TE probes
Old June 18th 13, 02:09 PM posted to rec.aviation.soaring
4Z
Default TE probes
I suspect that a repair I did recently on the TE probe on my DG 800B
didn't work. So it's time to get a replacement. My factory probe is
8mm but the end that fits into the receptacle has a small reduced
diameter section (4mm) that must fit into a reduced diameter hole
inside the receptacle. My previous gliders didn't have this smaller
section. So my question is, does any replacement probe have to have
this arrangement, or can I just plug in an 8mm probe if it seals
properly?. I'd like to get it right cause these things aren't cheap.
Thanks, Tim
Old June 18th 13, 03:07 PM posted to rec.aviation.soaring
jfitch
Default TE probes
Thanks, Tim
These are two concentric tubes with different pressures in them, aren' they? Hence "double probe"? Mine has three concentric tubes, or a triple probe. Static, pitot, and suction. Depending on what is hooked up to what, putting a single tube in there might give you some interesting instrument readings....
Old June 18th 13, 03:49 PM posted to rec.aviation.soaring
StaPo
Default TE probes
You can adapt 8mm multiple type probe installation
to single 8mm TE probe via joining existing 2-3 hoses outputs together via T-piece(s).
But do simple leak test on the ground before flight testing to avoid "interesting" instrument readings...
Old June 18th 13, 05:49 PM posted to rec.aviation.soaring
jfitch
Default TE probes
But you will have only a single probe system then (probably suction) and he is starting with a double probe...fine if nothing is connected to static or pitot.
CHT probes flybynightkarmarepair Home Built 4 May 14th 07 06:07 AM
New TE Probes Paul Buchanan Soaring 0 August 21st 06 08:53 PM
WTB CHT probes [email protected] Home Built 6 August 11th 04 06:46 PM
WTB CHT probes [email protected] Aviation Marketplace 6 August 11th 04 06:46 PM
WTB CHT probes [email protected] Owning 6 August 11th 04 06:46 PM
