#11
Moving Gliders
On Tuesday, May 8, 2018 at 8:49:57 PM UTC-5, Paul Agnew wrote:
Best practices for moving gliders around? Stacking the hangar... Staging... Clearing the runway... I've recently been told that the Europeans never move a glider by the wingtips, but it's almost a necessity when stacking our hangar. (Gliders are on wheel sleds, so the load is not high.) Things can be tight and we often need someone on each wing to prevent hangar rash, but don't have someone as a wingroot pusher. There are some significant some differences of opinions due to various culture and practices differences from previous clubs. So, what does your club do? Paul A. I suppose if you really leaned on a wing tip, say 80 lbs worth of 'grunt" you might exert 2000 lbs on a forward or aft root pin location, 4000lbs if the pin is only 6 inches from the spar. Not an insignificant force. Scott. |
Moving Gliders
On Wednesday, May 9, 2018 at 5:07:21 AM UTC-7, Bruce Hoult wrote:
1) what is the function of "drag pins" In typical sailplane practice, there are no "drag pins" per se; drag and thrust loads are accommodated by a torque couple comprised of spanwise tension outboard on the wing main spar and spanwise compression inboard applied between the flat faces at the root of the lift pin and at the end of the pin socket it fits into. The loads reacted in this manner are primarily forward thrust loads, which in the normal flight envelope are much greater than the drag loads. Of course, abnormal overloads are most often drag loads applied when the wingtip encounters an obstacle on takeoff or landing. 2) how much load is put on things by pushing a glider around by the wing tips compared to opening the brakes at high speed, or by a Vne dive with brakes open? (and is either "necessary"?) Just for arguement, let's consider a 15m glider with VNE-limiting airbrakes going straight down. Our hypothetical glider has a non-lifting mass of 500 lbs, so we know that the the brake on each wing is delivering 250 lbs of drag into the fuselage. Each airbrake is located 100" outboard of the root. The distance between the wing main spar and the aft lift pin is 12". Simple statics suggests that the compression force applied at each aft lift pin is on the order of 250lbf*100"/12" = ~2080 lbf. For comparison, this compression force would be developed by an aft pull on the wingtip of 2080lbf*12"/300" = ~83 lbf. As I recall, US FAR Part 23 and the very similar JAR/CS 22 specify that a normal category glider be able to accommodate a 100 lbf chordwise force at the wingtip unless lower can be rationally justified. My impression is that most gliders are certificated to lower tip forces, the rational justification being "we handle them with care." As I understand the issue at the root of this discussion, the problem is not so much overloads, but rather wear between the lift pins and sockets. Gliders being moderately limber, when you apply a chordwise force at the tip it separates the pin and socket from full engagement by some small but non-trivial amount; let's guess around 0.020" (0.5mm). And when the force is removed or reversed, the pin and socket go back together. Repeated cycles of this half-mm movement can, over time, result in wear and looseness. Remember that the wings typically weigh between 120 and 180 lbs each, so that's a vertical force of 60 to 90 lbs at each pin and socket connection while they're being worked in and out. For the gliders I've designed, my advice is that an occasional chordwise force at the tip of up to 50 lbf while parking or moving the glider is not an issue. However, repeated cycles, for example when moving the glider from one end of the runway to the other, should be avoided when practical. --Bob K. |
Moving Gliders
As I recall, US FAR Part 23 and the very similar JAR/CS 22 specify that a normal category glider be able to accommodate a 100 lbf chordwise force at the wingtip unless lower can be rationally justified. My impression is that most gliders are certificated to lower tip forces, the rational justification being "we handle them with care." I looked it up. JAR 22.501 Wing-tip landing "There must be means to ensure that ground loads acting at the wing tips are adequately resisted. A limit load T = 40 daN must be assumed to act rearward at the point of contact of one wing-tip with the ground, in a direction parallel to the longitudinal axis of the sailplane, the yawing moment so generated must be balanced by side load R at the tail skid/wheel or nose skid/wheel (see Figure 4)." 40 daN of force at the wingtip works out to about 89.9 pounds-force. That's pretty close to your recollection of 100 lbf. I don't know what your average wing-walker can generate in terms of pushing force. (I can't say I've ever placed a bathroom scale on the wall and pushed on it with all my strength). I also don't know what kind of standards were required for the older antique gliders; they may have been certified before JAR-22 was even a thing. I still don't let people help push my Duo from the wingtip. Come in-board to the spoilers if you want to push. |
Similar Threads | ||||
Moving Pictures 7/16/15 | Byker | Aviation Photos | 0 | July 16th 15 09:07 PM |
Moving Pictures 7/16/15 | Byker | Aviation Photos | 0 | July 16th 15 09:06 PM |
PDA for Moving Map | brian whatcott | Soaring | 18 | December 20th 09 02:52 AM |
Moving to CA | Ishrat Zahid | Piloting | 30 | May 20th 04 10:59 PM |
