Flarm, TCAS and the rest up the individual pilots to decide. regards Tim Mara wrote in message ... A couple of years ago there was talk of denying entry in to contests all gliders that were not equipped with ELT's. I immediatly ordered a 121.5 / 406 Mhz model. It came the other day, a year and a half later. It includes a clunky antenna that would have to be mounted outside of a carbon hull. I have two questions. One, what happened to the urgency??? and two has anyone come up with a workable solution to the antenna issue? __________ Information from ESET NOD32 Antivirus, version of virus signature database 6407 (20110824) __________ The message was checked by ESET NOD32 Antivirus. http://www.eset.com __________ Information from ESET NOD32 Antivirus, version of virus signature database 6407 (20110824) __________ The message was checked by ESET NOD32 Antivirus. http://www.eset.com |
ELT's
In my own installations and the ones I illustrated on my website with the
rubber duck antenna's these were of course done with the 121.5/243.0 ELT's not with 406 Mhz.... granted, few S&R teams have capability to even search the 406 frequency signals and do rely on the stand-by 121.5 Mhz ....the new 406 ELT's typically will no longer have 243.0Mhz but retain 121.5.again, you have to have an external antenna or portable antenna to Tx on this frequency.....Kannad does have an optional antenna for portable use and it is possible that other rubber duck antenna could also be mounted to the unit for 121.5 but Kannad warns that an improper antenna used here can also harm the ELT...I'd need to get more clarification as to why and how but at least their own portable antenna option remains as possible choice. best regards Tim Mara Please visit the Wings & Wheels website at www.wingsandwheels.com "Darryl Ramm" wrote in message ... Mmmm thanks Tim, that Kannad antenna systems is quite appealing for somebody who really wants a 406 Mhz ELT. This may be by far the best ELT approach, say mount it under the fiberglass RF area of a turtledeck (an area that likely survives impact well). Just be aware that many SAR organizations may still attempt to do final homing on the 121.5 MHz beacon all these systems also carry and so having a way to connect the 121.5 MHz antenna (if you are able to after landing/crashing) is important. The 406 MHz patch antenna is unlikely to provide a good radial pattern for ground based homing on 405 MHz. I think we'll disagree on how reliable ELTs activations are - at least one benefit of a Kannad system is that mounted like above or in front of the spars under the turledeck and aligned along the gliders axis properly etc. is likely a better install location than other places where these ELTs end up misaligned and have likely lower probability of proper activation. The problem with rubber ducky antennas with 405 MHz ELTs is having a single antenna that handles 406 MHz and 121.5 MHz signals. Darryl On 8/24/11 1:54 PM, Tim Mara wrote: Please look at my website page: http://www.wingsandwheels.com/elt_em...plb_person.htm there is a new unit from Kannad that has not only internal GPS but also includes and internal 406 Mhz antenna. You will note that they originally had suggested this could be mounted without any external antenna but the FAA frowned on this and they now include a note regarding this "an external antenna must be mounted when "mandated".essentially though, an ELT is not "mandated" for gliders and in fact there is an exception to the ELT requirement for gliders. With that being said, this ELT can legally be installed in a glider without the external antenna.....I have spoken directly with our technical contact at Kannad and he stated that the ELT performs as well with the internal antenna as with the external antenna as long as the ELT has an unblocked view (meaning not covered by metal, carbon fiber or materials that would otherwise block the antenna signal. The other exception to this is that the Integra ELT does not transmit the 121.5 Mhz signal without the external antenna. It will Tx on 121.5 however with the "portable" antenna used like most handheld devices so this could also be easily implemented. I have in the past installed the previous model 121.4/243 ELT's in my own gliders with simple rubber duck handheld antennas since they too were 1/4 wave and typical for the airband (118-136 Mhz) and mounted these on smaller ground planes..Understandably even the short rubber duck antenna is in actuality a 22-23" antenna but coiled so it in all perfection should have a ground plane that would be undoable in nearly any glider (being nearly 22" radius) but even a small ground plane is more effective and though a compromise of the "ideal" works....I have tested my own and found then working and sending a signal that I believe could be received by S&R. The big advantage to the aircraft ELT over Spot's and PLB's is that they are activated on impact and have internal batteries capable of sending the signal for several hours even days and I know we've all heard the arguments that ELT's don't work....but the fact of the matter is that they do and even in soaring we have had ELT's that have helpd to find downed gliders.. should ELT's be mandatory in gliders, in contest? or? ? I'll let the rest of you argue and debate this and leave requiring ELTs, PLB's Spot's, Flarm, TCAS and the rest up the individual pilots to decide. regards Tim Mara wrote in message ... A couple of years ago there was talk of denying entry in to contests all gliders that were not equipped with ELT's. I immediatly ordered a 121.5 / 406 Mhz model. It came the other day, a year and a half later. It includes a clunky antenna that would have to be mounted outside of a carbon hull. I have two questions. One, what happened to the urgency??? and two has anyone come up with a workable solution to the antenna issue? __________ Information from ESET NOD32 Antivirus, version of virus signature database 6407 (20110824) __________ The message was checked by ESET NOD32 Antivirus. http://www.eset.com __________ Information from ESET NOD32 Antivirus, version of virus signature database 6407 (20110824) __________ The message was checked by ESET NOD32 Antivirus. http://www.eset.com __________ Information from ESET NOD32 Antivirus, version of virus signature database 6410 (20110825) __________ The message was checked by ESET NOD32 Antivirus. http://www.eset.com __________ Information from ESET NOD32 Antivirus, version of virus signature database 6410 (20110825) __________ The message was checked by ESET NOD32 Antivirus. http://www.eset.com |
ELT's
On Tue, 23 Aug 2011 16:03:46 -0700 (PDT), Bob Kuykendall
wrote: In a word, Spot. the big disadvantage of the Spot device is, if I understand correctly, that it sends out a position message every 10 minutes. It may well happen that a message doesn't pass through the satellite system, so the distance between fixes may reach 20 (or more) minutes. Now, at the the speed we fly in contest, 10mins equal somewhere between 10 and 30 km. Add to this the unpredictable deviations from course, and I believe you get just an indication for a search circle about 30km in radius. In rough terrain, that's quite a huge area. My first choice is to have an ELT, and possibly add tracking functions via a GPS-Smartphone (feat. ReliRescue or similar softwares) or a Spot. When many sailplanes share a competition area, Flarm traces have proved to be extremely valuable in reconstructing a missing glider's path. Another reason for promoting Flarm usage. aldo cernezzi (BTW: I've been at a contest where we all were grounded for 3 consecutive days, trying to help, driving and hiking around in the mountains, until the rests were found. The pain for the family was never ending. Please don't let this agony repeat itself) |
ELT's
On Aug 23, 6:36*pm, Dick wrote:
A couple of years ago there was talk of denying entry in to contests all gliders that were not equipped with ELT's. *I immediatly ordered a 121.5 / 406 Mhz model. *It came the other day, a year and a half later. *It includes a clunky antenna that would have to be mounted outside of a carbon hull. *I have two questions. *One, what happened to the urgency??? *and two has anyone come up with a workable solution to the antenna issue? US contest rules permit the contest organizer to require ELT's or other safety device as thety see fit.The initiative, authored by myself, to make ELT's mandatory was never implemented as pilots did not think theyshould be mandatory. Personally, I have an impact actuated ELT, a 406 PLB, and a SPOT, acquired in that order. I'm confident that, with those implemented, I will be found. None are perfect. ELT's are negatively affected by installation and antenna issues. PLB's require concious person to activate. Spot has to see the sky. Today from scratch, I would do Spot, and add impact activated 406 when I felt I could afford it, My decisions are based on my hope that my going missing will end quickly to minimize the effect on my wife and family. FWIW UH UH |
Similar Threads | ||||
ELT's | [email protected] | Soaring | 0 | March 16th 05 07:27 PM |
ELT's | Brad | Soaring | 3 | January 20th 05 06:12 AM |
New 406 MHz ELT's | Brian GJ | Soaring | 0 | July 5th 04 06:52 PM |
ELT's, On Star, etc | Tim Shea | Soaring | 3 | November 19th 03 08:13 PM |
ELT's are a joke | Buck Wild | Soaring | 22 | November 18th 03 08:44 AM |
