Electrically Powered Ultralight Aircraft
Old August 14th 07, 04:37 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
Larry Dighera
Default Electrically Powered Ultralight Aircraft
On Tue, 14 Aug 2007 08:40:29 -0500, "Gig 601XL Builder"
wrDOTgiaconaATsuddenlink.net wrote in
Larry Dighera wrote:
On Mon, 13 Aug 2007 17:39:44 -0400, Dana M. Hague
d(dash)m(dash)hague(at)comcast(dot)net wrote in
safety if the batteries are damaged in a crash is still an issue.
I would think the hazard somewhat less than gasoline.
The battery can produce it's own ignition source.
You have a point. While a source of ignition (sparking wires, hot
muffler?) is required to ignite post-crash gasoline fumes, it would
take an un-fused short circuit or significant deformation of a battery
to potentially ignite a lithium battery. Granted, if the crash occurs
as a result of fuel exhaustion, there is little fire hazard, while the
lithium would always be aboard.
  #132
Old August 15th 07, 01:23 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
CanalBuilder
How much of a fire hazard would a paper battery be?
http://www.energy-daily.com/reports/...per _999.html
  #133
Old August 15th 07, 02:18 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
Larry Dighera
On Wed, 15 Aug 2007 12:23:00 GMT, CanalBuilder
wrote in
That is an interesting device indeed. Given these quotes from the
article:
Rensselaer researchers infused this paper with aligned carbon
nanotubes, which give the device its black color. The nanotubes
act as electrodes and allow the storage devices to conduct
electricity. The device, engineered to function as both a
lithium-ion battery and a supercapacitor, can provide the long,
steady power output comparable to a conventional battery, as well
as a supercapacitor's quick burst of high energy. ...
Along with use in small handheld electronics, the paper batteries'
light weight could make them ideal for use in automobiles,
aircraft, and even boats. The paper also could be molded into
different shapes, such as a car door, which would enable important
new engineering innovations.
"Plus, because of the high paper content and lack of toxic
chemicals, it's environmentally safe," Shaijumon said. ...
"It's a way to power a small device such as a pacemaker without
introducing any harsh chemicals - such as the kind that are
typically found in batteries - into the body," Pushparaj said.
I find the article to be somewhat contradictory in its characterizing
a lithium-ion battery as containing no harsh chemicals. And its claim
of using carbon electrodes in a supercapacitor seem very
counterintuitive for a low impedance device. It reads like an April
Fools Day hoax.
  #134
Old August 17th 07, 04:03 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
Charles Vincent
In rec.aviation.piloting Tim Ward wrote:
The advantage from the electric engine at cruise is that it uses zero
energy.
Snippage
Jim Pennino
Remove .spam.sux to reply.
You want to support this, somehow?
Tim Ward
At cruise the electric motor is turned off.
The only energy used is some slight bearing friction.
The electric motor is only turned on when more power than the gas
engine can provide is needed.
To carry more weight at the same speed and altitude takes more power, so
you have to account for the energy expended kiting you deadweight
electric takeoff system around the sky as well. Sizing an engine for
cruise has been done, if only backwards. Think JATO. Most JATO's are
actually RATO (rocket assisted takeoff). I expect RATO would beat an
electric system based on energy density and the fact that when it is
done you have reduced your weight by the fuel. I also suspect for a
given amount of thrust the rocket will be lighter than an electric motor
and associated clutches and gearing. In my opinion, at this point in
time it is just as practical for a homebuilt as well as in not.
Charles
  #135
Old August 17th 07, 04:35 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
energy.
Snippage
Jim Pennino
Tim Ward
Well, that's true enough, but the above was about hybrid cars.
Jim Pennino
  #137
Old August 17th 07, 05:04 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
Charles Vincent
energy.
Snippage
Jim Pennino
Tim Ward
Well in cruise in a car, more weight does not increase your aerodynamic
drag like it does on an airplane, but it does increase your rolling
resistance in the real world, so there is no free lunch. Different
tradeoffs for different missions. I guess that is why cheetahs and
sparrows look so different.
Charles
  #138
Old August 17th 07, 05:15 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
No, it's not true enough.
To carry more weight at the same speed and altitude requires more LIFT.
A higher CL - and/or more wing area.
THEN, to overcome the increased drag, THEN you need more power.
But more power by itself won't satisfy the constraints...
So if I add 1 pound to a 2400 pound gross aircraft loaded to 2300 pounds,
it would be impossible to cruise at the same speed and altitude without
the 1 pound unless I added wing area?
How about 50 pounds?
Jim Pennino
  #139
energy.
Snippage
Jim Pennino
Tim Ward
Unless the added weight is enough to deform the tires, the increase
in rolling resistance in the total energy expediture can't be found.
Jim Pennino
  #140
Old August 17th 07, 05:25 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
Charles Vincent
so you have to account for the energy expended kiting you
deadweight electric takeoff system around the sky as well. Sizing
an engine for cruise has been done, if only backwards. Think JATO.
Most JATO's are actually RATO (rocket assisted takeoff). I expect
RATO would beat an electric system based on energy density and the
fact that when it is done you have reduced your weight by the fuel.
I also suspect for a given amount of thrust the rocket will be
lighter than an electric motor and associated clutches and gearing.
In my opinion, at this point in time it is just as practical for a
The original remark said "To carry more weight at the same speed and
altitude takes more power" -- which you have now taken the time to
substantiate with more detail. It never said it was the only factor,
and didn't need to, to rebut the earlier claim. I do not understand how
you arrive at it not being true. Frankly, I would expect any one
engaged in building or flying an airplane to understand those
relationships, and based on the FAA's published pilot exam questions and
other materials, it seems they agree.
Charles
Electrically Powered Ultralight Aircraft Larry Dighera Piloting 178 December 31st 07 08:53 PM
Solar powered aircraft. Was: Can Aircraft Be Far Behind? Jim Logajan Piloting 4 February 9th 07 01:11 PM
World's First Certified Electrically Propelled Aircraft? Larry Dighera Piloting 2 September 22nd 06 01:50 AM
Powered gliders = powered aircraft for 91.205 Mark James Boyd Soaring 2 December 12th 04 03:28 AM
Help! 2motors propelled ultralight aircraft [email protected] Home Built 3 July 9th 03 01:02 AM
