Modifying Std Libelle with Tost Lilliput Wheel
Old September 18th 17, 01:32 AM posted to rec.aviation.soaring
Default Modifying Std Libelle with Tost Lilliput Wheel
Has anyone done a 337 to modify a Std Libelle with the Tost 4" wheel? Looking tech data for a 337 or a precedent of someone that has already done this.. I know the Tost Wheel Selection Chart shows compatibility and Streifeneder is ok with the substitution but that's probably enough to satisfy the FAA.
Old September 18th 17, 06:55 AM posted to rec.aviation.soaring
Darryl Ramm
On Sunday, September 17, 2017 at 5:32:43 PM UTC-7, wrote:
Has anyone done a 337 to modify a Std Libelle with the Tost 4" wheel? Looking tech data for a 337 or a precedent of someone that has already done this. I know the Tost Wheel Selection Chart shows compatibility and Streifeneder is ok with the substitution but that's probably enough to satisfy the FAA.
Uh this has accommodation for a 4" wheel already right? You are talking off one tailwheel and replacing it with another, maybe with washers or axle spacers? Right?
What major modification is being made here and who is telling you a 337 is required?
Old September 18th 17, 02:57 PM posted to rec.aviation.soaring
Hmmmm........
Do you have the motorcycle wheel, the one that has spoke holes? If so, no 337 needed to replace with current factory unit in use (Stiefenater)
JJ
Old September 18th 17, 05:46 PM posted to rec.aviation.soaring
JS[_5_]
Mike et al:
If you are doing this to improve the brakes, a more simple approach would be to take the wheel to a motorcycle brake shop that still does drum brakes. There are not many places that do that sort of vintage stuff.
I've used Vintage Brake in Sonora, California. Mike does a great job of relining and arcing the shoes, but the shop normally has a waiting list. One method to secure a spot and not have your glider down for months is to pay up front and you'll be informed when to send your whole main wheel in.
Vintage Brake
Michael Morse
209 533-4346
info AT vintagebrake.com
www.vintagebrake.com
The last job I sent to them was a Libelle wheel. It could put the glider on the nose after the mod.
Old September 18th 17, 07:36 PM posted to rec.aviation.soaring
What is the long term brake performance?
My thoughts, limited in types, is "Tost" should be "Toast"......,good for one hard braking, then they're toast.
Not sure if it's the braking material or the drum. Pull it apart, sand (200 grit or so dry) on the shoes and drums, great for one hard braking event, repeat process.
I'm guessing the brake material.
Most recent experience is a 2 place Lark. In general, my experience is Tost drum brakes are weak other than the first application.
If you have a better experience, please share. I still think it's the shoe friction material from the OEM.
Maybe your motorcycle shop has a decent friction material that lasts for multiple hard stops, great!
This from someone that has done "band brakes" (1-26 brake against the tire tread.....sucks when the ground is wet) up to various ASW's where you grind the Gelcoat off the belly if you're not careful on pavement.
Old September 18th 17, 08:31 PM posted to rec.aviation.soaring
On Monday, September 18, 2017 at 11:36:40 AM UTC-7, Charlie M. (UH & 002 owner/pilot) wrote:
I never said anything about a braking issue, I said I wanted to replace the original wheel with the TOST wheel.
My A&P interprets the FAA regs as no different parts in a "Type Certificated " aircraft are allowed without an Supplimental Type Certificate issued approving the different part or a Tech Memo from the Certificate Holder (Streifeneder).
Old September 18th 17, 11:59 PM posted to rec.aviation.soaring
Later 201's came with a Tost wheel, Stiefanater holds the type certificates for all Glasflugel ships, he also sells Tost wheels. No 337 required, no supplemental type cert needed.
JJ
Old September 19th 17, 12:19 AM posted to rec.aviation.soaring
JJ
Thanks you!
Old September 19th 17, 01:12 AM posted to rec.aviation.soaring
[email protected][_1_]
*1 for Michael "Mercury" Morse. Blueprinted and relined my -20A Tost wheel and braking was reliable and powerful. Smelled like rotted fish when applied, however. Small price to pay.
Old September 19th 17, 10:10 AM posted to rec.aviation.soaring
Ross[_3_]
I got really excited earlier this year and installed the Beringer wheel in my libelle. Now have a disk brake that works fantastic.
Not sure how you would get around it there, but Streifeneder does have a TM for it
Wing Wheel - Std Libelle [email protected] Soaring 0 August 13th 13 11:49 PM
Tost 5“Penta disk brake wheel Mod for Duo Discus Mike I Green Soaring 0 February 6th 12 09:38 PM
Tost brass tail wheel, tube, tire for sale: USA Barny Soaring 2 August 12th 11 10:43 PM
Libelle broken wheel landing Burt Compton - Marfa Soaring 3 April 25th 11 05:55 PM
need Libelle wheel installed pix Brad[_2_] Soaring 10 July 31st 10 02:01 AM
