How to shorten a Tach drive cable?
Old August 29th 07, 09:32 PM posted to rec.aviation.homebuilt,rec.aviation.owning
Dave[_16_]
Default How to shorten a Tach drive cable?
I need to replace the tach cable in a friends plane. The inner part is
what needs replacement. I have access to another cable but the inner
part is too long.
How can I shorten the cable? The end is square and appears to have been
put into a press to form it.
I tried to square up a piece of cable from the old one, with no success.
i attempted to pound it square with a vise and hammer.
I was looking for an old time speedo shop here in dallas to help me with
this, but I can't seem to find them any more. I guess the modern cars
have put them out of business.
Any suggestions?
Dave
Old August 29th 07, 10:24 PM posted to rec.aviation.homebuilt,rec.aviation.owning
Morgans[_2_]
"Dave" wrote
Auto replacements for spedo cables usually have a fitting that is placed on
one end of the cut to length cable, and crimped in place. The fitting has
the square part on it.
It will be nearly impossible to shape your own end, short of brazing the
end, then grinding down to the desired square shape.
Jim in NC
Old August 29th 07, 10:44 PM posted to rec.aviation.homebuilt,rec.aviation.owning
Jim Stewart
And it will be damn near impossible to get
braze to stick to something so impregnated
with grease.
Old August 30th 07, 12:00 AM posted to rec.aviation.homebuilt,rec.aviation.owning
Mike Noel
....and you can get a new tach cable from Chief for about $30.
http://www.chiefaircraft.com/airsec/...achCables.html
Best Regards,
Mike
http://photoshow.comcast.net/mikenoel
It is not work that kills men; it is worry. Worry is rust upon the blade.
"Dave" wrote in message
I need to replace the tach cable in a friends plane. The inner part is what
needs replacement. I have access to another cable but the inner part is too
long.
I tried to square up a piece of cable from the old one, with no success. i
this, but I can't seem to find them any more. I guess the modern cars have
Any suggestions?
Dave
Old August 30th 07, 02:15 AM posted to rec.aviation.homebuilt,rec.aviation.owning
Dave[_16_]
Thanks for all the info and suggestions.
I had a spare cable and wanted to use it to fix the broken one.
I also just noticed that the one I have has the wrong twist on it.
I'll probably have to order a new one from chief.
Cheers
dave
Old August 30th 07, 04:35 AM posted to rec.aviation.homebuilt,rec.aviation.owning
Orval Fairbairn
Dave wrote:
http://www.chiefaircraft.com/airsec/.../TachCables.ht
ml
Cheers
dave
Just pull out both ends and take them to your local speedometer shop.
They have all the ends and can make up one for you for a few bucks. It
is not rocket science!
Old August 30th 07, 11:00 AM posted to rec.aviation.homebuilt,rec.aviation.owning
Morgans[_2_]
Tell me you're kidding! What size city do you live in, that could support
such a narrow specialty? I've never even heard of such a thing!
Jim in NC
Old August 30th 07, 01:47 PM posted to rec.aviation.owning
Jim Carter[_1_]
-----Original Message-----
Posted At: Thursday, August 30, 2007 5:00 AM
Posted To: rec.aviation.owning
Conversation: How to shorten a Tach drive cable?
Subject: How to shorten a Tach drive cable?
shop.
It
support
Jim in NC
We used to have three or four of the shops in Tulsa, Ok a few years ago,
and I'm pretty sure as of last weekend that they're all still there.
Tulsa is not that large, and never was; 350,000 or so.
Old August 30th 07, 02:29 PM posted to rec.aviation.homebuilt,rec.aviation.owning
Dave Butler
Where are you in NC, Jim? Pretty sure Bradley's could handle it:
Bradley's Service (919) 834-5727 101 S Blount St Raleigh, NC
Dave
Old August 30th 07, 04:16 PM posted to rec.aviation.homebuilt,rec.aviation.owning
Orval Fairbairn
Daytona Beach. Any speedometer shop should be able to make up a new
cable. The fittings are all standard.
secondary tach dave Owning 1 March 14th 07 08:34 PM
"Flaw Could Shorten Raptors' Lives" Mike Naval Aviation 0 May 12th 06 02:54 PM
Can anyone help, PLEASE - searching for zip-cord (aka: mono-cord, speaker wire, shooting wire, dbl hookup, rainbow cable, ribbon cable) Striker Cat Home Built 6 October 15th 04 08:51 PM
Tachometer or Tach Cable Rich Owning 14 October 14th 04 02:54 AM
Can anyone help, PLEASE - searching for zip-cord (aka: mono-cord, speaker wire, shooting wire, dbl hookup, rainbow cable, ribbon cable) Striker Cat General Aviation 0 October 12th 04 05:11 PM
