Vasi Papi Stumper question
Old December 27th 05, 02:05 PM posted to rec.aviation.ifr
Default Vasi Papi Stumper question
In the US, vasis provides a maximum of 4 ** nautical miles ** obstacle
protection and papi provides 4 ** statute miles ** of protection.
True or False
Stan
Old December 27th 05, 02:20 PM posted to rec.aviation.ifr
True or False
Stan
True
Old December 27th 05, 02:55 PM posted to rec.aviation.ifr
True or False
Stan
This is the kind of question that gives FAA knowledge tests a bad name.
Old December 27th 05, 05:50 PM posted to rec.aviation.ifr
I don't think it's *on* the written because I've never heard that before.
I didn't even realize that a vasi/papi had a specific clearance requirement.
What about private airports that just throw up a few boards?
Ben Jackson
http://www.ben.com/
Old December 27th 05, 06:03 PM posted to rec.aviation.ifr
They had better not "throw up a few boards" in disregard of FAA airport
standards. If they do, it might be some hungry attornies coming after
them someday, rather than the FAA.
Here is what the AIM says:
2-1-2. Visual Glideslope Indicators
a. Visual Approach Slope Indicator (VASI)
1. The VASI is a system of lights so arranged to provide visual descent
guidance information during the approach to a runway. These lights are
visible from 3-5 miles during the day and up to 20 miles or more at
night. The visual glide path of the VASI provides safe obstruction
clearance within plus or minus 10 degrees of the extended runway
centerline and to 4 NM from the runway threshold. Descent, using the
VASI, should not be initiated until the aircraft is visually aligned
with the runway. Lateral course guidance is provided by the runway or
runway lights.
What the AIM misses is that PAPIs are good to 4 statute miles because of
a different Airports advisory circular for airport owners. I doubt the
1/2 mile difference would ever be critical.
What is critical is to check the AFD to make certain that a VASI or PAPI
is not further restricted.
Old December 27th 05, 07:52 PM posted to rec.aviation.ifr
True or False
False
Old December 27th 05, 10:19 PM posted to rec.aviation.ifr
True or False
False
Check alt.binaries.pictures.aviation for a PDF I just uploaded, which
shows that VASI extends to 4 n.m. and PAPI to 4 s.m.
Note the fax date on the order, which was sent to me by the FAA in early
2004. This order was in effect for at least 23 years.
The best I can determine, this order quietly disappeared sometime in
mid-2004, making the siting for any *new* PAPI installations 4 nautical
miles, the same as VASI.
So, any PAPIs installed since mid-2004 are, or should be, 4 n.m. The
vast majority, however, have not been resurveyed (a airport authority,
not FAA, responsibility).
Old December 28th 05, 04:26 PM posted to rec.aviation.ifr
Thanks Tim. Helpful as always
Stan
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 05:03 AM
A question on Airworthiness Inspection Dave S Home Built 1 August 10th 04 05:07 AM
Question Charles S Home Built 4 April 5th 04 09:10 PM
Tecumseh Engine Mounting Question jlauer Home Built 7 November 16th 03 01:51 AM
Question about Question 4488 [email protected] Instrument Flight Rules 3 October 27th 03 01:26 AM
