Loss of Mode C and Transponder Reply
Lost Mode C and Transponder reply while in Class B airspace the other
day. After landing, was looking at all of the simple obvious things, like transponder not seated in tray etc. Little voice told me to look at the antenna, too. Seems the whip broke at the base and just fell off. It is mounted on the bottom of the boot cowl just aft of the firewall on the PA22/20, and probably gets subjected to some buffeting from the propellor pressure pulses. Mounting a new one further back from the propellor might be better, but that would put it closer to the landing gear legs. Alternatively, it would have to go all the way back to mid fuselage where there is a 16x16" metal access plate for the elavator trim jackscrew. The strobe is mounted on this plate. Otherwise the fuselage is covered with fabric. Any ideas? MikeM Pacer '00Z |
mikem wrote: Any ideas? I would probably put the new one in exactly the same place. They aren't real expensive, and I think that's the best place for it on that plane (mine is in the same place on my Maule). How long did it last? Maybe the best bet is to replace it periodically before it fails, like some people replace dry vacuum pumps. George Patterson A diplomat is a person who can tell you to go to hell in such a way that you look forward to the trip. |
mikem wrote:
Lost Mode C and Transponder reply while in Class B airspace the other day. After landing, was looking at all of the simple obvious things, like transponder not seated in tray etc. Little voice told me to look at the antenna, too. Seems the whip broke at the base and just fell off. It is mounted on the bottom of the boot cowl just aft of the firewall on the PA22/20, and probably gets subjected to some buffeting from the propellor pressure pulses. Mounting a new one further back from the propellor might be better, but that would put it closer to the landing gear legs. Alternatively, it would have to go all the way back to mid fuselage where there is a 16x16" metal access plate for the elavator trim jackscrew. The strobe is mounted on this plate. Otherwise the fuselage is covered with fabric. Any ideas? MikeM Pacer '00Z Go to an avionics shop that knows how to properly install a metal backing plate in a fabric aircraft. Ask how much to replace the existing antenna and how much to move it back. -- Jim Pennino Remove -spam-sux to reply. |
mikem wrote:
wrote: Go to an avionics shop that knows how to properly install a metal backing plate in a fabric aircraft. My AI and I installed a backing plate under the TXP antenna about a year ago. Prior to this, it was mounted only through the (very thin) aluminum boot cowl, and was very flexible. I'm guessing that adding the backing plate stiffened the mount to where the whip now hits some vibration modes excited by the propellor pulses... Could well be. Better to fatigue off a cheap antenna than a chunk of the cowl though. Ask how much to replace the existing antenna and how much to move it back. No expertise with fabric aircraft at any local avionics shop. The replacement antenna TED 12-10 can be had from Spruce for $20, Chief for $23, and eBay for $15+ That's not really surprising. Back in the early 70's when I worked in an avionics shop and fabric aircraft were a lot more common, we only did one or two a year if you didn't count the Maules which had metal in the right place already. Anyway, I think you answered your own question; $20 now and then is a lot cheaper than finding someone with the expertise to mount it on the belly. You could mount it inside the fabric, but that would probably be even more expensive and problematic. -- Jim Pennino Remove -spam-sux to reply. |
Similar Threads | ||||
KT76C Mode C transponder - what is it worth? | Mike Rapoport | General Aviation | 1 | November 21st 04 05:56 AM |
Narco AT-50 Mode C Transponder for sale | Jay Honeck | Aviation Marketplace | 0 | June 28th 04 06:48 PM |
WTB: Mode C Transponder | Chris Batcheller | Aviation Marketplace | 0 | February 21st 04 01:31 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
Mode S Transponders - Can ATC tell the difference? | Doodybutch | Owning | 2 | August 10th 03 06:21 AM |
