C182 vs Cherokee 6
*If it
wasn't for the additional costs, I would never fly an C172 again. The flying club I belong to has an R182 RG. It goes for $145 an hour. Is that about normal? High? Low? |
C182 vs Cherokee 6
john wrote: I was surprised at the difference on fuel consumtion. I have tried to fly both of them at the same altitude, RPM and fuel/air mixture. Over several flights the consumption stays about the same. I asked an instructor about it and he mentioned he can't get the high fuel consumption down either. It doesn't matter whether it was in the lower or higher altitudes (up to 7500 feet), and aggressive leaning, the Cherokee doesn't have the fuel economy of the Cessna. The engine had been rebuilt recently, (less than 200 hours), but I'm not sure that has anything to do with it. If the 140's tach is reading low, then it can have a higher than expected fuel burn. (fwiw - even with the 160hp conversion on my 140, I don't see 9gph, usually it's around 7 gph). -- Bob Noel (goodness, please trim replies!!!) |
C182 vs Cherokee 6
"kontiki" wrote: (I am suprised you are getting 12gph for the 182... the ones I've flown burn more than that). That's about right for 125 KTAS. -- Dan T-182T at BFM |
C182 vs Cherokee 6
wrote: The flying club I belong to has an R182 RG. It goes for $145 an hour. Is that about normal? Wet? Sounds like the low side of normal. -- Dan T-182T at BFM |
C182 vs Cherokee 6
Does the 160 HP conversion come with a repitched prop? Unless it does, your
fuel burn at a given RPM should actually go down because the engine has a higher compression ratio and produces power more efficiently. KB "Bob Noel" wrote in message ... In article , john wrote: I was surprised at the difference on fuel consumtion. I have tried to fly both of them at the same altitude, RPM and fuel/air mixture. Over several flights the consumption stays about the same. I asked an instructor about it and he mentioned he can't get the high fuel consumption down either. It doesn't matter whether it was in the lower or higher altitudes (up to 7500 feet), and aggressive leaning, the Cherokee doesn't have the fuel economy of the Cessna. The engine had been rebuilt recently, (less than 200 hours), but I'm not sure that has anything to do with it. If the 140's tach is reading low, then it can have a higher than expected fuel burn. (fwiw - even with the 160hp conversion on my 140, I don't see 9gph, usually it's around 7 gph). -- Bob Noel (goodness, please trim replies!!!) |
C182 vs Cherokee 6
"Kyle Boatright" wrote: Does the 160 HP conversion come with a repitched prop? Unless it does, your fuel burn at a given RPM should actually go down because the engine has a higher compression ratio and produces power more efficiently. I did repitch my prop to make it the same engine/prop as a warrior II. -- Bob Noel (goodness, please trim replies!!!) |
C182 vs Cherokee 6
John Smith wrote: In article , Gig 601XL Builder wrote: A 6-300 will cruise about 167 Knots and burn about 16gph. I think a 260 is a little under 140 knots at about 13 or 14gph. I've flown both but the 260 was a long time ago. I think you mean mph not kts. I fly a 6-300 and I flight plan and get 135 kts. 16 to 18 gph will depend on the engine installation, how high and how lean you like to fly. I have flown at 10,500 leaned to 12 gph but GS was only 95 kts. *nod* I've been flying a 6-300 for about 4 years now, and get 135 kts at 15 gph below 8,000 ft, and around 13.5 - 14 gph at 10,500. -- Dane |
C182 vs Cherokee 6
John Smith wrote:
In article , Gig 601XL Builder wrote: A 6-300 will cruise about 167 Knots and burn about 16gph. I think a 260 is a little under 140 knots at about 13 or 14gph. I've flown both but the 260 was a long time ago. I think you mean mph not kts. I fly a 6-300 and I flight plan and get 135 kts. 16 to 18 gph will depend on the engine installation, how high and how lean you like to fly. I have flown at 10,500 leaned to 12 gph but GS was only 95 kts. Yes I did mean MPH. Sorry. |
Similar Threads | ||||
C182 Oil Temperatures | Steve Leonard | Soaring | 0 | October 9th 07 04:53 AM |
C182 questions | Frank Whiteley | Soaring | 5 | October 8th 07 10:54 PM |
C182 Oil Temp | Steve Leonard | Soaring | 1 | October 8th 07 10:33 PM |
C182 overhaul | Chris | Owning | 7 | September 9th 06 05:58 AM |
Nearly new C182 checklist | Brinks | Owning | 7 | December 18th 04 04:00 AM |
