How to disable PDA connections to avoid error message?
Old April 17th 10, 03:03 PM posted to rec.aviation.soaring
Barny
Default How to disable PDA connections to avoid error message?
My HP5555 running Winpilot opens a pop-up error that I have to
manually close every few minutes in flight. "Unable to connect: You
have no modem entries created, and no network card present".
WP runs fine, just the error window blocking my view. GPS input is a
VL to SN10 to PDA, also working fine. I've already RTFM (96 pages),
it has many items on how to connect, but none on how 'not to connect'.
The blue tooth connection is disabled, but it's looking for a modem or
internet (?). I've tried every connection item in the menus and
settings, (except of course the one I need). Does anybody know where
to find the elusive setting? Appreciate any help, Thanks! Bruce Barnard
Old April 17th 10, 04:51 PM posted to rec.aviation.soaring
Darryl Ramm
manually close every few minutes in flight. *"Unable to connect: You
VL to SN10 to PDA, also working fine. *I've already RTFM (96 pages),
settings, (except of course the one I need). *Does anybody know where
The problem is Winpilot, you need to remove it and replace it with
SeeYou Mobile :-)
This is almost certainly Intellisync (aka Stupidsync) trying to
connect to your PC (over a dock conenctor or a network). Kill
Intellisync on the PDA if it is running and redock you PDA and let it
fully sync. Look at all the Intellisync settings on your PC, turn off
as much stuff as you can/don't need. You can look at the Intellisync
settings on the PDA but I suggest you change the settings on the PC.
Unless you really need to set toolsoptionsschedule to "manual" to
avoid Intellisync running ever time you put the PDA in the dock
connected to your PC. Personally with SeeYou Mobile I just install it
on the SD card and use that for transferring flight logs etc. (since
they go to a Macintosh) and I completely avoid any Intellisync
problems.
Darryl
Old April 17th 10, 05:24 PM posted to rec.aviation.soaring
Paul Remde
Hi Darryl,
Great advice - as always. But I think you meant to say "ActiveSync" not
Intellisync - didn't you?
Paul Remde
"Darryl Ramm" wrote in message
SeeYou Mobile :-)
problems.
Darryl
Old April 17th 10, 05:51 PM posted to rec.aviation.soaring
Darryl Ramm
On Apr 17, 9:24*am, "Paul Remde" wrote:
Hi Darryl,
Great advice - as always. *But I think you meant to say "ActiveSync" not
Paul Remde
SeeYou Mobile :-)
as much stuff as you can/don't need. *You can look at the Intellisync
problems.
Darryl
Yes, Stupidsync, just like I said :-) Low on caffeine this morning.
Darryl
Old April 18th 10, 04:03 AM posted to rec.aviation.soaring
Barny
Paul, Darryl, that did it even w/o syncing to the PC. One more to
add to my tips document. Thanks very much, Bruce
Old April 18th 10, 05:06 AM posted to rec.aviation.soaring
Darryl Ramm
On Apr 17, 8:03*pm, Barny wrote:
*Paul, Darryl, that did it even w/o syncing to the PC. *One more to
The reason to turn off automatic sync and make it manual only is
sometimes you put the PDA in and then quickly pull it out etc. without
thinking and the poor thing gets confused trying to sync. Better to
just do this manually.
In addition to killing activesync which fixing your problem you'll
often find stuff running in the background, activesync, File Explorer,
etc. etc. One thing that seems to help overall stability, is to do a
soft reset on the whole PDA. Some people do that every now and again,
and others before each flight, it seems to help improve stability (and
it certainly clears out these background processes).
Darryl
Old April 18th 10, 04:05 PM posted to rec.aviation.soaring
Barny
Hi Darryl, Active Sync was on manual last season. The cradle was not
plugged into the PC all winter, it was only charging because I only
use it for WP. Two weeks ago I ran the battery dead after a trip to
the airport, so I had to perform a reset to charge the battery. This
changed Active Sync to auto, but it wasn't connected to the PC so it
wanted to find Daddy. Thanks again, you saved me much frustration.
~Bruce
Narco Com IIA Wiring connections? Rod Home Built 4 October 12th 11 07:08 AM
LX4000 GPS Connections Brian[_1_] Soaring 4 April 28th 08 04:38 AM
Using biological weapons to disable my arms when I was only six years old. [email protected] Restoration 0 September 25th 05 08:49 PM
Garmin 430 error message: "com requires service"??? Guy Byars Owning 2 July 26th 05 02:28 AM
Hotellier connections Mike Soaring 38 September 28th 04 04:30 PM
