contrails
Old January 12th 10, 07:05 PM posted to rec.aviation.soaring
bildan
Default Global Warming/Climate Change (was contrails)
On Jan 12, 10:40*am, T8 wrote:
On Jan 12, 11:12*am, bildan wrote:
On Jan 11, 6:56*pm, Martin Gregorie
On Sun, 10 Jan 2010 12:47:53 -0800, Tom Gardner wrote:
2) If everyone turns their thermostats one degree closer to the outside
temperature, drives a smaller car, and switches off phone chargers when
not in use, will an energy crisis be averted?
My sister pointed out recently that British people tend to keep their
houses warmer than we did/do in NZ, so turning down the thermostat is not
a hardship - just put on a pullover over your T-shirt in winter.
Smaller cars is a problem for us in the trailer towing fraternity. My
main gripe with the current crop of electric and hybrid cars is that
nobody mentions towing, that I've seen anyway. There's one exception:
Aptera say NO TOWING up front. I guess the same goes for many of the rest
but they're too chicken to mention it.
Hungry chargers are just stupidly bad technology and should be banned..
Chargers that use no power[1] when they're plugged in but not connected
to anything have been around for at least 8 years, so there's no excuse
for selling one that burns power when its under no load.
Anyway, I just looked at four chargers I happened to have handy and
here's what it shows they burn when plugged into the mains and
disconnected from the things they charge:
18 month old Lenovo laptop PSU (65w o/p) * * * *0 * watts.
my much older Thinkpad 560Z PSU (54w o/p) * * * 1.9 watts.
iPAQ 3630 PSU (10w o/p) * * * * * * * * * * * * 2.0 watts.
2001 Motorola T250 phone charger (2.5w o/p) * * 0 * watts.
[1] I recently bought myself a power meter for a tenner from Maplins. It *
which reads to 0.1 watts, so a reading of 0.0 should mean 50 mW
consumption or less. These power meters are simple to use: they have a 13
amp plug on the back and a 13 amp socket on the front, so you just plug
them in between the wall and the device you want to measure.
martin@ * | Martin Gregorie
gregorie. | Essex, UK
org * * * |
I suspect the concept of "powered trailers" will pop up more
frequently. *This is not an unproven concept since the mining industry
has used it for years.
If you use a load cell to measure the push-pull loads at the trailer
hitch, the data can be used to control electric motors in the trailer
wheels. *If a glider *trailer housed a large battery, possibly charged
with a large solar panel on top and wheel motors, it could minimize
the loads imposed on the towing vehicle by essentially powering
itself. *The wheel motors would also provide regenerative braking.
The whole car-trailer combo then becomes a parallel hybrid which
permits the use of a much smaller and less powerful car. *The fuel
savings while towing would be small compared to the fuel savings
achieved by driving a small, fuel efficient yet tow capable car when
not towing.
The energy capacity of the trailer battery pack coupled to an inverter
could also power things like power tools and polishers when parked at
the airport.
The problem with EVs isn't power, it's on-board energy storage.
I have a friend who is a hybrid/EV enthusiast. *He reckons the holy
grail is 40 mile range. *Okay, adequate for most people buying
groceries or going to work, but completely useless for XC travel. *We
need 1 - 2 magnitudes of improvement in energy density and 3 or 4 in
re-fueling time before you can reasonably talk about competing with
existing gas/diesel for hauling pilot/plane/crew to a site several
hundred miles distant.
That, or we turn I80 into a giant sized nuclear powered HO slot car
track :-).
Back to trailers: *From fuel consumption numbers, I can back out that
my Komet trailer/glider has an effective fuel consumption of 120 miles
to the gallon at 60 - 65 mph on level road, no wind. *Figure about 6
hp. *Two or three times that under acceleration or ascending steep
grade. * The point is: it's a small load. *A decently capable EV could
tow it without difficulty.
-Evan Ludeman / T8
Yes, pretty much any econobox can pull a glider trailer on a level
road. Where the 'powered trailer' idea would come in is on hills.
~90% of the time, the trailer would be unpowered and the trailers
wheel motors would only kick in when the towing econobox couldn't
handle the load alone. On downhill grades, the wheel motors would
switch to regenerative braking to recharge the trailer battery and
save the towing vehicle's brakes.
Set up correctly, the charge in the trailer battery should last as
long as the fuel in the towing vehicle's tank. If recharging stations
proliferate, the trailer battery could be recharged while the tow
car's tank is being refilled.
