Winpilot and Colibri Problems
Old May 30th 05, 03:54 AM
ttaylor at cc.usu.edu
Default Winpilot and Colibri Problems
I am running a system that includes WinPilot running on an Ipaq 37XX
series, Colibri GPS/logger and Borgelt B50. The system is very
unstable and will usually only run for an hour at the most and often
only a few minutes before it crashes or gives an error message.
I get a "lost GPS signal" quite often even though the colibri is
showing nine satellites and a 3D lock. Other times the Ipaq just
locks up and has to have the reset button pushed to get it running
again.
I have spoken to an other pilot with the same configuration and he is
having similar problems.
Has anyone dealt with this and found a solution or has any ideas of
what ot do to fix this?
Tim
Old May 30th 05, 04:35 AM
Marc Ramsey
If there is too much GPS data being passed through the B50, its output
will be garbled, which will occasionally cause software running on the
PDA to lock up. In the case of the Colibri, there is an NMEA
configuration screen that determines the set of NMEA sentences that it
outputs. You probably need to disable all sentences except those that
are actually used by WinPilot.
Marc
Old May 30th 05, 04:53 AM
Marc, Having the same trouble with WinPilot running on an Ipaq 37xx
with a Cambridge GPS. Cambridge has been updated with new battery. Any
ideas, Tom
Marc
Old May 30th 05, 06:17 AM
Eric and Marc,
Thanks for the replies.
Marc, I have the Colibri set up following the Winpilot recommendations
of GPGGA and GPRMC outputs. I can try turning them off one at a time.
Eric, I checked and the IR port is turned off. So hopefully that is
not the problem.
I will try some test to see if things improve. I would like to get
this all worked out before heading to Ely next week.
Thanks,
Tim
Old May 30th 05, 06:35 AM
Jancsika
As I know winpilot use these NMEA sentences. So if you disable them it
won't work at all...
not the problem.
Try to log the nmea output (as suggested on the winpilot page).
"1. How do I troubleshoot cable connection between my GPS/Logger and
Windows CE device?
We have written a special application to make it easier. Right-click on
one of the links below , save it on your PC, and transfer it to your
Windows CE device to \Windows\Start Menu directory. You should then be
able to start it from the Start button menu. The application shows if
NMEA data is arriving to the serial port, and saves the incoming data
into a file named NMEA_Log.txt. WinPilotTTy for MIPS WinPilotTTy for
iPAQ "
Do not use any tweak software/hardware (overclocking, special system
functions etc-etc).
/Janos
Old May 30th 05, 06:41 AM
Marc Ramsey
Eric and Marc,
I'm not a WinPilot user, but if you have just GPGGA, GPRMC, plus the
LXN-specific sentence that outputs pressure altitude, your B50 should be
able to handle that amount of data without problem.
I'll be at Ely, so if you haven't solved it by then, I can take a look...
Regards,
Marc
Old May 30th 05, 01:31 PM
Tim
The colibri NMEA output should be GPGGA, GPRMC, LXWpx all YES, Baud
rate 4800, and make sure the infared port in off in the ipaq.
If this does not fix your problem, then I would look to the cabling
quite possibily a bad connection.
Richard
www.craggyaero.com
again.
Tim
Old May 30th 05, 01:43 PM
Tom,
Make sure the beam is off on your ipaq. Start, Settings,
Connections, Beam, uncheck box.
The green light on the GPS NAV blinks when there is a GPS lock, solid
light then you don't have a GPS lock. If you get error messages when
the GPS-NAV is solid then there may be a problem with a weak GPS
engine in your GPS-NAV.
If the GPS_NAV is blinking and you get the message then possibly a
problem with the wiring or the connectors.
Richard
www.craggyaero.com
Old June 6th 05, 06:44 PM
An Update:
Marc, Eric, Richard, Al and Janos
Thanks for the suggestions. On my last flight the system worked
flawlessly for the entire flight.
I did not do the conversion scientifically, i.e. one change at a time
so I don't have the definitive answer to what was wrong. I made
three major changes at one time so that any or all may have made the
difference.
Al let me know one of my Ipaq's may have a problem. I also noticed
that the one I was using was having trouble syncing with my desktop
computer the last few weeks. This would indicate a com port problem on
the unit.
I was not using the LXWpx string from the Colibri. I turned that on.
I upgraded WinPilot to the 6.07 version from the 5.xx version I had.
Jerry at WinPilot was very helpful as well as Richard at Craggy Aero.
A side note, I love the new GO TO feature in WinPilot 6.0. I think
this is worth the upgrade by itself.
I confirmed the autobeam infrared function was off on both of my Ipaqs.
So after changing to my second Ipaq 3760, upgrading the software and
turning on the LXWpx stream the system is rock solid stable. I even
tested it by turning off the Colibri and then back on. The WinPilot
would note the data stream was lost, but resume working as soon as the
Colibri was sending data again.
Thanks,
Tim
