Landing Gear
Has anyone had experience building landing gear from motorcycle forks?
On 10 Apr 2004, Lou Parker wrote:
Has anyone had experience building landing gear from motorcycle forks? The good news Lou, is that you don't need anything that complicated. A very small bit of time is spent rolling on the ground. Some gear use only the tires to absorb the landing loads. Keep it simple, and light. George Graham RX-7 Powered Graham-EZ, N4449E Homepage http://bfn.org/~ca266 |
Has anyone had experience building landing gear from motorcycle forks? ------------------------------------------------------ Dear Lou, Sure. Lotsa folks. See Roger Mann's RW-19 for a nice example of a long-travel landing gear. He uses the oleo-pneumatic element off a big dirt bike, combined with a stiffer after-market spring. Gives him something like 10" of travel and you really have to see one of his landings to believe it. (The RW-19 and RW-20 are 2-place clones of the Storch.) -R.S.Hoover |
Similar Threads | ||||
Cessna landing gear legs Reserve MET! | Bill Berle | Home Built | 1 | February 23rd 04 12:31 AM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 1 | November 24th 03 02:46 PM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 2 | November 24th 03 05:23 AM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 0 | November 24th 03 03:52 AM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart D. Hull | Home Built | 0 | November 22nd 03 06:24 AM |