  #212
Old January 12th 10, 08:47 PM posted to rec.aviation.soaring
Tom Gardner
On Jan 12, 7:05*pm, bildan wrote:
*On downhill grades, the wheel motors would
Is that actually the case? I was under the impression
that the electrolyte will boil if you try to put energy into
batteries as fast as it can be taken out.
I'm more than happy to be corrected, if necessary.
  #213
Old January 12th 10, 09:42 PM posted to rec.aviation.soaring
bildan
With the old lead-acid liquid electrolyte batteries, that would be
true.
The new "fast-charge" lithium based solid electrolyte electric vehicle
batteries can take a full charge in less than 10 minutes. They also
have a far larger energy density and power density.
However, even this may not be good enough for heavy regenerative
braking - enter the Ultra-capacitor. Ultra-capacitors can charge
almost instantly then trickle the charge into a battery pack at a
charge rate that keeps it happy.
  #214
Old January 13th 10, 12:08 AM posted to rec.aviation.soaring
Martin Gregorie[_5_]
On Tue, 12 Jan 2010 08:12:31 -0800, bildan wrote:
On Jan 11, 6:56Â*pm, Martin Gregorie
outside temperature, drives a smaller car, and switches off phone
chargers when not in use, will an energy crisis be averted?
not a hardship - just put on a pullover over your T-shirt in winter.
rest but they're too chicken to mention it.
18 month old Lenovo laptop PSU (65w o/p) Â* Â* Â* Â*0 Â* watts. my much
older Thinkpad 560Z PSU (54w o/p) Â* Â* Â* 1.9 watts. iPAQ 3630 PSU (10w
o/p) Â* Â* Â* Â* Â* Â* Â* Â* Â* Â* Â* Â* 2.0 watts. 2001 Motorola T250 phone
charger (2.5w o/p) Â* Â* 0 Â* watts.
It which reads to 0.1 watts, so a reading of 0.0 should mean 50 mW
13 amp plug on the back and a 13 amp socket on the front, so you just
plug them in between the wall and the device you want to measure.
martin@ Â* | Martin Gregorie
org Â* Â* Â* |
I suspect the concept of "powered trailers" will pop up more frequently.
This is not an unproven concept since the mining industry has used it
for years.
wheels. If a glider trailer housed a large battery, possibly charged
with a large solar panel on top and wheel motors, it could minimize the
loads imposed on the towing vehicle by essentially powering itself. The
The whole car-trailer combo then becomes a parallel hybrid which permits
the use of a much smaller and less powerful car. The fuel savings while
towing would be small compared to the fuel savings achieved by driving a
small, fuel efficient yet tow capable car when not towing.
the airport.
That sounds good, practical, even. I've seen film of power trailers
behind Landrovers which seemed remarkably good at ploughing through mud
in off-road tests. Do you know if there are stability problems with these
rigs at highway speeds? I ask because I expect mining trailers would be
somewhat slower and the film didn't show anything operating at much over
10 mph.
martin@ | Martin Gregorie
org |
  #215
Old January 13th 10, 12:16 AM posted to rec.aviation.soaring
bildan
On Jan 12, 5:08*pm, Martin Gregorie
18 month old Lenovo laptop PSU (65w o/p) * * * *0 * watts. my much
older Thinkpad 560Z PSU (54w o/p) * * * 1.9 watts. iPAQ 3630 PSU (10w
o/p) * * * * * * * * * * * * 2.0 watts. 2001 Motorola T250 phone
org * * * |
I suspect the concept of "powered trailers" will pop up more frequently..
*This is not an unproven concept since the mining industry has used it
for years.
loads imposed on the towing vehicle by essentially powering itself. *The
the use of a much smaller and less powerful car. *The fuel savings while
the airport.
10 mph.
org * * * |
I guess it could be done wrong so stability problems ensued. However,
electric wheel motors create an opportunity for dynamic stability
control. One motor could be instantly braked while the other powered
forward to counter sway. Since the motors are directly coupled to the
wheels, this could happen at the speed of electronics. Accelerometers
in the trailer would sense sway. I would think it could be done in a
way to create dead solid stability.
  #216
Old January 13th 10, 12:17 AM posted to rec.aviation.soaring
bildan
On Jan 11, 7:34*pm, Eric Greenwell wrote:
Bruce Hoult wrote:
On Jan 11, 4:39 pm, Eric Greenwell wrote:
"Only 19 percent of the ice cover was over 2 years old, the least in the
satellite record and far below the 1981-2000 average of 52 percent."
