Lycoming O-360 ring gear
Old January 10th 06, 08:58 PM posted to rec.aviation.owning
Default Lycoming O-360 ring gear
George Patterson wrote:
snip
When re-sleeving cylinders on motorcycles, we used to stick the sleeve in the
freezer overnight and heat the cylinder to 400 degrees.
snip
Yup.
Didn't have an oven in the shop, so ring gear supports went into the
freezer and the gears got heated on a steel worktop with a rosebud
torch tip until saliva sizzled on your finger like a hot iron used on
cotton/linen.
Just enuff of the ring gear hanging over the edge of the bench to grab
it with a pair of pliers and plop it on the support. Helpful if you've
got someone standing by with a couple more pairs to hold the ring gear
firmly down against the flange while it's cooling.
TC
Saratoga Gear Retract Problem Yahoo! News Owning 16 November 29th 05 11:17 PM
Jet engines vs. leaf blowers 01-- Zero One Soaring 6 September 8th 05 01:59 AM
A&P heroics Jim Piloting 31 July 18th 05 07:26 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 1 November 24th 03 02:46 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 06:24 AM
