Comm noise
Old August 30th 08, 12:17 AM posted to rec.aviation.owning
Morgans[_2_]
Default Comm noise
"RST Engineering" wrote
Orval, you are chasing your tail. If it does it on BOTH radios, the
probability of a dual identical fault is practically zero, especially if
the noise on #1 correlates with the noise on #2.
Sure, go ahead and shotgun the thing and then come back in here lamenting
that you spent $X amus on the problem and it is still there.
I'm with you, on this point.
Do you have any ideas on what possible things to look at (to trouble-shoot
it) to figure out what the real problem is, yet?
Jim in NC
Old August 30th 08, 04:22 PM posted to rec.aviation.owning
RST Engineering
Default Comm noise
Sure. Does it do it with just the master switch on, sitting on the ground,
engine off. Engine on and idle. Engine on taxiing. Engine on runup.
Engine on takeoff roll. Engine on climbout...
What is the LEAST active thing the airplane is doing when it starts. Does
it always happen, say, ten minutes into the flight? Or does it do it on the
ground in the same ten minutes? Does it start in the air and continue after
landing?
An hour's logical troubleshooting can save dozens of hours shotgunning the
problem.
"It is the mark of an educated mind to be able to entertain a thought
without accepting it."
--Aristotle
"Morgans" wrote in message
Jim in NC
Old August 31st 08, 06:28 AM posted to rec.aviation.owning
David Lesher
Default Comm noise
"RST Engineering" writes:
probability of a dual identical fault is practically zero, especially if the
Do the two radios have separate antennas, or do they share a single point
of failure?
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
Old August 31st 08, 08:14 PM posted to rec.aviation.owning
Peter Clark
Default Comm noise
Wouldn't taking a meter to the coax where it attaches to the radio
tray tell whether the cable and/or antenna has a problem?
On Sat, 30 Aug 2008 08:22:33 -0700, "RST Engineering"
landing?
problem.
Old September 1st 08, 04:57 PM posted to rec.aviation.owning
RST Engineering
Default Comm noise
Have you ever seen two com radios sharing a single antenna? Tell me how you
do it without the transmitter of #1 blowing up the receiver of #2. Unless
you are talking about dual Genave A-200s/Escort 110s and the ilk that used
two antenna inputs, one for the transmitter and one for the receiver.
--Aristotle
"David Lesher" wrote in message
of failure?
Old September 1st 08, 04:58 PM posted to rec.aviation.owning
RST Engineering
Default Comm noise
The odds of finding the problem that way lie somewhere between the odds of
winning an argument with an umpire and an argument with your wife.
--Aristotle
"Peter Clark" wrote in message
Old September 1st 08, 05:34 PM posted to rec.aviation.owning
john smith
Default Comm noise
I'll take my chances with the umpire.
Old September 3rd 08, 04:36 PM posted to rec.aviation.owning
David Lesher
Default Comm noise
I thought Nav antennas were typically shared. I mention this because I
have seen non-aircraft multi-antenna multi-front-end receivers where
weirdness on one antenna appeared to be on the other.
Old September 3rd 08, 06:07 PM posted to rec.aviation.owning
Mike[_22_]
Default Comm noise
you
A Nav only antenna doesn't transmit, which is why they can be shared easily.
It's possible to share comm antennas, but you need either a transmit switch
or duplexer of some type to protect the receiver.
Old September 3rd 08, 06:49 PM posted to rec.aviation.owning
RST Engineering
Default Comm noise
First of all, the OP said it was his COM radio that was affected; NAV wasn't
mentioned.
Second, to use the correct terms, Nav antennas are isolated in a splitter
where a defect in one radio does not affect the other. Google "Wilkinson
splitter" for a technical description. "Shared" doesn't convey the full
effect of what has to happen; that implies that you just run both radios to
a single antenna without any isolation device in the path.
--Aristotle
Comm 120 Tri-Pacer Owning 2 July 31st 07 04:59 PM
FAA paper Noise Attenuation Properties of Noise-Canceling Headsets Jim Macklin Piloting 26 January 13th 07 12:06 AM
FAA paper Noise Attenuation Properties of Noise-Canceling Headsets Jim Macklin Instrument Flight Rules 15 January 13th 07 12:06 AM
360 Comm Tri-Pacer Home Built 3 August 5th 06 04:09 PM
Prop noise vs. engine noise Morgans Piloting 8 December 24th 03 03:24 AM