I don't know about you, but it seems clear to me that if ice was at
the lowest level ever two years ago and has since staged a huge
recovery, then saying that 81% of the the ice cover is less than two
years old doesn't actually add any new information and certainly is
not bad news.
It has not staged a "huge" recovery. 2009 is the _third lowest year_ in
the 30 year satellite record. And the loss of multi-year ice is crucial:
"The ice cover remained thin, leaving the ice cover vulnerable to melt
in coming summers."
That's fromhttp://nsidc.org/news/press/20091005_minimumpr.html
While you are on that page, take a look at fig. 3 to see the extent of
the recovery.
And finally, the examination of the ice from ships found the ice was
less that the satellites were reporting:
"Recently published research by Barber and colleagues shows that the ice
cover was even more fragile at the end of the melt season than satellite
data indicated, with regions of the Beaufort and Chukchi Seas covered by
small, rotten ice http://nsidc.org/cgi-bin/words/word.pl?rotten%20ice
floes."
There is no good news from the National Snow and Ice Center, regardless
of the The Mail says.
Look at this:
http://climate.nasa.gov/news/index.c...ews&NewsID=242
  #217
Old January 13th 10, 08:36 AM posted to rec.aviation.soaring
delboy
org * * * |
not towing.
the airport.- Hide quoted text -
- Show quoted text -
Just a small practical problem, if you want to go at any speed.
Generally speaking the heavier the trailer is in relation to the
towing vehicle, the less stable the combination becomes. I suspect
that the concept of the trailer pushing a small car would make it even
more unstable.
Derek Copeland
  #218
Old January 13th 10, 09:33 AM posted to rec.aviation.soaring
Bruce Hoult
That's pretty impressive.
When I was towing a Grob two seater in (admittedly a pretty crappy
trailer) it reduced the range of my 2.5l Subaru on a 56l fill up from
about 620 km to about 350 km. Say, from 32 mpg to about 18 mpg.
http://hoult.org/bruce/Subaru_with_TA.jpg
To put it into the normal units used here, the car alone normally uses
about 9 l/100 km on a long trip, and the combo used about 16 l/100km.
That implies that the trailer used about 7 l/100 km, or 40 mpg.
I'm sure a Komet with a single seat glider would be much better, but
I'm surprised it's three times better.
I note in passing that my Subaru&trailer combo used only very slightly
more fuel than my Dad's 4.1 l Falcon station wagon does by itself.
One more point: for most of us outside the USA, I believe that the
practical lower limit on vehicle size for towing is governed not by
power (you can always change down and go slower when necessary) but by
the stability and controllability of the combo under braking and on
steep downhills. Too-small cars are ones that get shoved badly when
braking on downhill switchbacks, and ones that arrive at the bottom of
a couple of thousand foot descent with the brakes smoking.
Here in Wellington NZ, the benchmark is a run over the Rimutaka Hill
to the Wairarapa for a day's gliding at Jury Hill or Masterton. The
summit is only 1800 ft but it's enough to sort the good tow cars from
the bad ones (or stupid drivers who don't use engine braking).
  #219
Old January 13th 10, 01:17 PM posted to rec.aviation.soaring
On Wed, 13 Jan 2010 01:33:59 -0800, Bruce Hoult wrote:
I'm sure a Komet with a single seat glider would be much better, but I'm
That probably depends on what you're driving: a single seat trailer is
usually no higher than the tow car. If the latter is an estate (station
wagon) then hanging a trailer on it may only add rolling drag from the
extra axle plus skin friction drag. If the trailer cross section fits
behind the tow vehicle you've effectively lost its front surface drag and
transferred the tow vehicle's rear end drag to the rear of the trailer.
org |
  #220
Old January 13th 10, 03:15 PM posted to rec.aviation.soaring
bildan
org * * * |
for years.
the airport.
10 mph.
org * * * |
Just to clear up a small confusion, the powered trailer would never
'push' the towing vehicle. In fact, there would likely always be some
residual "pull" to prevent noisy load reversals.
contrails No Name Aviation Photos 3 June 22nd 07 01:47 PM
Contrails Darkwing Piloting 21 March 23rd 07 05:58 PM
Contrails Kevin Dunlevy Piloting 4 December 13th 06 08:31 PM
Contrails Steven P. McNicoll Piloting 17 December 10th 03 10:23 PM
