Ignition switch, what happen when Left or Right is selected
Old May 20th 05, 01:55 PM
Dave Butler
Wade wrote:
I've been taught this shtudown procedure, too.
But, what is the magic about turning them BOTH off, simultaneously?
If, at idle, you turned off the left mag, and noted an rpm drop,
then turned off the right one, and also noted an rpm drop,
then doesn't that confirm the same thing as turning
both of and feeling for the engine to start to shut-down?
The procedure you suggest does not test the OFF position of the switch itself.
These cheesy switches have been known to fail that way.
  #42
Old May 21st 05, 04:55 AM
George Patterson
No. Turning off the left mag verifies that that position of the switch will
ground out the left mag. Turning off the right verifies that the switch will
ground out the right mag in that position. You can only verify that "off" really
grounds out both mags by turning the switch off.
George Patterson
"Naked" means you ain't got no clothes on; "nekkid" means you ain't got
no clothes on - and are up to somethin'.
American nazi pond scum, version two bushite kills bushite Naval Aviation 0 December 21st 04 10:46 PM
Hey! What fun!! Let's let them kill ourselves!!! [email protected] Naval Aviation 2 December 17th 04 09:45 PM
Accidents happen... Manuel Piloting 26 November 28th 04 11:32 AM
LEFT WINGERS IN FOR BIG SURPISE - STROKES TO FOLLOW ELECTION Jarg Military Aviation 3 April 20th 04 06:37 PM
