Oxygen Bottle for ASW 20
Old February 14th 19, 11:27 PM posted to rec.aviation.soaring
Deming Gray
Default Oxygen Bottle for ASW 20
Hello,
I want to install an oxygen bottle in my ASW20. I haven't found any documentation on what size bottle should be installed. I tried a search on this site and there are loads of posts regarding oxygen but I couldn't get them to open. Anyone know why? Anyone have any information on the size of oxygen bottle to use in an ASW 20?
Thanks,
Deming
Old February 15th 19, 12:00 AM posted to rec.aviation.soaring
Several years ago, a pilot who had relocated from Florida to Moriarty with an ASW-20C had me install an O2 system. By enlarging the fuselage bulkhead hole down by the pilot's right elbow, I was able to fit a Mountain High AL-682 cylinder. This is the largest capacity cylinder available for use in a -20. It is also the one I use in my Pegasus, which has a nearly identical cockpit. The diameter of the AL-682 (and the shorter AL-415) is 4.4 inches. It fits in the existing clamp, but the padding must be removed. If you do not have a clamp, one must be fabricated or possibly ordered from Schleicher.. Call or email me if you need more info. You have my number and email address.
Old February 15th 19, 01:03 AM posted to rec.aviation.soaring
Tango Eight
On Thursday, February 14, 2019 at 5:27:47 PM UTC-5, Deming Gray wrote:
Hello,
Thanks,
Deming
You need a steel (not aluminum) E size bottle. These may vary a little in OD and smaller is better (4.18" is the magic number iirc). The aluminum E size bottles are too big.
Something like this:
https://www.cramerdeckermedical.com/...product_id=430
best,
Evan Ludeman / T8
Oxygen bottle for ASW 27 and ASG 29 [email protected] Soaring 8 April 18th 16 04:08 PM
Oxygen Bottle Roger Fowler[_2_] Soaring 2 November 19th 11 10:17 PM
WTB: Oxygen bottle Jason Kramb Soaring 5 February 2nd 11 04:33 AM
oxygen bottle No Name Piloting 2 May 23rd 07 07:09 AM
DG-400 Oxygen Bottle Problems [email protected] Soaring 23 September 8th 05 10:43 PM
