Exhaust pipe on one side is sooty
Old June 14th 05, 02:40 AM
nrp
Maybe a minor air leak in the intake system on the leaner side? The
intake gaskets have a straight side & I've seen them suck in. Maybe a
loose hose clamp?
A leaking primer is also a possibility - as I recall they usually only
prime on one side.
A test would be to apprach under power, land and check immediately,
avoiding any taxi at low power & see if it is fouling at cruise. I'd
be concerned if the black stuff is generated on one side at cruise.
Old June 14th 05, 02:49 AM
This calls for a compression check and a timing check on the engine.
Old June 14th 05, 03:47 AM
Mike Rapoport
What would a timing check accomplish?
MU-2
Old June 14th 05, 05:18 AM
Peter Duniho
"nrp" wrote in message
That's a good point. Just because the symptom is on one side, that doesn't
mean that the problem isn't on the other.
Old June 14th 05, 05:35 AM
RST Engineering
Absolutely nothing. The man is a jerknose.
MU-2
Old June 14th 05, 08:13 PM
George Patterson
Casey Wilson wrote:
I'm talking about soot in the pipe. Right side is dusty brownish -- left
side is black grimy.
Either burning or pumping oil. Check the plugs on those cylinders -- if the
ceramic is also black and sooty, that's the cylinder with the problem.
Compression tests are in order. If the black grime is deamp and smeary, suspect
a broken ring.
George Patterson
Why do men's hearts beat faster, knees get weak, throats become dry,
and they think irrationally when a woman wears leather clothing?
Because she smells like a new truck.
The Meredith Effect Corky Scott Home Built 19 September 4th 04 04:01 PM
P-38 Exhaust Stephen Harding Military Aviation 10 April 19th 04 07:03 AM
FS: Piper Side Window (New) JimC Aviation Marketplace 0 August 10th 03 12:19 PM
YF-23 exhaust? Sir Loin of Beef Military Aviation 0 August 1st 03 04:55 AM
Exhaust Tape RobertR237 Home Built 19 July 30th 03 03:06 AM
