Club Class gliders and Handicaps in Polish Nationals June 2018
Old May 8th 18, 11:54 PM posted to rec.aviation.soaring
Default Club Class gliders and Handicaps in Polish Nationals June 2018
This interesting list shows what gliders will fly in Polish Nationals, Club Class, Leszno, Poland, June 8-16, 2018
http://www.aeroklub.leszno.pl/zawody...ta-zawodnikow/
Handicap table
http://www.aeroklub.leszno.pl/zawody...20-%202018.pdf
Andre
Old May 9th 18, 03:11 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Handicap table
Andre
The FAI Club classs list is at https://www.fai.org/sites/default/files/sc3ah_2018a.pdf . A lot of changes; SZD-55 and ASW-24 used to have the same handicap if I recall correctly.
Interesting that Poland has Club A and B; I guess it makes it more fair to have a closer range of gliders to race against.
Old May 9th 18, 03:44 PM posted to rec.aviation.soaring
Paul T[_4_]
The new 'silly list' designed by guys with no common sense- based on
some asinine theory which ignores 20-30 years of RL competition
performance comparison.
Are they really still using this handicap list for the Worlds? Better get
an SZD55 if you want to win then..... - notice the Poles have, and are
not flying the usual Brawo/Jantar Std 3. Wouldn't want to be flying a
Mosqiuto though.
Old May 9th 18, 03:50 PM posted to rec.aviation.soaring
Paul T[_4_]
Mosqiuto though.
P.S. a SZD55 in good condition can p.ss all over a Discus.
Old May 9th 18, 03:57 PM posted to rec.aviation.soaring
krasw
Mosqiuto though.
AFAIK at least one other team chose to change their gliders to 55's.
Old May 12th 18, 05:04 AM posted to rec.aviation.soaring
ASM
I saw a ****load of Jantar 2’s and 3’s on the list of competitors.
Old May 12th 18, 07:14 AM posted to rec.aviation.soaring
krasw
Mosqiuto though.
I have flown Discus in a team with friend flying 55 (several nationals + international comps). We found out that when gliders have no bugs, Discus has very small advantage, but during day 55 goes better and better (we did not have bug wipers those times). When it started to rain, 55 disappeared forward and up, Discus did not stand a chance. But to be honest, 95% of the time there was no difference between gliders. When flown dry 55 suffers a bit from very low empty weight (at least those first gliders from early 90's), it climbs like a balloon but I think 30-40 kg of water is needed unless you just try to stay airborne.
Old May 12th 18, 08:50 AM posted to rec.aviation.soaring
Paul T[_4_]
At 04:04 12 May 2018, ASM wrote:
I saw a ****load of Jantar 2=E2=80=99s and 3=E2=80=99s on the
list of
compe=
titors.
For the Polish Nationals? To be expected.
For the Worlds - 3 listed at the moment - usually a lot more.
Anyway does not take away from the handicapping discrepancies in the
'new' FAI list.
Old May 12th 18, 12:41 PM posted to rec.aviation.soaring
For South African club class competitions, there are three handicap lists depending on the strength of the day. The strength (weak, intermediate or strong) and which list is applied depends on the speeds of the winning gliders. For example, the system recognises that on week days and slower speeds, there is little difference between a Std Class and 15m Class glider. As the speeds go up - the advantage of having flaps increases and so the handicap for the 15m gliders increases relatively to the Std gliders. It's an attempt to try get a very broad range of gliders to compete with some sort of fairness in a wide range of conditions. No handicap system will have all the pilots happy - but least the South African approach does take cognesence of the fact that the conditions of the particular day may favour one glider over another.
2018 Standard Class Nationals [email protected] Soaring 5 February 9th 18 09:39 PM
Polish Gliding Commission bans modern ships from there Standard Class Nationals! [email protected] Soaring 9 February 8th 14 05:02 PM
Club Class Nationals 5 ugly Soaring 37 September 24th 10 03:27 AM
2007 Sports Class Nationals 12-21 June at Caesar Creek Soaring Club near Waynesville Ohio 2007 Sports Class Nationals Soaring 1 November 28th 06 01:02 PM
UK Open Class and Club Class Nationals - Lasham Steve Dutton Soaring 0 August 6th 03 10:07 PM
