FAA sticks to its guns on not allowing solo glider flight for out ofcurrency power pilots
Old May 4th 16, 12:56 AM posted to rec.aviation.soaring
Brian[_1_]
Default FAA sticks to its guns on not allowing solo glider flight for outof currency power pilots
On Sunday, May 1, 2016 at 10:24:29 PM UTC-6, Bill T wrote:
If by Bill, you mean me?
It is my understanding that The FAA no longer considers a pilot with a certificate, a student. They are a rated pilot in search of additional ratings.
Hence they do not require a written test going from airplane to glider. As shown in other posts on RAS, the way to be considered a student is to turn in all your certificates and start from scratch, a student, complete with written tests and student limitations,
BillT
Thank BillT, but I have yet to see any documentation that supports this "Understanding"
The issue of course is that a rated pilot without a current flight review can not solo under FAR 61.31. But all they need is the ability to Solo using Student pilot privileges to complete the requirements to take a check ride..
The FAA could fix this very easily with a letter that states (or revokes previous understandings) that Student pilot privileges are included with any higher certificate. Then there is no need for a pilot to use FAR 61.31 to solo, since they can complete their solo requirement under FAR 61.87 instead..
Brian
  #32
Old May 4th 16, 02:59 AM posted to rec.aviation.soaring
Brian,
http://www.faa.gov/about/office_org/...rpretation.pdf
FAA is pretty clear
  #33
Old May 4th 16, 07:10 PM posted to rec.aviation.soaring
Brian[_1_]
On Tuesday, May 3, 2016 at 8:00:51 PM UTC-6, wrote:
Brian,
FAA is pretty clear
Ok, my mistake, I had already admitted that I hadn't fully read the Beard Letter, I should have. It does pretty clearly state that they "Understand" once you have a higher rating, one no longer has student privileges. This is interesting, since this it not the case for other ratings certificates, like sport Pilot or private pilot privileges, if one has a commercial certificate.
Will be interesting to see how the FAA fixes this problem.
Brian
  #34
Old May 13th 16, 09:30 PM posted to rec.aviation.soaring
Call your local FSDO. Mine said just keep doing what you have been doing for past 40 years.
  #35
Old May 13th 16, 10:58 PM posted to rec.aviation.soaring
Great FSDO.........
  #36
Old May 14th 16, 01:41 PM
Walt Connelly Walt Connelly is offline
Senior Member
First recorded activity by AviationBanter: Aug 2010
Quote:
I'd get that in writing........
Walt
  #37
Old May 15th 16, 09:55 PM posted to rec.aviation.soaring
Bill T
Until the smart DPE starts looking in the applicants log book for the last Flight Review endorsement.
Soon Flight Review endorsements may need to be filed electronically through IACRA, then the computer will check for current FR when adding a rating.
No getting around that.
BillT
Sooo ... Glider pilots DO make good jet pilots! AS Soaring 2 November 30th 15 09:02 AM
50,000 Power Pilots Charlie Papa[_2_] Soaring 5 April 25th 15 05:16 PM
allowing guns in cockpits Private Piloting 141 January 12th 08 06:47 AM
Why Screeners Miss Guns and Knives (and why pilots miss planes and airports) cjcampbell Piloting 2 January 3rd 06 04:24 AM
pilots with guns spoof gatt Piloting 1 May 25th 05 09:37 PM
