dropped plug in engine
Old May 24th 07, 02:58 PM posted to rec.aviation.owning
Default dropped plug in engine
What is the best way to get a spark plug out that has been dropped
while being changed?
Old May 24th 07, 10:40 PM posted to rec.aviation.owning
Jon Kraus
and then shell out another $15.00 for a $1.50 item...
Jon
Out of what? Out of the engine? Presumably it was out while it was being
dropped? I think we need a little more detail about what you are trying
to do and why you are having trouble doing it. DB
The rule of thumb on dropping spark plugs is to drop it twice:
1. Accidentally on the floor
2. Into the trash.
Old May 25th 07, 12:46 AM posted to rec.aviation.owning
David Lesher
Dave Butler writes:
It's hard-pressed to fall into the cylinder, so I gather it fell
somewhere inside the cowl?
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
Old May 25th 07, 11:35 AM posted to rec.aviation.owning
Ron Natalie
2. Into the trash.
To paraphrase one of my professors (he was referring to blown transistors):
Put it in your pocket.
Take it a long way from the airport and throw it away so
it never finds it's way back.
Consequences of dropped spark-plug? Kensandyeggo Home Built 4 June 27th 06 02:13 AM
Dropped Spark-Plug Consequences? Kensandyeggo Owning 3 June 27th 06 01:46 AM
Mk 13 Air Dropped Torpedo Kyle Boatright Naval Aviation 15 January 2nd 06 11:48 PM
Cowl / Engine Plug Recomendations for 1964 - C172 Skyhawk ??? Philip Products 0 April 22nd 04 12:58 PM
dropped in D Arden Prinz Piloting 35 August 7th 03 02:23 PM
